151 (edited by galexis 2022-08-04 14:15:13)
Je ne comprends pas ...désolé. PPA, dépots, clé, .... je suis perdu.
Pour LM21 c'est bien http://ppa.launchpad.net/scorpio/qelect … /InRelease ?
Je dois utiliser utiliser le dépot debian ? Modifier pour Ubuntu ?
sudo apt-key export 1D4FB6C1 | sudo gpg --dearmour -o /usr/share/keyrings/qelectrotech.gpg
echo "deb [signed-by=/usr/share/keyrings/qelectrotech.gpg] http://debian.qelectrotech.org/qet/debian/ unstable main" | sudo tee /etc/apt/sources.list.d/qelectrotech.list
Now remove in /etc/apt/sources.list :
And old key:
 sudo apt-key del 1D4FB6C1
The branch, master has been updated
       via  02769fe8816c02386c9e9feb5bb4ffb0e74a1fa0 (commit)
      from  e57ba72d7c5ec07ae61c2e5b467c251a34a93891 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
commit 02769fe8816c02386c9e9feb5bb4ffb0e74a1fa0
Author: joshua <Joshua@>
Date:   Wed Aug 3 13:54:39 2022 +0200
    Improve opening time of dxf
Summary of changes:
sources/editor/UndoCommand/openelmtcommand.cpp | 6 +++++-
1 file changed, 5 insertions(+), 1 deletion(-)
QET import dxf KP32_back_V2.dxf : ~ 2 seconds instead of 35 seconds
dxf2elmt run on Terminal convert KP32_back_V2.dxf : 279 ms
As you probably know, working on a large symbol such as a conversion from a DXF file is very tedious, partly due to the complex calculations for each primitive. Which can be very time consuming with thousands of selected primitives.
On this video, if you disable some of these calculations, the selection, editing and transformation work is instantaneous on a large DXF file freshly converted into a QET symbol.
There will be a lot of work to do on this part of the code to improve the user experience ...
Le PPA pour LM21 est bien http://ppa.launchpad.net/scorpio/qelect … /InRelease ?
Je vient de faire l'upgrade de mon laptop de la 20.04 LTS to Jamy en 22.04 LTS à part un petit soucis avec usmerge machin, j'ai au reboot rajouté le dépôt vers le PPA comme ceci et zou..
sudo add-apt-repository ppa:scorpio/qelectrotech-dev
Le pinning étant déjà en place et fait, ça c'est installé sans probleme.
PAs de problème d'installation, mais juste le message
W: http://ppa.launchpad.net/scorpio/qelectrotech-dev/ubuntu/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
J'ai rien dans sources.list.
J'ai ça en PPA et en clé
Capture d’écran du 2022-08-04 14-19-36.png, 76.17 kb, 1104 x 567
Pas la peine que je  te cherche et te mette des liens si tu ne les lis pas ... nomicons/smiley-green
cd /etc/apt
sudo cp trusted.gpg trusted.gpg.d
cd /etc/apt
J'ai regardé les liens mais j'étais perdu ...
La commande fonctionne. Grand merci.
C'est juste un workaround, lis les réponses plus bas.
https://askubuntu.com/questions/1398344 … 56#1408456
Ha OK, merci.
Polylines always closed on dxf export #228
https://github.com/qelectrotech/qelectr … issues/228
       via  af5d5e0aa39c55113f68f4e73db5622dc80dd224 (commit)
      from  e9931511ded2b8d05bd738e313379085c11a4757 (commit)
commit af5d5e0aa39c55113f68f4e73db5622dc80dd224
Author: David Varley <David.>
Date:   Sat Aug 13 11:57:29 2022 +1000
    Allow for open polygons (ie polylines) when saving as dxf
Summary of changes:
sources/exportdialog.cpp                 | 5 ++++-
sources/qetgraphicsitem/qetshapeitem.cpp | 5 ++++-
2 files changed, 8 insertions(+), 2 deletions(-)
       via  eee1c7fff7412a219ebb7a13fe588d9b756d2879 (commit)
      from  af5d5e0aa39c55113f68f4e73db5622dc80dd224 (commit)
commit eee1c7fff7412a219ebb7a13fe588d9b756d2879
Date:   Sat Aug 13 12:40:59 2022 +0200
    Element editor : Improve responsiveness when several shapes are selected.
