Topic: zoom "fit in view" leaves white space
when doing a zoom "fit in view" sometimes there is a empty space outside of the title block template
this can be on all sides
how to find what there?
QElectroTech → EN : Help, suggestions, discussions, ... → zoom "fit in view" leaves white space
hi, LievenC
Happens to me too, certain pages don't align to the top left corner...
I start erasing parts of the design, eventually it realigns. Then I "undo" several times to go back to the full pattern and it stays aligned up to a certain point. then it misaligns again...
Maybe is a bug with with allow unzoom beyond the folio?
And who knows... If I empty a part of it, then it realigns itself.
I can't figure out why.
I use the "allow unzoom" which allows me to move and center the corners with the mouse otherwise, beyond a certain limit, I would have to use the sliding bars of the window which are awkward.
I do not know..
thank you
Generated in 0.052 seconds (11% PHP - 89% DB) with 11 queries
