Re: Qt 6.0 development and qelectrotech
Fixed by rm CMakeLists.txt otherwise my Debian dh saw an cmake build and not use qmake.
For GIT_COMMIT_SHA fixed by refresh my quilt patch.
oops, that was not the intention, refer or delete the Cmake I'll see what can be done
https://github.com/mxe/mxe/issues/2594
54 (edited by De-Backer 2020-12-11 15:44:41)
Cmake buit werkt nomicons/smile
with the associated problems
[282/283 4.7/sec] Linking CXX executable tests/googlemock/G_unitmocktests
[283/283 4.5/sec] Linking CXX executable qelectrotech
14:22:51: The process "/home/simon/Qt/Tools/CMake/bin/cmake" exited normally.
14:22:51: Elapsed time: 01:03.
14:22:51: Starting /home/simon/GIT/build/qet-Desktop_Qt_5_15_1_GCC_64bit-Debug/qelectrotech ...
failed to load "qt_be" "/home/simon/GIT/build/qet-Desktop_Qt_5_15_1_GCC_64bit-Debug/lang/"
failed to load qet_en "/home/simon/GIT/build/qet-Desktop_Qt_5_15_1_GCC_64bit-Debug/lang/"
qt.svg: Cannot open file ':/ico/16x16/window-close.svg', because: No such file or directory
14:22:51.374 Info: Start-up
14:22:51.407 Info: debugging enabled: false
14:22:51.407 Info: Qt library version: 5.15.1
14:22:51.407 Info: Qt library location default prefix: "/home/simon/Qt/5.15.1/gcc_64"
14:22:51.407 Info: Qt library location documentation: "/home/simon/Qt/5.15.1/gcc_64/doc"
14:22:51.407 Info: Qt library location headers: "/home/simon/Qt/5.15.1/gcc_64/include"
14:22:51.407 Info: Qt library location libraries: "/home/simon/Qt/5.15.1/gcc_64/lib"
14:22:51.407 Info: Qt library location executables: "/home/simon/Qt/5.15.1/gcc_64/libexec"
14:22:51.408 Info: Qt library location Qt binaries: "/home/simon/Qt/5.15.1/gcc_64/bin"
14:22:51.408 Info: Qt library location Qt plugins: "/home/simon/Qt/5.15.1/gcc_64/plugins"
14:22:51.408 Info: Qt library location installed QML extensions: "/home/simon/Qt/5.15.1/gcc_64/imports"
14:22:51.408 Info: Qt library location installed QML extensions: "/home/simon/Qt/5.15.1/gcc_64/qml"
14:22:51.408 Info: Qt library location dependent Qt data: "/home/simon/Qt/5.15.1/gcc_64"
14:22:51.408 Info: Qt library location independent Qt data: "/home/simon/Qt/5.15.1/gcc_64"
14:22:51.408 Info: Qt library location translation: "/home/simon/Qt/5.15.1/gcc_64/translations"
14:22:51.408 Info: Qt library location examples: "/home/simon/Qt/5.15.1/gcc_64/examples"
14:22:51.408 Info: Qt library location Qt testcases: "/home/simon/Qt/5.15.1/gcc_64/tests"
14:22:51.408 Info: Qt library location Qt settings: "/etc/xdg"
14:22:51.408 Info: "GitRevision aacbe57d51e66b4cfb021e32bcefdc7109bc76b3"
14:22:51.408 Info: "QElectroTech V 0.80-rc"
14:22:51.408 Info: "Compilation : GCC 10.2.1 20201202 [revision e563687cf9d3d1278f45aaebd03e0f66531076c9]"
14:22:51.408 Info: "Built with Qt 5.15.1 - Date : Dec 11 2020 : 14:21:59"
14:22:51.408 Info: "Run with Qt 5.15.1 using 16 thread(s)"
14:22:51.408 Info: "CPU : model name\t: AMD Ryzen 7 3700X 8-Core Processor\n"
14:22:51.408 Info: "RAM Total : 32026 MB"
14:22:51.408 Info: "RAM Available : 22311 MB"
14:22:51.408 Info: "GPU : "
14:22:51.408 Info: "GPU RAM : @ToDo"
14:22:51.408 Info: "OS : linux  - x86_64 - Version : openSUSE Tumbleweed - Kernel : 5.9.12-1-default"
14:22:51.408 Info: *** Qt screens ***
14:22:51.408 Info: "( 1 : 3840 x 2160 )"
14:22:51.673 Info: Elements collection reload
14:22:51.963 Info: Elements collection finished to be loaded
14:23:49: /home/simon/GIT/build/qet-Desktop_Qt_5_15_1_GCC_64bit-Debug/qelectrotech exited with code 0
Screenshot_20201211_144409.png, 70.18 kb, 1549 x 1143
improvement
Screenshot_20201211_160804.png, 71.52 kb, 1168 x 988
does anyone have an idea?
qet> cmake .
_____________________________________________________________________
Copyright 2006 The QElectroTech Team
This file is part of QElectroTech.
QElectroTech is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 2 of the License, or
(at your option) any later version.
QElectroTech is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with QElectroTech.  If not, see <http://www.gnu.org/licenses/>.
PROJECT_NAME       :qelectrotech
PROJECT_SOURCE_DIR :/home/simon/GIT/qet
QET_DIR            :/home/simon/GIT/qet
GIT_COMMIT_SHA     :74b112a4bb794061127313ba6c39ee7762964321
KF5_GIT_TAG        :v5.70.0
-- The C compiler identification is GNU 10.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
Installing in /usr/local. Run /home/simon/GIT/qet/_deps/kcoreaddons-build/prefix.sh to set the environment for qelectrotech.
-- Setting build type to 'Debug' as none was specified.
-- Looking for __GLIBC__
-- Looking for __GLIBC__ - found
-- Performing Test _OFFT_IS_64BIT
-- Performing Test _OFFT_IS_64BIT - Success
-- Performing Test HAVE_DATE_TIME
-- Performing Test HAVE_DATE_TIME - Success
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Could NOT find FAM (missing: FAM_INCLUDE_DIR FAM_LIBRARIES)
CMake Warning (dev) at /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:424 (message):
  The package name passed to `find_package_handle_standard_args` (PROCSTAT)
  does not match the name of the calling package (Procstat).  This can lead
  to problems in calling code that expects `find_package` result variables
  (e.g., `_FOUND`) to follow a certain pattern.
Call Stack (most recent call first):
  _deps/kcoreaddons-src/cmake/FindProcstat.cmake:18 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
  _deps/kcoreaddons-src/CMakeLists.txt:68 (find_package)
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Could NOT find PROCSTAT (missing: PROCSTAT_INCLUDE_DIR PROCSTAT_LIBRARIES)
-- Looking for include files sys/types.h, sys/mman.h
-- Looking for include files sys/types.h, sys/mman.h - found
-- Looking for getgrouplist
-- Looking for getgrouplist - found
-- Performing Test COMPILER_HAS_HIDDEN_VISIBILITY
-- Performing Test COMPILER_HAS_HIDDEN_VISIBILITY - Success
-- Performing Test COMPILER_HAS_HIDDEN_INLINE_VISIBILITY
-- Performing Test COMPILER_HAS_HIDDEN_INLINE_VISIBILITY - Success
-- Performing Test COMPILER_HAS_DEPRECATED_ATTR
-- Performing Test COMPILER_HAS_DEPRECATED_ATTR - Success
-- At least one python version must be available to use PythonModuleGeneration.
-- Found SharedMimeInfo: /usr/bin/update-mime-database (found suitable version "2.0", minimum required is "1.3")
-- Performing Test HAVE_QFILESYSTEMWATCHER
-- Performing Test HAVE_QFILESYSTEMWATCHER - Success
-- The following OPTIONAL packages have been found:
 * Threads
 * Inotify
   Filesystem alteration notifications using inotify
 * SharedMimeInfo (required version >= 1.3), A database of common MIME types, <https://freedesktop.org/wiki/Software/shared-mime-info/>
   Allows KDE applications to determine file types
-- The following REQUIRED packages have been found:
 * ECM (required version >= 5.70.0), Extra CMake Modules., <https://commits.kde.org/extra-cmake-modules>
 * Qt5Core
 * Qt5LinguistTools
 * Qt5 (required version >= 5.12.0)
-- The following features have been disabled:
 * QCH, API documentation in QCH format (for e.g. Qt Assistant, Qt Creator & KDevelop)
-- The following OPTIONAL packages have not been found:
 * FAM, File alteration notification support via a separate service, <http://oss.sgi.com/projects/fam>
   Provides file alteration notification facilities using a separate service. FAM provides additional support for NFS.
 * Procstat
   Process information using libprocstat
 * PythonModuleGeneration
Installing in /usr/local. Run /home/simon/GIT/qet/_deps/kwidgetsaddons-build/prefix.sh to set the environment for qelectrotech.
-- The following features have been enabled:
 * DESIGNERPLUGIN, Build plugin for Qt Designer
 * Threads
 * Inotify
 * Qt5Gui (required version >= 5.15.2)
 * Qt5Widgets
 * Qt5Core
 * Qt5LinguistTools
 * Qt5UiPlugin
   Required to build Qt Designer plugins
 * Qt5Test
 * Procstat
QET_COMPONENTS     :WidgetsConcurrentXmlSvgNetworkSqlPrintSupportLinguistTools
QT_VERSION_MAJOR   :5
!!  TESTING TESTING TESTING TESTING TESTING  !!
Add sub directorie tests
.____________________________________________________________________
. PROJECT_NAME:       unittests
. PROJECT_SOURCE_DIR: /home/simon/GIT/qet/tests
. Add sub directorie catch
..___________________________________________________________________
.. PROJECT_NAME       :C_unittests
.. PROJECT_SOURCE_DIR :/home/simon/GIT/qet/tests/catch
.. QET_DIR            :/home/simon/GIT/qet
.. QT_VERSION_MAJOR   :5
.. CATCH_INCLUDE_DIR is not set,assuming Catch2 can be found automatically in your system
. Add sub directorie googletest
.. PROJECT_NAME       :G_unittests
.. PROJECT_SOURCE_DIR :/home/simon/GIT/qet/tests/googletest
CMake Deprecation Warning at _deps/gtest-src/CMakeLists.txt:4 (cmake_minimum_required):
  Compatibility with CMake < 2.8.12 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value or use a ...<max> suffix to tell
  CMake that the project does not need compatibility with older versions.
CMake Deprecation Warning at _deps/gtest-src/googlemock/CMakeLists.txt:45 (cmake_minimum_required):
  CMake.
CMake Deprecation Warning at _deps/gtest-src/googletest/CMakeLists.txt:56 (cmake_minimum_required):
  CMake.
-- Found PythonInterp: /usr/bin/python3.8 (found version "3.8.6")
. Add sub directorie googlemock
.. PROJECT_NAME       :G_unitmocktests
.. PROJECT_SOURCE_DIR :/home/simon/GIT/qet/tests/googlemock
. Add sub directorie qttest
.. PROJECT_NAME       :qt_unittests
.. PROJECT_SOURCE_DIR :/home/simon/GIT/qet/tests/qttest
-- Configuring done
CMake Error at /usr/share/ECM/modules/ECMAddTests.cmake:89 (add_executable):
  Cannot find source file:
    /home/simon/GIT/qet/src/lib/text/ktexttohtml.cpp
  Tried extensions .c .C .c++ .cc .cpp .cxx .cu .m .M .mm .h .hh .h++ .hm
  .hpp .hxx .in .txx .f .F .for .f77 .f90 .f95 .f03 .ispc
  _deps/kcoreaddons-src/autotests/CMakeLists.txt:80 (ecm_add_test)
CMake Warning (dev) in _deps/pugixml-src/CMakeLists.txt:
  AUTOGEN: No valid Qt version found for target pugixml-shared.  AUTOMOC,
  AUTOUIC and AUTORCC disabled.  Consider adding:
    find_package(Qt<QTVERSION> COMPONENTS Widgets)
  to your CMakeLists.txt file.