       via  d6e8a1c133e7ba75c1ad108c76d77deae55ffec5 (commit)
      from  eee1c7fff7412a219ebb7a13fe588d9b756d2879 (commit)
commit d6e8a1c133e7ba75c1ad108c76d77deae55ffec5
Date:   Sat Aug 13 13:06:46 2022 +0200
    Element editor : improve deletion speed
Summary of changes:
sources/editor/elementscene.cpp | 10 ++++++++++
1 file changed, 10 insertions(+)
Improve download page: add more informations and links for externals programs, added more links to other binaries,
DXFtoQET, Dxf2elmt, Qet_translate, QET_ElementScaler, Qet_tb_generator:
https://qelectrotech.org/download.html.en
Add C-Born Engineering company in: They support us:
https://qelectrotech.org/index.html.en
Update QET Dokuwiki Hogfather to lastest stable Igor version, and btw fix error with vector template: "Security Token did not match. Possible CSRF attack".
https://forum.dokuwiki.org/d/20248-secu … srf-attack
Update Mantis bug tracker.
FYI, I updated OSX bundles to Qt 5.15.5 and KF5 to 5.97.0 versions.
Enjoy! nomicons/wink
QET est maintenant disponible sur le MDM IDF (ile de france PARIS)
https://assistanceidf.zendesk.com/hc/fr … ans-le-MDM
https://iledefrance-unowhy.com/projet/
Le projet numérique de la Région Île-de-France
Un projet d’envergure ayant pour but d’accélérer le virage numérique dans les lycées franciliens.
La Région met à disposition de chaque établissement un matériel numérique adapté aux besoins quotidiens des lycéens.
Deux types d’équipements sont proposés : des PC ultraportables Windows Y13 ou des tablettes Android Y10, conçus par la société française UNOWHY. Ces équipements intègrent des ressources pédagogiques gratuites (manuels scolaires, granules…) consultables également hors connexion.
Une plateforme de gestion « MDM » intégrée aux équipements accompagne les lycées dans leurs usages : le téléchargement des applications, les mises à jour… Tout peut se contrôler à distance.
Depuis 2019, la Région Île-de-France a décidé de prendre le virage numérique pour l’école et équipe l’ensemble des lycéens franciliens.
Résultat : Tous les lycéens entrant en classe de 2de dans un lycée public et tous les lycéens des filières professionnelles des lycées privés sous contrat sont dotés d’un équipement numérique individuel (PC ultraportable).
Les enseignants sont désormais dotés du même équipement numérique que leurs élèves.
Un grand merci aux très nombreux enseignants qui se servent de QET notre logiciel libre et gratuit, participent au projet, nous remontent des bugs ou des symboles avec leurs étudiants, et ce depuis maintenant plus d'une décennie pour enseigner l'électricité, la physique et ou des applications plus pointues comme Electricité appliqué dans les centres industriel, la domotique, le pneumatique, l’hydraulique, les énergies alternatives comme le solaire, géothermie , etc, à nos chers enfants.
Dommage que ce ne soit pas le cas dans certaines académies, ou des enseignants réputés utilisent encore des logiciels propriétaires inaccessibles aux enfants en dehors de l’établissement, de part leurs coûts exorbitants et non pas encore connaissance de l’existence d'alternatives libres et surtout gratuite comme QElectroTech ...  de son potentiel et évolutions.
Et ou l’élève curieux pourra approfondir chez lui ses connaissances avec un logiciel qu'il utilise au lycée, ou  dans l'enseignement supérieure quelque soit le système d'exploitation qu'il trouvera chez lui ou chez ses copains, famille: macOS, Windows, Linux..
Pour preuve mon petit dernier en 2019 qui quand il était en bac pro et ensuite en BTS maintenance industrielle, ses professeurs n'avaient jamais entendus parler de QET.....
