Topic: Incomplete display of the user's collection in QElectroTech.
I don't use the QElectroTech program for a long time. First, I had a version of QT-0.70 RC 1-win64+svn5832-1 in it I created my collection of elements according to the Russian GOST. Then I updated this version to version QET-0.70-win64+git5967-1, the collection of elements was shown in the library normally. There were labels for each folder with elements, sketches of elements and so on. When I updated QElectroTech to version QT-0.80+87c957a06d79751d3, my collection of elements stopped displaying normally in the library. How it looks is shown in the screenshot of the program. When transferring an element to the schema field, it has a normal image such as it should be. I have Windows 7 Professional 6.1 SP1 64 bit. Maybe the latest version of Qelectrotech is incompatible with my Windows 7 or you need some updates and similar additions, for example, NET.Framework? Sincerely, Alexander.
Re: Incomplete display of the user's collection in QElectroTech.
Hi Alexander,
you could share your collection for check?
Good afternoon. It does not accept a zip file for uploading to the site. Maybe you need a different file extension?
I don't saw problem with your collection on 0.9-dev..
Thanks for attention. Do you suggest that I install the program version 0.9?
I installed version 0.9, the problem is the same.
You could join pictures or an example project off your problem?
Yes, the screenshot is at the bottom.
КПллекцОя.jpg, 21.73 kb, 287 x 539
You could try it on other machine?
https://download.qelectrotech.org/qet/forum_img_2/alexander.png
10 (edited by vishne-aleksandr 2021-07-02 22:26:21)
This is a picture from a laptop. It has the same Windows, but I use it to store files that are valuable to me. There are fewer programs installed on the laptop.
Collection.jpg, 40.41 kb, 425 x 536
Hello. Sorry for the insistence, I wanted to find out about the issue of displaying "My Collection" in the QElectroTech program. Maybe I should go back to version 0.7? Sincerely, Alexander.
I tried on laptop with 0.8 ReadyToUse on WIN10, and I don't saw problem with your collection.
I returned version 0.7. I attach a screenshot. Probably version 0.8 and higher do not support Windows 7 SP1?
Collection My.jpg, 39.36 kb, 344 x 610
QET 0.8 and 0.9 work well on W7
Hello.
I have a comment about the problem "Incomplete display of user
collection in QElectroTech" by vishne-aleksandr.
I use QElectrotech installed on C drive. A year ago I solved the same
problem with a collection of elements. The element icons were not
visible in either W7 or W10.
In W10, I partitioned the disk and moved the collection to disk D and
modified the path to the collection and the program works fine.
Karel
16 (edited by vishne-aleksandr 2021-07-07 18:38:58)
Thanks. Karel's advice didn't help. "My Collection" is displayed as before, that is, without icons. Maybe my operating system is missing some kind of update or ....?
Try this (I think this will not fix the problem but...).
Close qet, with the file explorer go to : C:\Users\aleksandr\AppData\Roaming\qet
In this folder delete the file 'elements_cache.sqlite'.
Launch qet again.
Good afternoon. You are right, deleting the file did not help.