-- Generating done
CMake Generate step failed.  Build files cannot be regenerated correctly.
if this works, QET can be built autonomously
/GIT/kcoreaddons/build> cmake ..
-- The CXX compiler identification is GNU 10.2.1
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Installing in the same prefix as Qt, adopting their path scheme.
 * Inotify
 * ECM (required version >= 5.76.0), Extra CMake Modules., <https://commits.kde.org/extra-cmake-modules>
 * Qt5LinguistTools
 * Qt5Core
 * Threads
 * Procstat
-- Configuring done
-- Generating done
-- Build files have been written to: /home/simon/GIT/kcoreaddons/build
immediate build works
moet zijn
/home/simon/GIT/build/qet-Desktop_Qt_5_15_1_GCC_64bit-Debug/_deps/kcoreaddons-src/src/lib/text/ktexttohtml.cpp
en als ik de code plak?..
works
simon@localhost:~/GIT/qet> cmake .
 * Threads
 * Inotify
 * Qt5Core
 * Qt5LinguistTools
 * Procstat
 * Threads
 * Inotify
 * Qt5Widgets
 * Qt5Core
 * Qt5LinguistTools
 * Qt5UiPlugin
 * Qt5Test
 * Procstat
QT_VERSION_MAJOR   :5
  CMake.
  CMake.
  CMake.
-- Configuring done
-- Generating done
-- Build files have been written to: /home/simon/GIT/qet
59 (edited by De-Backer 2020-12-11 22:16:58)
simon@localhost:~/GIT/qet> make
Scanning dependencies of target SingleApplication_autogen
[  0%] Automatic MOC and UIC for target SingleApplication
[  0%] Built target SingleApplication_autogen
[  0%] Building CXX object _deps/singleapplication-build/CMakeFiles/SingleApplication.dir/SingleApplication_autogen/mocs_compilation.cpp.o
[  0%] Building CXX object _deps/singleapplication-build/CMakeFiles/SingleApplication.dir/singleapplication.cpp.o
[  0%] Building CXX object _deps/singleapplication-build/CMakeFiles/SingleApplication.dir/singleapplication_p.cpp.o
[  0%] Linking CXX static library libSingleApplication.a
Scanning dependencies of target qelectrotech_autogen
[  0%] Automatic MOC and UIC for target qelectrotech
[  0%] Built target qelectrotech_autogen
Scanning dependencies of target KF5CoreAddons_autogen
[  0%] Automatic MOC and UIC for target KF5CoreAddons
[  0%] Built target KF5CoreAddons_autogen
[  0%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/KF5CoreAddons_autogen/mocs_compilation.cpp.o
[  0%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/kaboutdata.cpp.o
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/kaboutdata.cpp: In static member function ‘static QList<KAboutPerson> KAboutData::Private::parseTranslators(const QString&, const QString&)’:
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/kaboutdata.cpp:905:70: let op: ‘QString::KeepEmptyParts’ is deprecated [-Wdeprecated-declarations]
  905 |         emailList = translatorEmail.split(QLatin1Char(','), QString::KeepEmptyParts);
In file included from /usr/include/qt5/QtCore/QString:1,
                 from /home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/kaboutdata.h:17,
                 from /home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/kaboutdata.cpp:13:
/usr/include/qt5/QtCore/qstring.h:604:9: note: declared here
  604 |         KeepEmptyParts Q_DECL_ENUMERATOR_DEPRECATED,
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/kaboutdata.cpp:905:84: let op: ‘QStringList QString::split(QChar, QString::SplitBehavior, Qt::CaseSensitivity) const’ is deprecated: Use Qt::SplitBehavior variant instead [-Wdeprecated-declarations]
/usr/include/qt5/QtCore/qstring.h:615:17: note: declared here
  615 |     QStringList split(QChar sep, SplitBehavior behavior,
[  0%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/kcoreaddons.cpp.o
[  1%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/io/kautosavefile.cpp.o
[  1%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/io/kdirwatch.cpp.o
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/io/kdirwatch.cpp: In memberfunctie ‘KDirWatch::Method KDirWatch::internalMethod() const’:
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/io/kdirwatch.cpp:2018:12: let op: enumeration value ‘FAM’ not handled in switch [-Wswitch]
 2018 |     switch (d->m_preferredMethod) {
[  1%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/io/kfilesystemtype.cpp.o
[  1%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/io/kmessage.cpp.o
[  1%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/io/kprocess.cpp.o
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/io/kprocess.cpp: In memberfunctie ‘int KProcess::pid() const’:
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/io/kprocess.cpp:311:39: let op: ‘Q_PID QProcess::pid() const’ is deprecated: Use processId() instead [-Wdeprecated-declarations]
  311 |     return static_cast<int>(QProcess::pid());
In file included from /usr/include/qt5/QtCore/QProcess:1,
                 from /home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/io/kprocess.h:14,
                 from /home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/io/kprocess_p.h:12,
                 from /home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/io/kprocess.cpp:9:
/usr/include/qt5/QtCore/qprocess.h:237:11: note: declared here
  237 |     Q_PID pid() const;
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/io/kprocess.cpp:311:43: let op: ‘Q_PID QProcess::pid() const’ is deprecated: Use processId() instead [-Wdeprecated-declarations]
[  1%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/io/kbackup.cpp.o
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/io/kbackup.cpp: In functie ‘bool KBackup::backupFile(const QString&, const QString&)’:
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/io/kbackup.cpp:29:54: note: ‘#pragma message: KDE5 TODO: Remove KConfig correctly’
   29 | #pragma message("KDE5 TODO: Remove KConfig correctly")
[  1%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/io/kurlmimedata.cpp.o
[  1%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/io/kfileutils.cpp.o
[  1%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/jobs/kcompositejob.cpp.o
[  1%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/jobs/kjob.cpp.o
[  2%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/jobs/kjobtrackerinterface.cpp.o
[  2%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/jobs/kjobuidelegate.cpp.o
[  2%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/plugin/kpluginfactory.cpp.o
[  2%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/plugin/kpluginloader.cpp.o
[  2%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/plugin/kpluginmetadata.cpp.o
[  2%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/plugin/desktopfileparser.cpp.o
[  2%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/randomness/krandom.cpp.o
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/randomness/krandom.cpp: In functie ‘int KRandom::random()’:
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/randomness/krandom.cpp:40:28: let op: ‘void qsrand(uint)’ is deprecated: use QRandomGenerator instead [-Wdeprecated-declarations]
   40 |             qsrand(getpid());
In file included from /usr/include/qt5/QtCore/qchar.h:43,
                 from /usr/include/qt5/QtCore/qstring.h:49,
                 from /home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/randomness/krandom.h:16,
                 from /home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/randomness/krandom.cpp:11:
/usr/include/qt5/QtCore/qglobal.h:1278:81: note: declared here
 1278 | Q_CORE_EXPORT QT_DEPRECATED_VERSION_X_5_15("use QRandomGenerator instead") void qsrand(uint seed);
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/randomness/krandom.cpp:41:26: let op: ‘int qrand()’ is deprecated: use QRandomGenerator instead [-Wdeprecated-declarations]
   41 |             seed = qrand() ^ time(nullptr) ^ reinterpret_cast<quintptr>(QThread::currentThread());
/usr/include/qt5/QtCore/qglobal.h:1279:80: note: declared here
 1279 | Q_CORE_EXPORT QT_DEPRECATED_VERSION_X_5_15("use QRandomGenerator instead") int qrand();
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/randomness/krandom.cpp:43:20: let op: ‘void qsrand(uint)’ is deprecated: use QRandomGenerator instead [-Wdeprecated-declarations]
   43 |         qsrand(seed);
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/randomness/krandom.cpp:45:18: let op: ‘int qrand()’ is deprecated: use QRandomGenerator instead [-Wdeprecated-declarations]
   45 |     return qrand();
[  2%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/randomness/krandomsequence.cpp.o
[  2%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/text/kmacroexpander.cpp.o
[  2%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/text/kstringhandler.cpp.o
[  3%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/text/ktexttohtml.cpp.o
[  3%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/util/kdelibs4migration.cpp.o
[  3%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/util/kdelibs4configmigrator.cpp.o
[  3%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/util/kformat.cpp.o
[  3%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/util/kformatprivate.cpp.o
[  3%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/util/kosrelease.cpp.o
[  3%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/util/kprocesslist.cpp.o
[  3%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/util/kshell.cpp.o
[  3%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/caching/kshareddatacache.cpp.o
[  3%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/text/kmacroexpander_unix.cpp.o
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/text/kmacroexpander_unix.cpp:35:53: note: ‘#pragma message: TODO: Import these methods into Qt’
   35 | #pragma message("TODO: Import these methods into Qt")
[  3%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/util/klistopenfilesjob_unix.cpp.o
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/util/klistopenfilesjob_unix.cpp: In memberfunctie ‘void KListOpenFilesJobPrivate::lsofFinished(int, QProcess::ExitStatus)’:
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/util/klistopenfilesjob_unix.cpp:59:111: let op: ‘QString::SkipEmptyParts’ is deprecated [-Wdeprecated-declarations]
   59 |         const QVector<QStringRef> pidList = out.splitRef(QRegularExpression(QStringLiteral("\\s+")), QString::SkipEmptyParts);
In file included from /usr/include/qt5/QtCore/qhashfunctions.h:44,
                 from /usr/include/qt5/QtCore/qshareddata.h:48,
                 from /usr/include/qt5/QtCore/QSharedDataPointer:1,
                 from /home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/util/kprocesslist.h:14,
                 from /home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/util/klistopenfilesjob.h:16,
                 from /home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/util/klistopenfilesjob_unix.cpp:12:
/usr/include/qt5/QtCore/qstring.h:605:9: note: declared here
  605 |         SkipEmptyParts Q_DECL_ENUMERATOR_DEPRECATED
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/lib/util/klistopenfilesjob_unix.cpp:59:125: let op: ‘QVector<QStringRef> QString::splitRef(const QRegularExpression&, QString::SplitBehavior) const’ is deprecated: Use Qt::SplitBehavior variant instead [-Wdeprecated-declarations]
/usr/include/qt5/QtCore/qstring.h:630:25: note: declared here
  630 |     QVector<QStringRef> splitRef(const QRegularExpression &sep, SplitBehavior behavior) const;
[  4%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/util/kuser_unix.cpp.o
[  4%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/util/kshell_unix.cpp.o
[  4%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/util/kprocesslist_unix.cpp.o
[  4%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/ECMQmLoader-kcoreaddons5_qt.cpp.o
[  4%] Building CXX object _deps/kcoreaddons-build/src/lib/CMakeFiles/KF5CoreAddons.dir/kcoreaddons_debug.cpp.o
[  4%] Linking CXX shared library ../../../../bin/libKF5CoreAddons.so
[  4%] Built target KF5CoreAddons
Scanning dependencies of target KF5WidgetsAddons_autogen
[  4%] Automatic MOC and UIC for target KF5WidgetsAddons
[  4%] Built target KF5WidgetsAddons_autogen
[  4%] Generating ui_kpassworddialog.h
[  4%] Generating qrc_icons.cpp
[  4%] Generating ui_kdatetimeedit.h
[  4%] Generating ui_knewpassworddialog.h
[  5%] Generating ui_knewpasswordwidget.h
[  5%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/KF5WidgetsAddons_autogen/mocs_compilation.cpp.o
[  5%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kacceleratormanager.cpp.o
[  5%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kanimatedbutton.cpp.o
[  5%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kbusyindicatorwidget.cpp.o
[  5%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kcharselect.cpp.o
[  5%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kcharselectdata.cpp.o
[  5%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kcollapsiblegroupbox.cpp.o
[  5%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kcolorbutton.cpp.o
[  6%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kcolumnresizer.cpp.o
[  6%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kdatecombobox.cpp.o
[  6%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kdatepicker.cpp.o
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kdatepicker.cpp: In memberfunctie ‘void KDatePicker::initWidget(const QDate&)’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kdatepicker.cpp:239:58: let op: ‘QStyle::PM_DefaultLayoutSpacing’ is deprecated [-Wdeprecated-declarations]
  239 |     const int spacingHint = style()->pixelMetric(QStyle::PM_DefaultLayoutSpacing);
In file included from /usr/include/qt5/QtWidgets/qstyleoption.h:54,
                 from /usr/include/qt5/QtWidgets/qabstractitemdelegate.h:45,
                 from /usr/include/qt5/QtWidgets/qcombobox.h:45,
                 from /usr/include/qt5/QtWidgets/QComboBox:1,
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kdatepicker.cpp:28:
/usr/include/qt5/QtWidgets/qstyle.h:543:9: note: declared here
  543 |         PM_DefaultLayoutSpacing Q_DECL_ENUMERATOR_DEPRECATED,