FYI, Update cross-compiler MXE x86_64 (only for Windows 64) builds to:
KF5 5.96.0 -> KF5: 5.98.0
Qt 5.15.5 -> Qt: 5.15.6
GCC:11.3.0
https://www.tuxfamily.org/
Power hiccup
Posté le samedi 24 septembre 2022, à 21:13 UTC
Today, around 19:20 UTC, we experienced a power hiccup that killed some hosts. We managed to bring back most services, everything else (panel, mail, webmail) will be back shortly.
Upgrade to Qt 5.15.6.
Enjoy. nomicons/wink
Qt 5.15.6 -> Qt: 5.15.7
https://github.com/mxe/mxe/commit/06c4e … a7d2a931d6
Free Cloud Hosting by OnWorks Use free servers, workstations
This is the qelectrotech command that can be run in the OnWorks free hosting provider using one of our multiple free online workstations such as Ubuntu Online, Fedora Online, Windows online emulator or MAC OS online emulator
https://www.onworks.net/nl/programs/qelectrotech-online
Formation aux schémas électriques sur Ordinateurs (LOGICIEL QELECTROTECH) Auteur : Beranger SIX Aout 2022.
https://www.slideshare.net/BerangerSIX/ … triquepptx
How to design, develop and build a fully-integrated melt electrowriting 3D printer
Custom parts were designed with PTC Creo Parametric 3.0 computer aided design (CAD) software. Wiring diagrams were created with QElectroTech
https://www.sciencedirect.com/science/a … 0422003918
Good article by Pawel: ;-)
Errors in the electrical installations of machines:
https://pawelsmiech.prv.pl/bledy-w-inst … ych-maszyn
Win 10 Version 22H2
Elements collection finished to be loaded in 1.237 seconds
Elements collection finished to be loaded in 3.031 seconds
Installer_QElectroTech-0.90-DEV_x86_64-win64+git7722-1.exe
16:23:31.146 Info: Start-up
16:23:31.149 Debug: "File C:/Users/hp/Application Data/qet/20220929.log is deleted!" (../sources/main.cpp:150, void delete_old_log_files(int))
16:23:31.539 Info: Elements collection reload
16:23:31.637 Info: debugging enabled: false
16:23:31.638 Info: Qt library version: 5.15.7
16:23:31.639 Info: Qt library location default prefix: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
16:23:31.640 Info: Qt library location documentation: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/doc"
16:23:31.641 Info: Qt library location headers: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/include"
16:23:31.641 Info: Qt library location libraries: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/lib"
16:23:31.641 Info: Qt library location executables: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
16:23:31.641 Info: Qt library location Qt binaries: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
16:23:31.642 Info: Qt library location Qt plugins: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/plugins"
16:23:31.642 Info: Qt library location installed QML extensions: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/imports"
16:23:31.643 Info: Qt library location installed QML extensions: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/qml"
16:23:31.643 Info: Qt library location dependent Qt data: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
16:23:31.644 Info: Qt library location independent Qt data: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
16:23:31.644 Info: Qt library location translation: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/translations"
16:23:31.646 Info: Qt library location examples: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/examples"
16:23:31.646 Info: Qt library location Qt testcases: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/tests"
16:23:31.646 Info: "QElectroTech V 0.90-DEV+300440454b0a58100c957a06d79751d3"
16:23:31.647 Info: "Compilation : GCC 11.3.0"
16:23:31.647 Info: "Built with Qt 5.15.7 - x86_64 - Date : Nov 17 2022 : 00:09:46"
16:23:31.647 Info: "Run with Qt 5.15.7 using 8 thread(s)"
