Topic: Summary table order
Could you help me with ordering the information in the summary table.
Attached, a test with the new summary tool. As you can see, it does not follow the order of the pages.
Thanks for listening
Re: Summary table order
Modify request like this:
SELECT folio, title, plant, locmach, indexrev, author, date, pos FROM project_summary_view ORDER BY pos
Capture d’écran du 2020-12-11 11-52-22.png, 29.45 kb, 1107 x 522
Result
Capture d’écran du 2020-12-11 11-51-16.png, 63.77 kb, 891 x 622
hello galexis. I made the change that shows but I didn't get a positive result.
Ordem da tabela.png, 78.93 kb, 961 x 598
version I'm using for testing
versão.png, 35.6 kb, 850 x 546
When you set the position to column 1, the order works.
Ordem da tabela.png, 77.24 kb, 995 x 654
Make picture of request
Hi Galexis. Sorry for the delay, I had to travel this weekend.
Follow the images of the requests and the result afterwards.
I am using the summary with the position in the initial column. It solved my problem for now.
Ordem da tabela solicitção.png, 100.15 kb, 1366 x 729
Result 1
Ordem da tabela.png, 139.31 kb, 1366 x 730
request 2
Ordem da tabela solicitção 2.png, 120.44 kb, 1366 x 729
result 2
Ordem da tabela 2.png, 136.53 kb, 1366 x 729
qet version
versão.png, 104.76 kb, 1366 x 727
They bought me an eplan at work. There I saw good ideas. But unfortunately I have been sitting for a week now and I cannot draw a single scheme.
The plan uses item databases. Simple elements have access to a large database. This database can be replenished from any manufacturer. You can also get a graphical execution for the schemes there. The base is very extensive and reports are made from it. There is only one problem - licensing. But I think the idea is good. I understand that this can add a lot of work, but we need to evaluate this opportunity looking in the future.
eplan.PNG, 49.04 kb, 660 x 621