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kdatepicker.cpp: In memberfunctie ‘void KDatePicker::setCloseButton(bool)’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kdatepicker.cpp:635:62: let op: ‘QStyle::PM_DefaultLayoutSpacing’ is deprecated [-Wdeprecated-declarations]
  635 |         const int spacingHint = style()->pixelMetric(QStyle::PM_DefaultLayoutSpacing);
[  6%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kdatetable.cpp.o
[  6%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kdatetimeedit.cpp.o
[  6%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kfontaction.cpp.o
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kfontaction.cpp: In memberfunctie ‘virtual QWidget* KFontAction::createWidget(QWidget*)’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kfontaction.cpp:145:17: note: ‘#pragma message: FIXME: items need to be converted’
  145 | #pragma message "FIXME: items need to be converted"
[  6%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/knewpasswordwidget.cpp.o
[  6%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/fonthelpers.cpp.o
[  6%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kfontsizeaction.cpp.o
[  6%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpopupframe.cpp.o
[  7%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kselectaction.cpp.o
[  7%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/ktimecombobox.cpp.o
[  7%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kdragwidgetdecorator.cpp.o
[  7%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kdualaction.cpp.o
[  7%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kfontchooser.cpp.o
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kfontchooser.cpp: In memberfunctie ‘void KFontChooser::Private::init(const DisplayFlags&, const QStringList&, int, Qt::CheckState*)’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kfontchooser.cpp:180:61: let op: ‘QStyle::PM_DefaultLayoutSpacing’ is deprecated [-Wdeprecated-declarations]
  180 |     const int spacingHint = q->style()->pixelMetric(QStyle::PM_DefaultLayoutSpacing);
                 from /usr/include/qt5/QtWidgets/qabstractitemview.h:47,
                 from /usr/include/qt5/QtWidgets/qlistview.h:44,
                 from /usr/include/qt5/QtWidgets/qlistwidget.h:44,
                 from /usr/include/qt5/QtWidgets/QListWidget:1,
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kfontchooser.cpp:35:
[  7%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kfontchooserdialog.cpp.o
[  7%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kguiitem.cpp.o
[  7%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kled.cpp.o
[  7%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kmessagebox.cpp.o
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kmessagebox.cpp: In functie ‘QDialogButtonBox::StandardButton KMessageBox::createKMessageBox(QDialog*, QDialogButtonBox*, const QIcon&, const QString&, const QStringList&, const QString&, bool*, KMessageBox::Options, const QString&, QMessageBox::Icon)’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kmessagebox.cpp:203:70: let op: ‘QStyle::PM_DefaultLayoutSpacing’ is deprecated [-Wdeprecated-declarations]
  203 |     const int spacingHint = mainWidget->style()->pixelMetric(QStyle::PM_DefaultLayoutSpacing);
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kmessagebox.cpp:30:
[  7%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kmessagebox_p.cpp.o
[  8%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kmultitabbar.cpp.o
[  8%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kstandardguiitem.cpp.o
[  8%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kurllabel.cpp.o
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kurllabel.cpp: In memberfunctie ‘virtual void KUrlLabel::mouseReleaseEvent(QMouseEvent*)’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kurllabel.cpp:124:14: let op: ‘Qt::MidButton’ is deprecated: MidButton is deprecated. Use MiddleButton instead [-Wdeprecated-declarations]
  124 |     case Qt::MidButton:
In file included from /usr/include/qt5/QtGui/qcolor.h:45,
                 from /usr/include/qt5/QtGui/QColor:1,
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kurllabel.h:26,
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kurllabel.cpp:18:
/usr/include/qt5/QtCore/qnamespace.h:132:9: note: declared here
  132 |         MidButton Q_DECL_ENUMERATOR_DEPRECATED_X("MidButton is deprecated. Use MiddleButton instead") = MiddleButton,
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kurllabel.cpp: In memberfunctie ‘virtual void KUrlLabel::enterEvent(QEvent*)’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kurllabel.cpp:284:48: let op: ‘const QPixmap* QLabel::pixmap() const’ is deprecated: Use the other overload which returns QPixmap by-value [-Wdeprecated-declarations]
  284 |     if (!d->alternatePixmap.isNull() && pixmap()) {
In file included from /usr/include/qt5/QtWidgets/QLabel:1,
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kurllabel.h:27,
/usr/include/qt5/QtWidgets/qlabel.h:78:20: note: declared here
   78 |     const QPixmap *pixmap() const; // ### Qt 7: Remove function
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kurllabel.cpp:285:33: let op: ‘const QPixmap* QLabel::pixmap() const’ is deprecated: Use the other overload which returns QPixmap by-value [-Wdeprecated-declarations]
  285 |         d->realPixmap = *pixmap();
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kurllabel.cpp: In memberfunctie ‘virtual void KUrlLabel::leaveEvent(QEvent*)’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kurllabel.cpp:310:48: let op: ‘const QPixmap* QLabel::pixmap() const’ is deprecated: Use the other overload which returns QPixmap by-value [-Wdeprecated-declarations]
  310 |     if (!d->alternatePixmap.isNull() && pixmap()) {
[  8%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kcapacitybar.cpp.o
[  8%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kfontrequester.cpp.o
[  8%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpassworddialog.cpp.o
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kpassworddialog.cpp: In memberfunctie ‘QPixmap KPasswordDialog::pixmap() const’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kpassworddialog.cpp:151:39: let op: ‘const QPixmap* QLabel::pixmap() const’ is deprecated: Use the other overload which returns QPixmap by-value [-Wdeprecated-declarations]
  151 |     return *d->ui.pixmapLabel->pixmap();
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kpassworddialog.cpp:23:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kpassworddialog.cpp: In memberfunctie ‘void KPasswordDialog::addCommentLine(const QString&, const QString&)’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kpassworddialog.cpp:252:69: let op: ‘QStyle::PM_DefaultChildMargin’ is deprecated [-Wdeprecated-declarations]
  252 |                 const int marginHint = style()->pixelMetric(QStyle::PM_DefaultChildMargin);
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kpassworddialog.cpp:22:
/usr/include/qt5/QtWidgets/qstyle.h:542:9: note: declared here
  542 |         PM_DefaultChildMargin Q_DECL_ENUMERATOR_DEPRECATED,
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kpassworddialog.cpp: In memberfunctie ‘void KPasswordDialog::setPrompt(const QString&)’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kpassworddialog.cpp:302:57: let op: ‘QStyle::PM_DefaultChildMargin’ is deprecated [-Wdeprecated-declarations]
  302 |     const int marginHint = style()->pixelMetric(QStyle::PM_DefaultChildMargin);
[  8%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kruler.cpp.o
[  8%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kselector.cpp.o
[  8%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kxyselector.cpp.o
[  8%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kseparator.cpp.o
[  8%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/ksqueezedtextlabel.cpp.o
[  9%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/ktitlewidget.cpp.o
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/ktitlewidget.cpp: In memberfunctie ‘const QPixmap* KTitleWidget::pixmap() const’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/ktitlewidget.cpp:201:34: let op: ‘const QPixmap* QLabel::pixmap() const’ is deprecated: Use the other overload which returns QPixmap by-value [-Wdeprecated-declarations]
  201 |     return d->imageLabel->pixmap();
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/ktitlewidget.cpp:26:
[  9%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/ktoggleaction.cpp.o
[  9%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/ktogglefullscreenaction.cpp.o
[  9%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kviewstateserializer.cpp.o
[  9%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kviewstatemaintainerbase.cpp.o
[  9%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/keditlistwidget.cpp.o
[  9%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kcursor.cpp.o
[  9%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kratingwidget.cpp.o
[  9%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kratingpainter.cpp.o
[  9%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kactionselector.cpp.o
[ 10%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kcolorcombo.cpp.o
[ 10%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/ktoolbarspaceraction.cpp.o
[ 10%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpixmapregionselectordialog.cpp.o
[ 10%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpixmapregionselectorwidget.cpp.o
[ 10%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kactionmenu.cpp.o
[ 10%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/ktoolbarlabelaction.cpp.o
[ 10%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/ktoolbarpopupaction.cpp.o
[ 10%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpagedialog.cpp.o
[ 10%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpagemodel.cpp.o
[ 10%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpageview.cpp.o
[ 11%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpageview_p.cpp.o
[ 11%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpagewidget.cpp.o
[ 11%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpagewidgetmodel.cpp.o
[ 11%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kassistantdialog.cpp.o
[ 11%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kmessagewidget.cpp.o
[ 11%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/knewpassworddialog.cpp.o
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/knewpassworddialog.cpp: In memberfunctie ‘QPixmap KNewPasswordDialog::pixmap() const’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/knewpassworddialog.cpp:144:37: let op: ‘const QPixmap* QLabel::pixmap() const’ is deprecated: Use the other overload which returns QPixmap by-value [-Wdeprecated-declarations]
  144 |     return *d->ui.labelIcon->pixmap();
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-build/src/ui_knewpassworddialog.h:17,
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/knewpassworddialog.cpp:31:
[ 11%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/lineediturldropeventfilter.cpp.o
[ 11%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpasswordlineedit.cpp.o
[ 11%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpixmapsequence.cpp.o
[ 11%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpixmapsequenceoverlaypainter.cpp.o
[ 12%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kpixmapsequencewidget.cpp.o
[ 12%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kmimetypechooser.cpp.o
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kmimetypechooser.cpp: In memberfunctie ‘void KMimeTypeChooserPrivate::_k_editMimeType()’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/kmimetypechooser.cpp:273:100: note: ‘#pragma message: KF5 TODO: use QFileSystemWatcher to be told when keditfiletype changed a mimetype’
  273 | #pragma message("KF5 TODO: use QFileSystemWatcher to be told when keditfiletype changed a mimetype")
[ 12%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kmimetypeeditor.cpp.o
[ 12%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/common_helpers.cpp.o
[ 12%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/ksplittercollapserbutton.cpp.o
[ 12%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/kstyleextensions.cpp.o
[ 12%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/ktooltipwidget.cpp.o
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/ktooltipwidget.cpp: In memberfunctie ‘void KToolTipWidget::showBelow(const QRect&, QWidget*, QWindow*)’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/ktooltipwidget.cpp:183:51: let op: ‘QStyle::PM_DefaultTopLevelMargin’ is deprecated [-Wdeprecated-declarations]
  183 |         2 * content->style()->pixelMetric(QStyle::PM_DefaultTopLevelMargin),
In file included from /usr/include/qt5/QtWidgets/qstylepainter.h:45,
                 from /usr/include/qt5/QtWidgets/QStylePainter:1,
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/ktooltipwidget.cpp:26:
/usr/include/qt5/QtWidgets/qstyle.h:541:9: note: declared here
  541 |         PM_DefaultTopLevelMargin Q_DECL_ENUMERATOR_DEPRECATED,
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/src/ktooltipwidget.cpp:184:51: let op: ‘QStyle::PM_DefaultTopLevelMargin’ is deprecated [-Wdeprecated-declarations]
  184 |         2 * content->style()->pixelMetric(QStyle::PM_DefaultTopLevelMargin)};
[ 12%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/ECMQmLoader-kwidgetsaddons5_qt.cpp.o
[ 12%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/qrc_icons.cpp.o
[ 12%] Building CXX object _deps/kwidgetsaddons-build/src/CMakeFiles/KF5WidgetsAddons.dir/loggingcategory.cpp.o
[ 13%] Linking CXX shared library ../../../bin/libKF5WidgetsAddons.so
[ 13%] Built target KF5WidgetsAddons
Scanning dependencies of target pugixml-shared
[ 13%] Building CXX object _deps/pugixml-build/CMakeFiles/pugixml-shared.dir/src/pugixml.cpp.o
[ 13%] Linking CXX shared library libpugixml.so
[ 13%] Built target pugixml-shared
[ 13%] Automatic RCC for qelectrotech.qrc
[ 13%] Generating lang/qet_ar.qm
Updating 'lang/qet_ar.qm'...
