1 (edited by LievenC 2022-09-07 13:21:06)
Topic: update/replace element
case:
I am using an element from the custom library
then I notice I need to update the element
how to replace now the element that is already in the schematic with the version from the library which I just have updated??
I can of course delete the element and put the new one, but then all wires are lost
Re: update/replace element
Just drag and drop element updated and chose options.
Make a backup before.
the problem is that the existing element is still there and if you delete this all wires are also deleted
When you édit élément don‘t move or delete or add News terminales.
Also il‘s break compatibility and remove conductors linked to old element replaced.
Maybe I'm idiot, but both options - "make both elements coexist and "overwrite existing element" - have same result. New element is new and old elements stays same, not updated.
Ok, I found out that element is indeed replaced, but I have to reopen project to see changes. So far I have found no way how to update it in application. Anyway it works great, reloading is minor inconvenience.
