Topic: Summary table order
Could you help me with ordering the information in the summary table.
Attached, a test with the new summary tool. As you can see, it does not follow the order of the pages.
Thanks for listening
QElectroTech → EN : Help, suggestions, discussions, ... → Summary table order
Modify request like this:
SELECT folio, title, plant, locmach, indexrev, author, date, pos FROM project_summary_view ORDER BY pos
Result
hello galexis. I made the change that shows but I didn't get a positive result.
version I'm using for testing
When you set the position to column 1, the order works.
Make picture of request
Hi Galexis. Sorry for the delay, I had to travel this weekend.
Follow the images of the requests and the result afterwards.
I am using the summary with the position in the initial column. It solved my problem for now.
Result 1
request 2
result 2
qet version
They bought me an eplan at work. There I saw good ideas. But unfortunately I have been sitting for a week now and I cannot draw a single scheme.
The plan uses item databases. Simple elements have access to a large database. This database can be replenished from any manufacturer. You can also get a graphical execution for the schemes there. The base is very extensive and reports are made from it. There is only one problem - licensing. But I think the idea is good. I understand that this can add a lot of work, but we need to evaluate this opportunity looking in the future.
Generated in 0.047 seconds (29% PHP - 71% DB) with 11 queries