    Generated 1598 translation(s) (1386 finished and 212 unfinished)
    Ignored 668 untranslated source text(s)
[ 13%] Generating lang/qet_be.qm
Updating 'lang/qet_be.qm'...
    Generated 2259 translation(s) (2240 finished and 19 unfinished)
    Ignored 7 untranslated source text(s)
[ 13%] Generating lang/qet_ca.qm
Updating 'lang/qet_ca.qm'...
    Generated 1406 translation(s) (1165 finished and 241 unfinished)
    Ignored 860 untranslated source text(s)
[ 13%] Generating lang/qet_cs.qm
Updating 'lang/qet_cs.qm'...
    Generated 2256 translation(s) (2237 finished and 19 unfinished)
    Ignored 10 untranslated source text(s)
[ 14%] Generating lang/qet_da.qm
Updating 'lang/qet_da.qm'...
    Generated 2158 translation(s) (2158 finished and 0 unfinished)
    Ignored 108 untranslated source text(s)
[ 15%] Generating lang/qet_de.qm
Updating 'lang/qet_de.qm'...
    Generated 2266 translation(s) (2266 finished and 0 unfinished)
[ 16%] Generating lang/qet_el.qm
Updating 'lang/qet_el.qm'...
    Generated 1961 translation(s) (1960 finished and 1 unfinished)
    Ignored 305 untranslated source text(s)
[ 16%] Generating lang/qet_en.qm
Updating 'lang/qet_en.qm'...
[ 16%] Generating lang/qet_es.qm
Updating 'lang/qet_es.qm'...
    Generated 1811 translation(s) (1674 finished and 137 unfinished)
    Ignored 455 untranslated source text(s)
[ 16%] Generating lang/qet_fi.qm
Updating 'lang/qet_fi.qm'...
    Generated 0 translation(s) (0 finished and 0 unfinished)
    Ignored 1605 untranslated source text(s)
[ 16%] Generating lang/qet_fr.qm
Updating 'lang/qet_fr.qm'...
    Generated 1986 translation(s) (1986 finished and 0 unfinished)
    Ignored 280 untranslated source text(s)
[ 16%] Generating lang/qet_hr.qm
Updating 'lang/qet_hr.qm'...
    Generated 779 translation(s) (597 finished and 182 unfinished)
    Ignored 1487 untranslated source text(s)
[ 16%] Generating lang/qet_hu.qm
Updating 'lang/qet_hu.qm'...
[ 16%] Generating lang/qet_it.qm
Updating 'lang/qet_it.qm'...
    Generated 2228 translation(s) (1589 finished and 639 unfinished)
    Ignored 38 untranslated source text(s)
[ 16%] Generating lang/qet_ja.qm
Updating 'lang/qet_ja.qm'...
    Generated 1932 translation(s) (1882 finished and 50 unfinished)
    Ignored 334 untranslated source text(s)
[ 16%] Generating lang/qet_mn.qm
Updating 'lang/qet_mn.qm'...
    Ignored 2266 untranslated source text(s)
[ 16%] Generating lang/qet_nb.qm
Updating 'lang/qet_nb.qm'...
    Generated 2186 translation(s) (2122 finished and 64 unfinished)
    Ignored 80 untranslated source text(s)
[ 16%] Generating lang/qet_nl.qm
Updating 'lang/qet_nl.qm'...
[ 16%] Generating lang/qet_no.qm
Updating 'lang/qet_no.qm'...
    Ignored 1371 untranslated source text(s)
[ 16%] Generating lang/qet_pl.qm
Updating 'lang/qet_pl.qm'...
    Generated 2200 translation(s) (2148 finished and 52 unfinished)
    Ignored 66 untranslated source text(s)
[ 16%] Generating lang/qet_pt.qm
Updating 'lang/qet_pt.qm'...
    Generated 832 translation(s) (599 finished and 233 unfinished)
    Ignored 1434 untranslated source text(s)
[ 16%] Generating lang/qet_pt_br.qm
Updating 'lang/qet_pt_br.qm'...
[ 16%] Generating lang/qet_ro.qm
Updating 'lang/qet_ro.qm'...
    Generated 1112 translation(s) (853 finished and 259 unfinished)
    Ignored 1154 untranslated source text(s)
[ 16%] Generating lang/qet_ru.qm
Updating 'lang/qet_ru.qm'...
    Generated 1383 translation(s) (1182 finished and 201 unfinished)
    Ignored 883 untranslated source text(s)
[ 16%] Generating lang/qet_sk.qm
Updating 'lang/qet_sk.qm'...
[ 16%] Generating lang/qet_sl.qm
Updating 'lang/qet_sl.qm'...
[ 16%] Generating lang/qet_sr.qm
Updating 'lang/qet_sr.qm'...
[ 16%] Generating lang/qet_tr.qm
Updating 'lang/qet_tr.qm'...
    Generated 1816 translation(s) (1688 finished and 128 unfinished)
    Ignored 450 untranslated source text(s)
[ 16%] Generating lang/qet_zh.qm
Updating 'lang/qet_zh.qm'...
[ 16%] Building CXX object CMakeFiles/qelectrotech.dir/qelectrotech_autogen/mocs_compilation.cpp.o
[ 17%] Building CXX object CMakeFiles/qelectrotech.dir/sources/borderproperties.cpp.o
[ 17%] Building CXX object CMakeFiles/qelectrotech.dir/sources/bordertitleblock.cpp.o
[ 17%] Building CXX object CMakeFiles/qelectrotech.dir/sources/conductorautonumerotation.cpp.o
[ 17%] Building CXX object CMakeFiles/qelectrotech.dir/sources/conductornumexport.cpp.o
[ 17%] Building CXX object CMakeFiles/qelectrotech.dir/sources/conductorprofile.cpp.o
[ 17%] Building CXX object CMakeFiles/qelectrotech.dir/sources/conductorproperties.cpp.o
[ 17%] Building CXX object CMakeFiles/qelectrotech.dir/sources/conductorsegment.cpp.o
[ 17%] Building CXX object CMakeFiles/qelectrotech.dir/sources/configdialog.cpp.o
[ 17%] Building CXX object CMakeFiles/qelectrotech.dir/sources/configpages.cpp.o
[ 17%] Building CXX object CMakeFiles/qelectrotech.dir/sources/createdxf.cpp.o
[ 18%] Building CXX object CMakeFiles/qelectrotech.dir/sources/diagramcommands.cpp.o
[ 18%] Building CXX object CMakeFiles/qelectrotech.dir/sources/diagramcontent.cpp.o
[ 18%] Building CXX object CMakeFiles/qelectrotech.dir/sources/diagramcontext.cpp.o
[ 18%] Building CXX object CMakeFiles/qelectrotech.dir/sources/diagram.cpp.o
[ 18%] Building CXX object CMakeFiles/qelectrotech.dir/sources/diagramposition.cpp.o
[ 18%] Building CXX object CMakeFiles/qelectrotech.dir/sources/diagramview.cpp.o
[ 18%] Building CXX object CMakeFiles/qelectrotech.dir/sources/elementdialog.cpp.o
[ 18%] Building CXX object CMakeFiles/qelectrotech.dir/sources/elementprovider.cpp.o
[ 18%] Building CXX object CMakeFiles/qelectrotech.dir/sources/elementscategoryeditor.cpp.o
[ 18%] Building CXX object CMakeFiles/qelectrotech.dir/sources/elementscollectioncache.cpp.o
[ 18%] Building CXX object CMakeFiles/qelectrotech.dir/sources/elementsmover.cpp.o
[ 19%] Building CXX object CMakeFiles/qelectrotech.dir/sources/elementspanel.cpp.o
[ 19%] Building CXX object CMakeFiles/qelectrotech.dir/sources/elementspanelwidget.cpp.o
[ 19%] Building CXX object CMakeFiles/qelectrotech.dir/sources/elementtextpattern.cpp.o
[ 19%] Building CXX object CMakeFiles/qelectrotech.dir/sources/elementtextsmover.cpp.o
[ 19%] Building CXX object CMakeFiles/qelectrotech.dir/sources/exportdialog.cpp.o
[ 19%] Building CXX object CMakeFiles/qelectrotech.dir/sources/exportproperties.cpp.o
[ 19%] Building CXX object CMakeFiles/qelectrotech.dir/sources/exportpropertieswidget.cpp.o
[ 19%] Building CXX object CMakeFiles/qelectrotech.dir/sources/genericpanel.cpp.o
[ 19%] Building CXX object CMakeFiles/qelectrotech.dir/sources/machine_info.cpp.o
[ 19%] Building CXX object CMakeFiles/qelectrotech.dir/sources/main.cpp.o
man building is slow
[ 20%] Building CXX object CMakeFiles/qelectrotech.dir/sources/newelementwizard.cpp.o
[ 20%] Building CXX object CMakeFiles/qelectrotech.dir/sources/projectconfigpages.cpp.o
[ 20%] Building CXX object CMakeFiles/qelectrotech.dir/sources/projectview.cpp.o
[ 20%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetapp.cpp.o
[ 20%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetarguments.cpp.o
[ 20%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qet.cpp.o
[ 20%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetdiagrameditor.cpp.o
[ 20%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qeticons.cpp.o
[ 20%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetinformation.cpp.o
[ 20%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetmainwindow.cpp.o
[ 21%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetmessagebox.cpp.o
[ 21%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetproject.cpp.o
[ 21%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetregexpvalidator.cpp.o
[ 21%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetresult.cpp.o
[ 21%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetxml.cpp.o
[ 21%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qfilenameedit.cpp.o
[ 21%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qgimanager.cpp.o
[ 21%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qtextorientationspinboxwidget.cpp.o
[ 21%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qtextorientationwidget.cpp.o
[ 21%] Building CXX object CMakeFiles/qelectrotech.dir/sources/recentfiles.cpp.o
[ 22%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblockcell.cpp.o
[ 22%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblockproperties.cpp.o
[ 22%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblocktemplate.cpp.o
[ 22%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblocktemplaterenderer.cpp.o
[ 22%] Building CXX object CMakeFiles/qelectrotech.dir/sources/autoNum/assignvariables.cpp.o
[ 22%] Building CXX object CMakeFiles/qelectrotech.dir/sources/autoNum/numerotationcontextcommands.cpp.o
[ 22%] Building CXX object CMakeFiles/qelectrotech.dir/sources/autoNum/numerotationcontext.cpp.o
[ 22%] Building CXX object CMakeFiles/qelectrotech.dir/sources/autoNum/ui/autonumberingdockwidget.cpp.o
[ 22%] Building CXX object CMakeFiles/qelectrotech.dir/sources/autoNum/ui/autonumberingmanagementw.cpp.o
[ 22%] Building CXX object CMakeFiles/qelectrotech.dir/sources/autoNum/ui/folioautonumbering.cpp.o
[ 22%] Building CXX object CMakeFiles/qelectrotech.dir/sources/autoNum/ui/formulaautonumberingw.cpp.o
[ 23%] Building CXX object CMakeFiles/qelectrotech.dir/sources/autoNum/ui/numparteditorw.cpp.o
[ 23%] Building CXX object CMakeFiles/qelectrotech.dir/sources/autoNum/ui/selectautonumw.cpp.o
[ 23%] Building CXX object CMakeFiles/qelectrotech.dir/sources/dataBase/projectdatabase.cpp.o
[ 23%] Building CXX object CMakeFiles/qelectrotech.dir/sources/dataBase/ui/elementquerywidget.cpp.o
[ 23%] Building CXX object CMakeFiles/qelectrotech.dir/sources/dataBase/ui/summaryquerywidget.cpp.o
[ 23%] Building CXX object CMakeFiles/qelectrotech.dir/sources/diagramevent/diagrameventaddelement.cpp.o
[ 23%] Building CXX object CMakeFiles/qelectrotech.dir/sources/diagramevent/diagrameventaddimage.cpp.o
[ 23%] Building CXX object CMakeFiles/qelectrotech.dir/sources/diagramevent/diagrameventaddshape.cpp.o
[ 23%] Building CXX object CMakeFiles/qelectrotech.dir/sources/diagramevent/diagrameventaddtext.cpp.o
[ 23%] Building CXX object CMakeFiles/qelectrotech.dir/sources/diagramevent/diagrameventinterface.cpp.o
[ 24%] Building CXX object CMakeFiles/qelectrotech.dir/sources/dvevent/dveventinterface.cpp.o
[ 24%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/arceditor.cpp.o
[ 24%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/editorcommands.cpp.o
[ 24%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/elementitemeditor.cpp.o
[ 24%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/elementprimitivedecorator.cpp.o
[ 24%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/elementscene.cpp.o
[ 24%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/elementview.cpp.o
[ 24%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/qetelementeditor.cpp.o
[ 24%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/styleeditor.cpp.o
[ 24%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/terminaleditor.cpp.o
[ 25%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/esevent/eseventaddarc.cpp.o
[ 25%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/esevent/eseventadddynamictextfield.cpp.o
[ 25%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/esevent/eseventaddellipse.cpp.o
[ 25%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/esevent/eseventaddline.cpp.o
[ 25%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/esevent/eseventaddpolygon.cpp.o
[ 25%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/esevent/eseventaddrect.cpp.o
[ 25%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/esevent/eseventaddterminal.cpp.o
[ 25%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/esevent/eseventaddtext.cpp.o
[ 25%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/esevent/eseventinterface.cpp.o
[ 25%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/graphicspart/abstractpartellipse.cpp.o
[ 26%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/graphicspart/customelementgraphicpart.cpp.o
[ 26%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/graphicspart/customelementpart.cpp.o
[ 26%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/graphicspart/partarc.cpp.o
[ 26%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/graphicspart/partdynamictextfield.cpp.o
[ 26%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/graphicspart/partellipse.cpp.o
[ 26%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/graphicspart/partline.cpp.o
[ 26%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/graphicspart/partpolygon.cpp.o
[ 26%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/graphicspart/partrectangle.cpp.o
[ 26%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/graphicspart/partterminal.cpp.o
[ 26%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/graphicspart/parttext.cpp.o
[ 27%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/ui/dynamictextfieldeditor.cpp.o