16:23:31.648 Info: "CPU : NAME                                      \r\r\nINTEL(R) CORE(TM) I7-8550U CPU @ 1.80GHZ  \r\r\n\r\r\n"
16:23:31.649 Info: "RAM Total : 16 GB"
16:23:31.649 Info: "RAM Available : 12 GB"
16:23:31.650 Info: "GPU : VideoProcessor                \r\r\nIntel(R) UHD Graphics Family  \r\r\n\r\r\n"
16:23:31.650 Info: "GPU RAM : RAM Total : AdapterRAM  \r\r\n1073741824  \r\r\n\r\r\n B"
16:23:31.650 Info: "OS : winnt  - x86_64 - Version : Windows 10 Version 2009 - Kernel : 10.0.19045"
16:23:31.651 Info: *** Qt screens ***
16:23:31.651 Info: "( 1 : 3840 x 2160 )"
16:23:31.652 Info: DISK : C:/
16:23:31.652 Info: FileSystemType: "NTFS"
16:23:31.652 Info: SizeTotal: 66 GB
16:23:31.653 Info: AvailableSize: 10 GB
16:23:31.654 Info: DISK : D:/
16:23:31.654 Info: FileSystemType: "NTFS"
16:23:31.655 Info: SizeTotal: 20 GB
16:23:31.655 Info: AvailableSize: 0 GB
16:23:31.656 Info: DISK USED: C:/
16:23:31.657 Info: FileSystemType: "NTFS"
16:23:31.658 Info: SizeTotal: 66 GB
16:23:31.658 Info: AvailableSize: 10 GB
16:23:33.529 Info: Elements collection finished to be loaded in 1.989 seconds
16:23:35.741 Debug: Export XML de 0 schemas (../sources/qetproject.cpp:916, QDomDocument QETProject::toXml())
16:23:35.745 Debug: is QRegularExpression ok? (../sources/titleblocktemplate.cpp:437, void TitleBlockTemplate::parseColumns(const QString&))
16:23:36.605 Info: Elements collection finished to be loaded
16:24:54.886 Info: Start-up
16:24:55.286 Info: Elements collection reload
16:24:55.288 Info: debugging enabled: false
16:24:55.289 Info: Qt library version: 5.15.7
16:24:55.289 Info: Qt library location default prefix: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
16:24:55.290 Info: Qt library location documentation: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/doc"
16:24:55.290 Info: Qt library location headers: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/include"
16:24:55.291 Info: Qt library location libraries: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/lib"
16:24:55.291 Info: Qt library location executables: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
16:24:55.292 Info: Qt library location Qt binaries: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
16:24:55.292 Info: Qt library location Qt plugins: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/plugins"
16:24:55.293 Info: Qt library location installed QML extensions: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/imports"
16:24:55.293 Info: Qt library location installed QML extensions: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/qml"
16:24:55.293 Info: Qt library location dependent Qt data: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
16:24:55.294 Info: Qt library location independent Qt data: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
16:24:55.294 Info: Qt library location translation: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/translations"
16:24:55.295 Info: Qt library location examples: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/examples"
16:24:55.295 Info: Qt library location Qt testcases: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/tests"
16:24:55.296 Info: "QElectroTech V 0.90-DEV+300440454b0a58100c957a06d79751d3"
16:24:55.296 Info: "Compilation : GCC 11.3.0"
16:24:55.296 Info: "Built with Qt 5.15.7 - x86_64 - Date : Nov 17 2022 : 00:09:46"
16:24:55.297 Info: "Run with Qt 5.15.7 using 8 thread(s)"
16:24:55.297 Info: "CPU : NAME                                      \r\r\nINTEL(R) CORE(TM) I7-8550U CPU @ 1.80GHZ  \r\r\n\r\r\n"
16:24:55.298 Info: "RAM Total : 16 GB"
16:24:55.298 Info: "RAM Available : 12 GB"
16:24:55.299 Info: "GPU : VideoProcessor                \r\r\nIntel(R) UHD Graphics Family  \r\r\n\r\r\n"
16:24:55.299 Info: "GPU RAM : RAM Total : AdapterRAM  \r\r\n1073741824  \r\r\n\r\r\n B"
16:24:55.299 Info: "OS : winnt  - x86_64 - Version : Windows 10 Version 2009 - Kernel : 10.0.19045"
