Topic: qelectrotech language and project language
I found that qelectrotech  is not full translated in some languages.
qelectrotech does have a language selector what about project language ?
Can we set qelectrotech language to english and get the project in other language ?
Thanks.
Re: qelectrotech language and project language
maybe you could help to translate, is easy, see:
https://qelectrotech.org/wiki_new/doc/translation
https://doc.qt.io/qt-5/linguist-translators.html
Because word chain's to translate are in French in the code you need:
https://doc.qt.io/qt-5/linguist-transla … ltaneously
Hi scorpio810,
Thanks for your reply but, Can we set qelectrotech language to english and get the project and symbols in other language ?
Thanks.
Hi vilatech,
for now you can't.
But I think now a workaround is possible : qet_en.qm is translation binary English for UI.
Copy this file and rename it by example to country you want like qet_nl.qm and of course delete old file or backup it to other directory.
Launch QET and select now Nederlands flags, restart QET.
https://qelectrotech.org/wiki_new/doc/d … mande_tree
Is there any change regarding separate language setting for UI and Project? It would be a valuable feature, because I work with English UI, but need to export folios mostly in Hungarian, but sometimes in English.
Thank you for this software and for the above workaround! nomicons/smile