[ 27%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/ui/elementpropertieseditorwidget.cpp.o
[ 27%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/ui/ellipseeditor.cpp.o
[ 27%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/ui/lineeditor.cpp.o
[ 27%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/ui/polygoneditor.cpp.o
[ 27%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/ui/rectangleeditor.cpp.o
[ 27%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/ui/texteditor.cpp.o
[ 27%] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/UndoCommand/pastepartscommand.cpp.o
[ 27%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ElementsCollection/elementcollectionhandler.cpp.o
[ 27%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ElementsCollection/elementcollectionitem.cpp.o
[ 27%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ElementsCollection/elementscollectionmodel.cpp.o
[ 28%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ElementsCollection/elementscollectionwidget.cpp.o
[ 28%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ElementsCollection/elementslocation.cpp.o
[ 28%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ElementsCollection/elementstreeview.cpp.o
[ 28%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ElementsCollection/fileelementcollectionitem.cpp.o
[ 28%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ElementsCollection/xmlelementcollection.cpp.o
[ 28%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ElementsCollection/xmlprojectelementcollectionitem.cpp.o
[ 28%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ElementsCollection/ui/renamedialog.cpp.o
[ 28%] Building CXX object CMakeFiles/qelectrotech.dir/sources/factory/elementfactory.cpp.o
[ 28%] Building CXX object CMakeFiles/qelectrotech.dir/sources/factory/elementpicturefactory.cpp.o
[ 28%] Building CXX object CMakeFiles/qelectrotech.dir/sources/factory/propertieseditorfactory.cpp.o
[ 29%] Building CXX object CMakeFiles/qelectrotech.dir/sources/factory/qetgraphicstablefactory.cpp.o
[ 29%] Building CXX object CMakeFiles/qelectrotech.dir/sources/factory/ui/addtabledialog.cpp.o
[ 29%] Building CXX object CMakeFiles/qelectrotech.dir/sources/NameList/nameslist.cpp.o
[ 29%] Building CXX object CMakeFiles/qelectrotech.dir/sources/NameList/ui/namelistdialog.cpp.o
[ 29%] Building CXX object CMakeFiles/qelectrotech.dir/sources/NameList/ui/namelistwidget.cpp.o
[ 29%] Building CXX object CMakeFiles/qelectrotech.dir/sources/print/projectprintwindow.cpp.o
[ 29%] Building CXX object CMakeFiles/qelectrotech.dir/sources/properties/propertiesinterface.cpp.o
[ 29%] Building CXX object CMakeFiles/qelectrotech.dir/sources/properties/reportproperties.cpp.o
[ 29%] Building CXX object CMakeFiles/qelectrotech.dir/sources/properties/terminaldata.cpp.o
[ 29%] Building CXX object CMakeFiles/qelectrotech.dir/sources/properties/xrefproperties.cpp.o
[ 30%] Building CXX object CMakeFiles/qelectrotech.dir/sources/PropertiesEditor/propertieseditordockwidget.cpp.o
[ 30%] Building CXX object CMakeFiles/qelectrotech.dir/sources/PropertiesEditor/propertieseditorwidget.cpp.o
[ 30%] Building CXX object CMakeFiles/qelectrotech.dir/sources/pugixml/pugixml.cpp.o
[ 30%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/conductor.cpp.o
[ 30%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/conductortextitem.cpp.o
[ 30%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/crossrefitem.cpp.o
[ 30%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/diagramimageitem.cpp.o
[ 30%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/diagramtextitem.cpp.o
[ 30%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/dynamicelementtextitem.cpp.o
[ 30%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/element.cpp.o
[ 31%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/elementtextitemgroup.cpp.o
[ 31%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/independenttextitem.cpp.o
[ 31%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/masterelement.cpp.o
[ 31%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/qetgraphicsitem.cpp.o
[ 31%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/qetshapeitem.cpp.o
[ 31%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/qgraphicsitemutility.cpp.o
[ 31%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/reportelement.cpp.o
[ 31%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/simpleelement.cpp.o
[ 31%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/slaveelement.cpp.o
[ 31%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/terminal.cpp.o
[ 32%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/terminalelement.cpp.o
[ 32%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/ViewItem/projectdbmodel.cpp.o
[ 32%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/ViewItem/qetgraphicsheaderitem.cpp.o
[ 32%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/ViewItem/qetgraphicstableitem.cpp.o
[ 32%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/ViewItem/ui/graphicstablepropertieseditor.cpp.o
[ 32%] Building CXX object CMakeFiles/qelectrotech.dir/sources/qetgraphicsitem/ViewItem/ui/projectdbmodelpropertieswidget.cpp.o
[ 32%] Building CXX object CMakeFiles/qelectrotech.dir/sources/QetGraphicsItemModeler/qetgraphicshandleritem.cpp.o
[ 32%] Building CXX object CMakeFiles/qelectrotech.dir/sources/QetGraphicsItemModeler/qetgraphicshandlerutility.cpp.o
[ 32%] Building CXX object CMakeFiles/qelectrotech.dir/sources/QPropertyUndoCommand/qpropertyundocommand.cpp.o
[ 32%] Building CXX object CMakeFiles/qelectrotech.dir/sources/QWidgetAnimation/qwidgetanimation.cpp.o
[ 32%] Building CXX object CMakeFiles/qelectrotech.dir/sources/richtext/richtexteditor.cpp.o
[ 33%] Building CXX object CMakeFiles/qelectrotech.dir/sources/SearchAndReplace/searchandreplaceworker.cpp.o
[ 33%] Building CXX object CMakeFiles/qelectrotech.dir/sources/SearchAndReplace/ui/replaceadvanceddialog.cpp.o
[ 33%] Building CXX object CMakeFiles/qelectrotech.dir/sources/SearchAndReplace/ui/replaceconductordialog.cpp.o
[ 33%] Building CXX object CMakeFiles/qelectrotech.dir/sources/SearchAndReplace/ui/replaceelementdialog.cpp.o
[ 33%] Building CXX object CMakeFiles/qelectrotech.dir/sources/SearchAndReplace/ui/replacefoliowidget.cpp.o
[ 33%] Building CXX object CMakeFiles/qelectrotech.dir/sources/SearchAndReplace/ui/searchandreplacewidget.cpp.o
[ 33%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/dimension.cpp.o
[ 33%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/dimensionwidget.cpp.o
[ 33%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/gridlayoutanimation.cpp.o
[ 33%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/helpercell.cpp.o
[ 34%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/integrationmovetemplateshandler.cpp.o
[ 34%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/qettemplateeditor.cpp.o
[ 34%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/splittedhelpercell.cpp.o
[ 34%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/templatecellsset.cpp.o
[ 34%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/templatecellwidget.cpp.o
[ 34%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/templatecommands.cpp.o
[ 34%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/templatedeleter.cpp.o
[ 34%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/templatelocationchooser.cpp.o
[ 34%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/templatelocation.cpp.o
[ 34%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/templatelocationsaver.cpp.o
[ 35%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/templatelogomanager.cpp.o
[ 35%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/templatescollection.cpp.o
[ 35%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/templateview.cpp.o
[ 35%] Building CXX object CMakeFiles/qelectrotech.dir/sources/titleblock/templatevisualcell.cpp.o
[ 35%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/aboutqetdialog.cpp.o
[ 35%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/abstractelementpropertieseditorwidget.cpp.o
[ 35%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/alignmenttextdialog.cpp.o
[ 35%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/bomexportdialog.cpp.o
[ 35%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/borderpropertieswidget.cpp.o
[ 35%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/compositetexteditdialog.cpp.o
[ 36%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/conductorpropertiesdialog.cpp.o
[ 36%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/conductorpropertieswidget.cpp.o
[ 36%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/configsaveloaderwidget.cpp.o
[ 36%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/diagramcontextwidget.cpp.o
[ 36%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/diagrampropertiesdialog.cpp.o
[ 36%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/diagrampropertieseditordockwidget.cpp.o
[ 36%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/diagramselection.cpp.o
[ 36%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/dialogwaiting.cpp.o
[ 36%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/dynamicelementtextitemeditor.cpp.o
[ 36%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/dynamicelementtextmodel.cpp.o
[ 37%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/elementinfopartwidget.cpp.o
[ 37%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/elementinfowidget.cpp.o
[ 37%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/elementpropertieswidget.cpp.o
[ 37%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/formulaassistantdialog.cpp.o
[ 37%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/imagepropertieswidget.cpp.o
[ 37%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/importelementdialog.cpp.o
[ 37%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/importelementtextpatterndialog.cpp.o
[ 37%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/inditextpropertieswidget.cpp.o
[ 37%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/linksingleelementwidget.cpp.o
[ 37%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/marginseditdialog.cpp.o
[ 37%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/masterpropertieswidget.cpp.o
[ 38%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/multipastedialog.cpp.o
[ 38%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/potentialselectordialog.cpp.o
[ 38%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/projectpropertiesdialog.cpp.o
[ 38%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/reportpropertiewidget.cpp.o
[ 38%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/shapegraphicsitempropertieswidget.cpp.o
[ 38%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/titleblockpropertieswidget.cpp.o
[ 38%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/xrefpropertieswidget.cpp.o
[ 38%] Building CXX object CMakeFiles/qelectrotech.dir/sources/ui/configpage/generalconfigurationpage.cpp.o
[ 38%] Building CXX object CMakeFiles/qelectrotech.dir/sources/undocommand/addelementtextcommand.cpp.o
[ 38%] Building CXX object CMakeFiles/qelectrotech.dir/sources/undocommand/changeelementinformationcommand.cpp.o
[ 39%] Building CXX object CMakeFiles/qelectrotech.dir/sources/undocommand/changetitleblockcommand.cpp.o
[ 39%] Building CXX object CMakeFiles/qelectrotech.dir/sources/undocommand/deleteqgraphicsitemcommand.cpp.o
[ 39%] Building CXX object CMakeFiles/qelectrotech.dir/sources/undocommand/itemmodelcommand.cpp.o
[ 39%] Building CXX object CMakeFiles/qelectrotech.dir/sources/undocommand/linkelementcommand.cpp.o
[ 39%] Building CXX object CMakeFiles/qelectrotech.dir/sources/undocommand/rotateselectioncommand.cpp.o
[ 39%] Building CXX object CMakeFiles/qelectrotech.dir/sources/undocommand/rotatetextscommand.cpp.o
[ 39%] Building CXX object CMakeFiles/qelectrotech.dir/sources/utils/conductorcreator.cpp.o
[ 39%] Building CXX object CMakeFiles/qelectrotech.dir/sources/utils/macosxopenevent.cpp.o
[ 39%] Building CXX object CMakeFiles/qelectrotech.dir/sources/utils/qetutils.cpp.o
[ 39%] Building CXX object CMakeFiles/qelectrotech.dir/qelectrotech_autogen/EWIEGA46WW/qrc_qelectrotech.cpp.o
[ 40%] Linking CXX executable qelectrotech
[ 40%] Built target qelectrotech
Scanning dependencies of target translations_99
[ 40%] Generating zh_CN/kcoreaddons5_qt.qm
[ 40%] Built target translations_99
Scanning dependencies of target translations_97
[ 41%] Generating wa/kcoreaddons5_qt.qm
[ 41%] Built target translations_97
Scanning dependencies of target translations_96
[ 41%] Generating vi/kcoreaddons5_qt.qm
[ 41%] Built target translations_96
Scanning dependencies of target translations_101
[ 41%] Generating zh_TW/kcoreaddons5_qt.qm
[ 41%] Built target translations_101
Scanning dependencies of target translations_94
[ 41%] Generating uz/kcoreaddons5_qt.qm
[ 41%] Built target translations_94
Scanning dependencies of target translations_93
[ 41%] Generating uk/kcoreaddons5_qt.qm
Removed plural forms as the target language has less forms.