16:24:55.300 Info: *** Qt screens ***
16:24:55.300 Info: "( 1 : 3840 x 2160 )"
16:24:55.301 Info: DISK : C:/
16:24:55.302 Info: FileSystemType: "NTFS"
16:24:55.302 Info: SizeTotal: 66 GB
16:24:55.303 Info: AvailableSize: 10 GB
16:24:55.303 Info: DISK : D:/
16:24:55.304 Info: FileSystemType: "NTFS"
16:24:55.304 Info: SizeTotal: 20 GB
16:24:55.304 Info: AvailableSize: 0 GB
16:24:55.306 Info: DISK USED: C:/
16:24:55.306 Info: FileSystemType: "NTFS"
16:24:55.306 Info: SizeTotal: 66 GB
16:24:55.307 Info: AvailableSize: 10 GB
16:24:56.524 Info: Elements collection finished to be loaded in 1.237 seconds
16:47:48.655 Info: Start-up
16:47:49.040 Info: Elements collection reload
16:47:49.124 Info: debugging enabled: false
16:47:49.125 Info: Qt library version: 5.15.7
16:47:49.125 Info: Qt library location default prefix: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
16:47:49.126 Info: Qt library location documentation: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/doc"
16:47:49.126 Info: Qt library location headers: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/include"
16:47:49.127 Info: Qt library location libraries: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/lib"
16:47:49.127 Info: Qt library location executables: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
16:47:49.128 Info: Qt library location Qt binaries: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
16:47:49.129 Info: Qt library location Qt plugins: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/plugins"
16:47:49.129 Info: Qt library location installed QML extensions: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/imports"
16:47:49.129 Info: Qt library location installed QML extensions: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/qml"
16:47:49.130 Info: Qt library location dependent Qt data: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
16:47:49.130 Info: Qt library location independent Qt data: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
16:47:49.131 Info: Qt library location translation: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/translations"
16:47:49.131 Info: Qt library location examples: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/examples"
16:47:49.131 Info: Qt library location Qt testcases: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/tests"
16:47:49.132 Info: "QElectroTech V 0.90-DEV+300440454b0a58100c957a06d79751d3"
16:47:49.132 Info: "Compilation : GCC 11.3.0"
16:47:49.133 Info: "Built with Qt 5.15.7 - x86_64 - Date : Nov 17 2022 : 00:09:46"
16:47:49.133 Info: "Run with Qt 5.15.7 using 8 thread(s)"
16:47:49.134 Info: "CPU : NAME                                      \r\r\nINTEL(R) CORE(TM) I7-8550U CPU @ 1.80GHZ  \r\r\n\r\r\n"
16:47:49.134 Info: "RAM Total : 16 GB"
16:47:49.134 Info: "RAM Available : 12 GB"
16:47:49.134 Info: "GPU : VideoProcessor                \r\r\nIntel(R) UHD Graphics Family  \r\r\n\r\r\n"
16:47:49.135 Info: "GPU RAM : RAM Total : AdapterRAM  \r\r\n1073741824  \r\r\n\r\r\n B"
16:47:49.136 Info: "OS : winnt  - x86_64 - Version : Windows 10 Version 2009 - Kernel : 10.0.19045"
16:47:49.136 Info: *** Qt screens ***
16:47:49.136 Info: "( 1 : 3840 x 2160 )"
16:47:49.137 Info: DISK : C:/
16:47:49.137 Info: FileSystemType: "NTFS"
16:47:49.138 Info: SizeTotal: 66 GB
16:47:49.138 Info: AvailableSize: 7 GB
16:47:49.138 Info: DISK : D:/
16:47:49.139 Info: FileSystemType: "NTFS"
16:47:49.139 Info: SizeTotal: 20 GB
16:47:49.139 Info: AvailableSize: 0 GB
16:47:49.141 Info: DISK USED: C:/
16:47:49.141 Info: FileSystemType: "NTFS"
16:47:49.141 Info: SizeTotal: 66 GB
16:47:49.142 Info: AvailableSize: 7 GB
16:47:52.072 Info: Elements collection finished to be loaded in 3.031 seconds
I'm thinking of abandoning 32-bits builds packages soon for Windows, what do you think?
