1 (edited by achim 2022-08-11 15:15:06)
Topic: Two mistakes?
I think I have found two mistakes.
1.  I cannot delete folders in Usercollection.
     A Massage appears: "Folder deletion failed"
2. A label in a Composite Text is not been updateted.
    See picture for mor details.
  I use the latest windows version (installer and ReadyToUse 64bit)
Re: Two mistakes?
1) same things with 32 bits version?
Are you sure your directory isn't in read only mode?
2) maybe send your project for we try.
Re: Two mistakes?
1) Directory is ok. I tested deleting the folders again today and it worked.
    I have had this problem with deleting the folders much more times.
    In this case I delete the folder in windows explorer.
    Strange that it works now. I don't know, I will observe and share if find out something.
2) See attachment
Re: Two mistakes?
Hmm don't use %F with composite text, folio label isn't in accessible variable for composite text.
BTW, a workaround is to cut this element and paste again when you have changed folio label. Or save, close and re open project.
Re: Two mistakes?
The champion of workarounds is back.
It's not a problem for me. I only wanted to share it.
Thank you very much for your help.
Achim
Re: Two mistakes?
Uhuhu. nomicons/smiley-green
Thanks Achim for report this issue.
Yes isn't refreshed on the fly.