If this sounds wrong, possibly the target language is not set or recognized.
[ 41%] Built target translations_93
Scanning dependencies of target translations_92
[ 41%] Generating ug/kcoreaddons5_qt.qm
[ 41%] Built target translations_92
Scanning dependencies of target translations_91
[ 41%] Generating tt/kcoreaddons5_qt.qm
[ 41%] Built target translations_91
Scanning dependencies of target translations_89
[ 41%] Generating th/kcoreaddons5_qt.qm
[ 41%] Built target translations_89
Scanning dependencies of target translations_85
[ 41%] Generating sv/kcoreaddons5_qt.qm
[ 41%] Built target translations_85
Scanning dependencies of target translations_84
[ 41%] Generating sr@latin/kcoreaddons5_qt.qm
[ 41%] Built target translations_84
Scanning dependencies of target translations_78
[ 41%] Generating sk/kcoreaddons5_qt.qm
[ 41%] Built target translations_78
Scanning dependencies of target translations_77
[ 41%] Generating si/kcoreaddons5_qt.qm
[ 41%] Built target translations_77
Scanning dependencies of target translations_82
[ 41%] Generating sr@ijekavian/kcoreaddons5_qt.qm
[ 41%] Built target translations_82
Scanning dependencies of target translations_76
[ 41%] Generating se/kcoreaddons5_qt.qm
[ 41%] Built target translations_76
Scanning dependencies of target translations_90
[ 41%] Generating tr/kcoreaddons5_qt.qm
[ 41%] Built target translations_90
Scanning dependencies of target translations_74
[ 41%] Generating ro/kcoreaddons5_qt.qm
[ 41%] Built target translations_74
Scanning dependencies of target translations_73
[ 41%] Generating pt_BR/kcoreaddons5_qt.qm
[ 41%] Built target translations_73
Scanning dependencies of target translations_71
[ 41%] Generating ps/kcoreaddons5_qt.qm
[ 41%] Built target translations_71
Scanning dependencies of target translations_70
[ 41%] Generating pl/kcoreaddons5_qt.qm
[ 41%] Built target translations_70
Scanning dependencies of target translations_69
[ 41%] Generating pa/kcoreaddons5_qt.qm
[ 41%] Built target translations_69
Scanning dependencies of target translations_68
[ 41%] Generating or/kcoreaddons5_qt.qm
[ 41%] Built target translations_68
Scanning dependencies of target translations_66
[ 41%] Generating nn/kcoreaddons5_qt.qm
[ 41%] Built target translations_66
Scanning dependencies of target translations_100
[ 41%] Generating zh_HK/kcoreaddons5_qt.qm
[ 41%] Built target translations_100
Scanning dependencies of target translations_65
[ 41%] Generating nl/kcoreaddons5_qt.qm
[ 41%] Built target translations_65
Scanning dependencies of target translations_63
[ 41%] Generating nds/kcoreaddons5_qt.qm
[ 41%] Built target translations_63
Scanning dependencies of target translations_72
[ 41%] Generating pt/kcoreaddons5_qt.qm
[ 41%] Built target translations_72
Scanning dependencies of target translations_62
[ 41%] Generating nb/kcoreaddons5_qt.qm
[ 41%] Built target translations_62
Scanning dependencies of target translations_64
[ 41%] Generating ne/kcoreaddons5_qt.qm
[ 41%] Built target translations_64
Scanning dependencies of target translations_61
[ 41%] Generating ms/kcoreaddons5_qt.qm
[ 41%] Built target translations_61
Scanning dependencies of target translations_60
[ 41%] Generating mr/kcoreaddons5_qt.qm
[ 41%] Built target translations_60
Scanning dependencies of target translations_59
[ 41%] Generating ml/kcoreaddons5_qt.qm
[ 41%] Built target translations_59
Scanning dependencies of target translations_25
[ 41%] Generating et/kcoreaddons5_qt.qm
[ 41%] Built target translations_25
Scanning dependencies of target translations_79
[ 42%] Generating sl/kcoreaddons5_qt.qm
[ 42%] Built target translations_79
Scanning dependencies of target translations_24
[ 42%] Generating es/kcoreaddons5_qt.qm
[ 42%] Built target translations_24
Scanning dependencies of target translations_29
[ 42%] Generating fr/kcoreaddons5_qt.qm
[ 42%] Built target translations_29
Scanning dependencies of target translations_39
[ 42%] Generating hr/kcoreaddons5_qt.qm
[ 42%] Built target translations_39
Scanning dependencies of target translations_33
[ 42%] Generating gl/kcoreaddons5_qt.qm
[ 42%] Built target translations_33
Scanning dependencies of target translations_53
[ 42%] Generating ku/kcoreaddons5_qt.qm
[ 42%] Built target translations_53
Scanning dependencies of target translations_17
[ 42%] Generating cy/kcoreaddons5_qt.qm
[ 42%] Built target translations_17
Scanning dependencies of target translations_75
[ 42%] Generating ru/kcoreaddons5_qt.qm
[ 42%] Built target translations_75
Scanning dependencies of target translations_14
[ 43%] Generating crh/kcoreaddons5_qt.qm
[ 43%] Built target translations_14
Scanning dependencies of target translations_55
[ 43%] Generating lt/kcoreaddons5_qt.qm
[ 43%] Built target translations_55
Scanning dependencies of target translations_18
[ 43%] Generating da/kcoreaddons5_qt.qm
[ 43%] Built target translations_18
Scanning dependencies of target translations_13
[ 43%] Generating ca@valencia/kcoreaddons5_qt.qm
[ 43%] Built target translations_13
Scanning dependencies of target translations_58
[ 43%] Generating mk/kcoreaddons5_qt.qm
[ 43%] Built target translations_58
Scanning dependencies of target translations_16
[ 43%] Generating csb/kcoreaddons5_qt.qm
[ 43%] Built target translations_16
Scanning dependencies of target translations_80
[ 43%] Generating sq/kcoreaddons5_qt.qm
[ 43%] Built target translations_80
Scanning dependencies of target translations_35
[ 43%] Generating ha/kcoreaddons5_qt.qm
[ 43%] Built target translations_35
[ 43%] Generating ar/kcoreaddons5_qt.qm
[ 43%] Built target translations_2
[ 43%] Generating be/kcoreaddons5_qt.qm
[ 43%] Generating as/kcoreaddons5_qt.qm
Scanning dependencies of target translations_12
[ 43%] Generating ca/kcoreaddons5_qt.qm
[ 43%] Built target translations_12
[ 43%] Generating bn/kcoreaddons5_qt.qm
Scanning dependencies of target translations_4
[ 43%] Generating ast/kcoreaddons5_qt.qm
[ 43%] Built target translations_4
Scanning dependencies of target translations_43
[ 43%] Generating ia/kcoreaddons5_qt.qm
[ 43%] Built target translations_43
Scanning dependencies of target translations_26
[ 43%] Generating eu/kcoreaddons5_qt.qm
[ 43%] Built target translations_26
Scanning dependencies of target translations_11
[ 43%] Generating bs/kcoreaddons5_qt.qm
[ 43%] Built target translations_11
Scanning dependencies of target translations_42
[ 43%] Generating hy/kcoreaddons5_qt.qm
[ 43%] Built target translations_42
Scanning dependencies of target translations_83
[ 43%] Generating sr@ijekavianlatin/kcoreaddons5_qt.qm
[ 43%] Built target translations_83
Scanning dependencies of target translations_19
[ 43%] Generating de/kcoreaddons5_qt.qm
[ 43%] Built target translations_19
Scanning dependencies of target translations_27
[ 43%] Generating fa/kcoreaddons5_qt.qm
[ 43%] Built target translations_27
[ 43%] Generating br/kcoreaddons5_qt.qm
[ 43%] Built target translations_10
[ 44%] Generating be@latin/kcoreaddons5_qt.qm
[ 44%] Built target translations_6
Scanning dependencies of target translations_87
[ 44%] Generating te/kcoreaddons5_qt.qm
[ 44%] Built target translations_87
Scanning dependencies of target translations_81
[ 44%] Generating sr/kcoreaddons5_qt.qm
[ 44%] Built target translations_81
[ 44%] Generating bn_IN/kcoreaddons5_qt.qm
[ 44%] Built target translations_9
Scanning dependencies of target translations_67
[ 44%] Generating oc/kcoreaddons5_qt.qm
[ 44%] Built target translations_67
Scanning dependencies of target translations_23
[ 45%] Generating eo/kcoreaddons5_qt.qm
[ 45%] Built target translations_23
Scanning dependencies of target translations_51
[ 45%] Generating kn/kcoreaddons5_qt.qm
[ 45%] Built target translations_51
Scanning dependencies of target translations_88
[ 46%] Generating tg/kcoreaddons5_qt.qm
[ 46%] Built target translations_88
[ 46%] Generating af/kcoreaddons5_qt.qm
[ 46%] Built target translations_1
[ 47%] Generating bg/kcoreaddons5_qt.qm
[ 47%] Built target translations_7
Scanning dependencies of target translations_28
[ 47%] Generating fi/kcoreaddons5_qt.qm
[ 47%] Built target translations_28
Scanning dependencies of target translations_30
[ 47%] Generating fy/kcoreaddons5_qt.qm
[ 47%] Built target translations_30
Scanning dependencies of target translations_32
[ 48%] Generating gd/kcoreaddons5_qt.qm
[ 48%] Built target translations_32
Scanning dependencies of target translations_98
[ 48%] Generating xh/kcoreaddons5_qt.qm
[ 48%] Built target translations_98
Scanning dependencies of target translations_56
[ 48%] Generating lv/kcoreaddons5_qt.qm
[ 48%] Built target translations_56
Scanning dependencies of target translations_34
[ 48%] Generating gu/kcoreaddons5_qt.qm
[ 48%] Built target translations_34
Scanning dependencies of target translations_47
[ 48%] Generating ja/kcoreaddons5_qt.qm
[ 48%] Built target translations_47
Scanning dependencies of target translations_36
[ 48%] Generating he/kcoreaddons5_qt.qm
[ 48%] Built target translations_36
Scanning dependencies of target translations_37
[ 48%] Generating hi/kcoreaddons5_qt.qm
[ 48%] Built target translations_37
Scanning dependencies of target translations_45
[ 48%] Generating is/kcoreaddons5_qt.qm
[ 48%] Built target translations_45
Scanning dependencies of target translations_38
[ 48%] Generating hne/kcoreaddons5_qt.qm
[ 48%] Built target translations_38
Scanning dependencies of target translations_31
[ 48%] Generating ga/kcoreaddons5_qt.qm
[ 48%] Built target translations_31
Scanning dependencies of target translations_40
[ 48%] Generating hsb/kcoreaddons5_qt.qm
[ 48%] Built target translations_40
Scanning dependencies of target translations_86
[ 48%] Generating ta/kcoreaddons5_qt.qm
[ 48%] Built target translations_86
Scanning dependencies of target translations_41
[ 49%] Generating hu/kcoreaddons5_qt.qm
[ 49%] Built target translations_41
Scanning dependencies of target translations_44
[ 49%] Generating id/kcoreaddons5_qt.qm
[ 49%] Built target translations_44
Scanning dependencies of target translations_46
[ 49%] Generating it/kcoreaddons5_qt.qm
[ 49%] Built target translations_46
Scanning dependencies of target translations_15
[ 49%] Generating cs/kcoreaddons5_qt.qm
[ 49%] Built target translations_15
Scanning dependencies of target translations_48
[ 49%] Generating ka/kcoreaddons5_qt.qm
[ 49%] Built target translations_48
Scanning dependencies of target translations_57
[ 49%] Generating mai/kcoreaddons5_qt.qm
[ 49%] Built target translations_57
Scanning dependencies of target translations_21
[ 49%] Generating en/kcoreaddons5_qt.qm
[ 49%] Built target translations_21
Scanning dependencies of target translations_49
[ 49%] Generating kk/kcoreaddons5_qt.qm
[ 49%] Built target translations_49
Scanning dependencies of target translations_20
[ 49%] Generating el/kcoreaddons5_qt.qm
