Topic: More element prefix...
After trying every fix I can find in the forums I can't get the prefix to appear on items from the standard elements library.
At this stage I just want to achieve basic functionalities before I move on to creating my own elements.
I have uninstalled the software, removed all registry keys and hidden Windows directories and tested previous portable
versions. I have found that going back to version 0.61 it works perfectly; a coil picks up the K prefix perfectly from the xml file.
All later versions do not pick up the prefix. I understand the rest of the label creation but the prefix is an essential element.
So my question must be what is different 'out of the box' between version 0.61 and the later versions?
2 (edited by Joshua 2022-02-23 20:12:36)
Re: More element prefix...
Hello,
this feature is broken due to the change of path of elements in the official collection.
The elements prefix are found in the file "qet_labels.xml" who is stored in the root folder of the official collection.
The prefix is found in the file "qet_label" at the same path of the element itself.
The official collection folder was rearranged but not the "qet_label" and so prefix are broken now.
We need to update the file according to the current collection. If you have time and desire to update this file and send us, it will be very helpful for us.
To resume, the elements prefix is actually broken.
Thanks very much for your quick response. I'm new here and would like to commend you on the quantity and the quality of the work you guys have put into this project.
I had a look for the "qet_label" file but could not find it. I'm looking in the ready to use version if that makes any difference?
If you can please point me in the right direction I will try and help with this problem.
I checked versions against each other and see that the qet_label.xml file appears in a different position between version; can you confirm the correct place for the newer versions please?
Thanks in advance.
Maybe in ~/Qet-svn/git/qet/elements/10_electric$ cat qet_labels.xml
replace & by undferscore see https://git.tuxfamily.org/qet/qet.git/c … 77a375223f etc
https://git.tuxfamily.org/qet/qet.git/c … 253a7aafbc
@Doezee : try new builds.
This is still the case in version 0.100. No prefix is loaded if the element files and 'qet_labels.xml' are not in the default directory.
https://qelectrotech.org/forum/viewtopi … 335#p11335
https://github.com/qelectrotech/qelectr … s.cpp#L664
I think the code hasn’t been updated with the latest changes to the path and the ‘company’ collection for function "qet_labels.xml' for users collections.
Please report this issue on bugtracker on our GitHub repository. Thanks for your feedback.
https://github.com/qelectrotech/qelectr … ror/issues
https://qelectrotech.org/bugtracker
Edit: https://github.com/qelectrotech/qelectr … ls_to_file
I don't have permission to add a 'New Issue'
If you talk about Mantis bugtraker you need to create new user login and new password.
BR,