[ 49%] Built target translations_20
Scanning dependencies of target translations_50
Re: Qt 6.0 development and qelectrotech
[ 50%] Generating km/kcoreaddons5_qt.qm
[ 50%] Built target translations_50
Scanning dependencies of target translations_95
[ 50%] Generating uz@cyrillic/kcoreaddons5_qt.qm
[ 50%] Built target translations_95
Scanning dependencies of target translations_22
[ 50%] Generating en_GB/kcoreaddons5_qt.qm
[ 50%] Built target translations_22
Scanning dependencies of target translations_52
[ 50%] Generating ko/kcoreaddons5_qt.qm
[ 50%] Built target translations_52
Scanning dependencies of target translations_54
[ 50%] Generating lb/kcoreaddons5_qt.qm
[ 50%] Built target translations_54
Scanning dependencies of target desktoptojson_autogen
[ 50%] Automatic MOC and UIC for target desktoptojson
[ 50%] Built target desktoptojson_autogen
[ 51%] Building CXX object _deps/kcoreaddons-build/src/desktoptojson/CMakeFiles/desktoptojson.dir/desktoptojson_autogen/mocs_compilation.cpp.o
[ 51%] Building CXX object _deps/kcoreaddons-build/src/desktoptojson/CMakeFiles/desktoptojson.dir/main.cpp.o
[ 51%] Building CXX object _deps/kcoreaddons-build/src/desktoptojson/CMakeFiles/desktoptojson.dir/desktoptojson.cpp.o
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/desktoptojson/desktoptojson.cpp: In memberfunctie ‘int DesktopToJson::runMain()’:
/home/simon/GIT/qet/_deps/kcoreaddons-src/src/desktoptojson/desktoptojson.cpp:51:98: note: ‘#pragma message: TODO: make it an error if one of the service type files is invalid or not found’
   51 | #pragma message("TODO: make it an error if one of the service type files is invalid or not found")
[ 51%] Building CXX object _deps/kcoreaddons-build/src/desktoptojson/CMakeFiles/desktoptojson.dir/__/lib/plugin/desktopfileparser.cpp.o
[ 51%] Linking CXX executable ../../../../bin/desktoptojson
[ 51%] Built target desktoptojson
Scanning dependencies of target kdirwatch_inotify_unittest_autogen
[ 51%] Automatic MOC and UIC for target kdirwatch_inotify_unittest
[ 51%] Built target kdirwatch_inotify_unittest_autogen
[ 51%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kdirwatch_inotify_unittest.dir/kdirwatch_inotify_unittest_autogen/mocs_compilation.cpp.o
[ 51%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kdirwatch_inotify_unittest.dir/kdirwatch_unittest.cpp.o
[ 51%] Linking CXX executable ../../../bin/kdirwatch_inotify_unittest
Scanning dependencies of target ktexttohtmltest_autogen
[ 51%] Automatic MOC and UIC for target ktexttohtmltest
[ 51%] Built target ktexttohtmltest_autogen
[ 51%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/ktexttohtmltest.dir/ktexttohtmltest_autogen/mocs_compilation.cpp.o
[ 51%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/ktexttohtmltest.dir/ktexttohtmltest.cpp.o
[ 51%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/ktexttohtmltest.dir/__/__/__/src/lib/text/ktexttohtml.cpp.o
[ 51%] Linking CXX executable ../../../bin/ktexttohtmltest
Scanning dependencies of target kosreleasetest_autogen
[ 51%] Automatic MOC and UIC for target kosreleasetest
[ 51%] Built target kosreleasetest_autogen
[ 51%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kosreleasetest.dir/kosreleasetest_autogen/mocs_compilation.cpp.o
[ 51%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kosreleasetest.dir/kosreleasetest.cpp.o
[ 52%] Linking CXX executable ../../../bin/kosreleasetest
[ 52%] Built target kosreleasetest
Scanning dependencies of target kprocesstest_helper_autogen
[ 52%] Automatic MOC and UIC for target kprocesstest_helper
[ 52%] Built target kprocesstest_helper_autogen
[ 53%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kprocesstest_helper.dir/kprocesstest_helper_autogen/mocs_compilation.cpp.o
[ 53%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kprocesstest_helper.dir/kprocesstest_helper.cpp.o
[ 53%] Linking CXX executable ../../../bin/kprocesstest_helper
[ 53%] Built target kprocesstest_helper
Scanning dependencies of target kdelibs4migrationtest_autogen
[ 53%] Automatic MOC and UIC for target kdelibs4migrationtest
[ 53%] Built target kdelibs4migrationtest_autogen
[ 53%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kdelibs4migrationtest.dir/kdelibs4migrationtest_autogen/mocs_compilation.cpp.o
[ 53%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kdelibs4migrationtest.dir/kdelibs4migrationtest.cpp.o
[ 53%] Linking CXX executable ../../../bin/kdelibs4migrationtest
Scanning dependencies of target kurlmimedatatest_autogen
[ 53%] Automatic MOC and UIC for target kurlmimedatatest
[ 53%] Built target kurlmimedatatest_autogen
[ 53%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kurlmimedatatest.dir/kurlmimedatatest_autogen/mocs_compilation.cpp.o
[ 53%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kurlmimedatatest.dir/kurlmimedatatest.cpp.o
[ 53%] Linking CXX executable ../../../bin/kurlmimedatatest
Scanning dependencies of target kdirwatch_stat_unittest_autogen
[ 53%] Automatic MOC and UIC for target kdirwatch_stat_unittest
[ 53%] Built target kdirwatch_stat_unittest_autogen
[ 53%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kdirwatch_stat_unittest.dir/kdirwatch_stat_unittest_autogen/mocs_compilation.cpp.o
[ 53%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kdirwatch_stat_unittest.dir/kdirwatch_unittest.cpp.o
[ 53%] Linking CXX executable ../../../bin/kdirwatch_stat_unittest
Scanning dependencies of target kjobtest_autogen
[ 53%] Automatic MOC and UIC for target kjobtest
[ 53%] Built target kjobtest_autogen
[ 53%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kjobtest.dir/kjobtest_autogen/mocs_compilation.cpp.o
[ 53%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kjobtest.dir/kjobtest.cpp.o
[ 53%] Linking CXX executable ../../../bin/kjobtest
Scanning dependencies of target kstringhandlertest_autogen
[ 54%] Automatic MOC and UIC for target kstringhandlertest
[ 54%] Built target kstringhandlertest_autogen
[ 54%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kstringhandlertest.dir/kstringhandlertest_autogen/mocs_compilation.cpp.o
[ 54%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kstringhandlertest.dir/kstringhandlertest.cpp.o
[ 54%] Linking CXX executable ../../../bin/kstringhandlertest
Scanning dependencies of target unversionedplugin_autogen
[ 54%] Automatic MOC and UIC for target unversionedplugin
[ 54%] Built target unversionedplugin_autogen
[ 54%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/unversionedplugin.dir/unversionedplugin_autogen/mocs_compilation.cpp.o
[ 54%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/unversionedplugin.dir/unversionedplugin.cpp.o
[ 54%] Linking CXX shared module ../../../bin/unversionedplugin.so
Scanning dependencies of target multiplugin_autogen
[ 54%] Automatic MOC and UIC for target multiplugin
[ 54%] Built target multiplugin_autogen
[ 54%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/multiplugin.dir/multiplugin_autogen/mocs_compilation.cpp.o
[ 54%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/multiplugin.dir/multiplugin.cpp.o
[ 54%] Linking CXX shared module ../../../bin/multiplugin.so
Scanning dependencies of target kformattest_autogen
[ 54%] Automatic MOC and UIC for target kformattest
[ 54%] Built target kformattest_autogen
[ 54%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kformattest.dir/kformattest_autogen/mocs_compilation.cpp.o
[ 54%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kformattest.dir/kformattest.cpp.o
[ 54%] Linking CXX executable ../../../bin/kformattest
Scanning dependencies of target kaboutdatatest_autogen
[ 54%] Automatic MOC and UIC for target kaboutdatatest
[ 54%] Built target kaboutdatatest_autogen
[ 54%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kaboutdatatest.dir/kaboutdatatest_autogen/mocs_compilation.cpp.o
[ 54%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kaboutdatatest.dir/kaboutdatatest.cpp.o
[ 54%] Linking CXX executable ../../../bin/kaboutdatatest
Scanning dependencies of target kdirwatch_qfswatch_unittest_autogen
[ 54%] Automatic MOC and UIC for target kdirwatch_qfswatch_unittest
[ 54%] Built target kdirwatch_qfswatch_unittest_autogen
[ 54%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kdirwatch_qfswatch_unittest.dir/kdirwatch_qfswatch_unittest_autogen/mocs_compilation.cpp.o
[ 55%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kdirwatch_qfswatch_unittest.dir/kdirwatch_unittest.cpp.o
[ 55%] Linking CXX executable ../../../bin/kdirwatch_qfswatch_unittest
[ 55%] Built target kdirwatch_qfswatch_unittest
Scanning dependencies of target jsonplugin2_autogen
[ 55%] Automatic MOC and UIC for target jsonplugin2
[ 55%] Built target jsonplugin2_autogen
[ 55%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/jsonplugin2.dir/jsonplugin2_autogen/mocs_compilation.cpp.o
[ 55%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/jsonplugin2.dir/jsonplugin2.cpp.o
[ 55%] Linking CXX shared module ../../../bin/jsonplugin2.so
Scanning dependencies of target kusertest_autogen
[ 55%] Automatic MOC and UIC for target kusertest
[ 55%] Built target kusertest_autogen
[ 56%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kusertest.dir/kusertest_autogen/mocs_compilation.cpp.o
[ 56%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kusertest.dir/kusertest.cpp.o
[ 56%] Linking CXX executable ../../../bin/kusertest
[ 56%] Built target kusertest
Scanning dependencies of target versionedplugin_autogen
[ 57%] Automatic MOC and UIC for target versionedplugin
[ 57%] Built target versionedplugin_autogen
[ 57%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/versionedplugin.dir/versionedplugin_autogen/mocs_compilation.cpp.o
[ 57%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/versionedplugin.dir/versionedplugin.cpp.o
[ 57%] Linking CXX shared module ../../../bin/versionedplugin.so
Scanning dependencies of target jsonplugin_autogen
[ 57%] Automatic MOC and UIC for target jsonplugin
[ 57%] Built target jsonplugin_autogen
[ 57%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/jsonplugin.dir/jsonplugin_autogen/mocs_compilation.cpp.o
[ 57%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/jsonplugin.dir/jsonplugin.cpp.o
[ 57%] Linking CXX shared module ../../../bin/jsonplugin.so
Scanning dependencies of target kprocesstest_autogen
[ 57%] Automatic MOC and UIC for target kprocesstest
[ 57%] Built target kprocesstest_autogen
[ 57%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kprocesstest.dir/kprocesstest_autogen/mocs_compilation.cpp.o
[ 57%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kprocesstest.dir/kprocesstest.cpp.o
[ 57%] Linking CXX executable ../../../bin/kprocesstest
Scanning dependencies of target kfileutilstest_autogen
[ 57%] Automatic MOC and UIC for target kfileutilstest
[ 57%] Built target kfileutilstest_autogen
[ 57%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kfileutilstest.dir/kfileutilstest_autogen/mocs_compilation.cpp.o
[ 58%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kfileutilstest.dir/kfileutilstest.cpp.o
[ 58%] Linking CXX executable ../../../bin/kfileutilstest
[ 58%] Built target kfileutilstest
Scanning dependencies of target kcompositejobtest_autogen
[ 58%] Automatic MOC and UIC for target kcompositejobtest
[ 58%] Built target kcompositejobtest_autogen
[ 58%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kcompositejobtest.dir/kcompositejobtest_autogen/mocs_compilation.cpp.o
[ 58%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kcompositejobtest.dir/kcompositejobtest.cpp.o
[ 58%] Linking CXX executable ../../../bin/kcompositejobtest
Scanning dependencies of target kautosavefiletest_autogen
[ 58%] Automatic MOC and UIC for target kautosavefiletest
[ 58%] Built target kautosavefiletest_autogen
[ 58%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kautosavefiletest.dir/kautosavefiletest_autogen/mocs_compilation.cpp.o
[ 58%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kautosavefiletest.dir/kautosavefiletest.cpp.o
[ 58%] Linking CXX executable ../../../bin/kautosavefiletest
Scanning dependencies of target kpluginloadertest_autogen
[ 58%] Automatic MOC and UIC for target kpluginloadertest
[ 58%] Built target kpluginloadertest_autogen
[ 58%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kpluginloadertest.dir/kpluginloadertest_autogen/mocs_compilation.cpp.o
[ 58%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kpluginloadertest.dir/kpluginloadertest.cpp.o
[ 58%] Linking CXX executable ../../../bin/kpluginloadertest
Scanning dependencies of target kshelltest_autogen
[ 58%] Automatic MOC and UIC for target kshelltest
[ 58%] Built target kshelltest_autogen
[ 58%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kshelltest.dir/kshelltest_autogen/mocs_compilation.cpp.o
[ 58%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kshelltest.dir/kshelltest.cpp.o
[ 59%] Linking CXX executable ../../../bin/kshelltest
[ 59%] Built target kshelltest
Scanning dependencies of target kpluginmetadatatest_autogen
[ 59%] Automatic MOC and UIC for target kpluginmetadatatest
[ 59%] Built target kpluginmetadatatest_autogen
[ 59%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kpluginmetadatatest.dir/kpluginmetadatatest_autogen/mocs_compilation.cpp.o
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kpluginmetadatatest.dir/kpluginmetadatatest.cpp.o
[ 60%] Linking CXX executable ../../../bin/kpluginmetadatatest
[ 60%] Built target kpluginmetadatatest
Scanning dependencies of target alwaysunloadplugin_autogen
[ 60%] Automatic MOC and UIC for target alwaysunloadplugin
[ 60%] Built target alwaysunloadplugin_autogen
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/alwaysunloadplugin.dir/alwaysunloadplugin_autogen/mocs_compilation.cpp.o
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/alwaysunloadplugin.dir/alwaysunloadplugin.cpp.o
[ 60%] Linking CXX shared module ../../../bin/alwaysunloadplugin.so
Scanning dependencies of target krandomtest_autogen
[ 60%] Automatic MOC and UIC for target krandomtest
[ 60%] Built target krandomtest_autogen
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/krandomtest.dir/krandomtest_autogen/mocs_compilation.cpp.o
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/krandomtest.dir/krandomtest.cpp.o
[ 60%] Linking CXX executable ../../../bin/krandomtest
Scanning dependencies of target kshareddatacachetest_autogen
[ 60%] Automatic MOC and UIC for target kshareddatacachetest
[ 60%] Built target kshareddatacachetest_autogen
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kshareddatacachetest.dir/kshareddatacachetest_autogen/mocs_compilation.cpp.o
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kshareddatacachetest.dir/kshareddatacachetest.cpp.o
[ 60%] Linking CXX executable ../../../bin/kshareddatacachetest
Scanning dependencies of target kpluginfactorytest_autogen
[ 60%] Automatic MOC and UIC for target kpluginfactorytest
[ 60%] Built target kpluginfactorytest_autogen
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kpluginfactorytest.dir/kpluginfactorytest_autogen/mocs_compilation.cpp.o
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kpluginfactorytest.dir/kpluginfactorytest.cpp.o
[ 60%] Linking CXX executable ../../../bin/kpluginfactorytest
Scanning dependencies of target klistopenfilesjobtest_unix_autogen
[ 60%] Automatic MOC and UIC for target klistopenfilesjobtest_unix
[ 60%] Built target klistopenfilesjobtest_unix_autogen
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/klistopenfilesjobtest_unix.dir/klistopenfilesjobtest_unix_autogen/mocs_compilation.cpp.o
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/klistopenfilesjobtest_unix.dir/klistopenfilesjobtest_unix.cpp.o
[ 60%] Linking CXX executable ../../../bin/klistopenfilesjobtest_unix
Scanning dependencies of target kdelibs4configmigratortest_autogen
[ 60%] Automatic MOC and UIC for target kdelibs4configmigratortest
[ 60%] Built target kdelibs4configmigratortest_autogen
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kdelibs4configmigratortest.dir/kdelibs4configmigratortest_autogen/mocs_compilation.cpp.o
[ 60%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kdelibs4configmigratortest.dir/kdelibs4configmigratortest.cpp.o
[ 61%] Linking CXX executable ../../../bin/kdelibs4configmigratortest
[ 61%] Built target kdelibs4configmigratortest
Scanning dependencies of target kaboutdataapplicationdatatest_autogen
[ 61%] Automatic MOC and UIC for target kaboutdataapplicationdatatest
[ 61%] Built target kaboutdataapplicationdatatest_autogen
[ 62%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kaboutdataapplicationdatatest.dir/kaboutdataapplicationdatatest_autogen/mocs_compilation.cpp.o
[ 62%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kaboutdataapplicationdatatest.dir/kaboutdataapplicationdatatest.cpp.o
[ 62%] Linking CXX executable ../../../bin/kaboutdataapplicationdatatest
[ 62%] Built target kaboutdataapplicationdatatest
Scanning dependencies of target kprocesslisttest_autogen
[ 62%] Automatic MOC and UIC for target kprocesslisttest
[ 62%] Built target kprocesslisttest_autogen
[ 62%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kprocesslisttest.dir/kprocesslisttest_autogen/mocs_compilation.cpp.o
[ 62%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/kprocesslisttest.dir/kprocesslisttest.cpp.o
[ 62%] Linking CXX executable ../../../bin/kprocesslisttest
Scanning dependencies of target desktoptojsontest_autogen
[ 62%] Automatic MOC and UIC for target desktoptojsontest
[ 62%] Built target desktoptojsontest_autogen
[ 62%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/desktoptojsontest.dir/desktoptojsontest_autogen/mocs_compilation.cpp.o
[ 62%] Building CXX object _deps/kcoreaddons-build/autotests/CMakeFiles/desktoptojsontest.dir/desktoptojsontest.cpp.o
[ 62%] Linking CXX executable ../../../bin/desktoptojsontest
Scanning dependencies of target faceicontest_autogen
[ 62%] Automatic MOC and UIC for target faceicontest
[ 62%] Built target faceicontest_autogen
[ 63%] Building CXX object _deps/kcoreaddons-build/tests/CMakeFiles/faceicontest.dir/faceicontest_autogen/mocs_compilation.cpp.o
[ 63%] Building CXX object _deps/kcoreaddons-build/tests/CMakeFiles/faceicontest.dir/faceicontest.cpp.o
[ 63%] Linking CXX executable ../../../bin/faceicontest
[ 63%] Built target faceicontest
Scanning dependencies of target kdirwatchtest_gui_autogen
[ 64%] Automatic MOC and UIC for target kdirwatchtest_gui
[ 64%] Built target kdirwatchtest_gui_autogen
[ 64%] Building CXX object _deps/kcoreaddons-build/tests/CMakeFiles/kdirwatchtest_gui.dir/kdirwatchtest_gui_autogen/mocs_compilation.cpp.o
[ 64%] Building CXX object _deps/kcoreaddons-build/tests/CMakeFiles/kdirwatchtest_gui.dir/kdirwatchtest_gui.cpp.o
[ 64%] Linking CXX executable ../../../bin/kdirwatchtest_gui
Scanning dependencies of target translations_198
[ 64%] Generating xh/kwidgetsaddons5_qt.qm
[ 64%] Built target translations_198
Scanning dependencies of target translations_196
[ 64%] Generating vi/kwidgetsaddons5_qt.qm
[ 64%] Built target translations_196
Scanning dependencies of target translations_195
[ 65%] Generating uz@cyrillic/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_195
Scanning dependencies of target translations_194
[ 65%] Generating uz/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_194
Scanning dependencies of target translations_193
[ 65%] Generating uk/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_193
Scanning dependencies of target translations_191
[ 65%] Generating tt/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_191
Scanning dependencies of target translations_189
[ 65%] Generating th/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_189
Scanning dependencies of target translations_185
[ 65%] Generating sv/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_185
Scanning dependencies of target translations_183
[ 65%] Generating sr@ijekavianlatin/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_183
Scanning dependencies of target translations_182
[ 65%] Generating sr@ijekavian/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_182
Scanning dependencies of target translations_180
[ 65%] Generating sq/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_180
Scanning dependencies of target translations_179
[ 65%] Generating sl/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_179
Scanning dependencies of target translations_175
[ 65%] Generating ru/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_175
Scanning dependencies of target translations_178
[ 65%] Generating sk/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_178
Scanning dependencies of target translations_174
[ 65%] Generating ro/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_174
Scanning dependencies of target translations_173
[ 65%] Generating pt_BR/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_173
Scanning dependencies of target translations_172
[ 65%] Generating pt/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_172
Scanning dependencies of target translations_169
[ 65%] Generating pa/kwidgetsaddons5_qt.qm
[ 65%] Built target translations_169
Scanning dependencies of target translations_177
[ 66%] Generating si/kwidgetsaddons5_qt.qm
[ 66%] Built target translations_177
Scanning dependencies of target translations_167
[ 66%] Generating oc/kwidgetsaddons5_qt.qm
[ 66%] Built target translations_167
Scanning dependencies of target translations_184
[ 66%] Generating sr@latin/kwidgetsaddons5_qt.qm
[ 66%] Built target translations_184
Scanning dependencies of target translations_166
[ 66%] Generating nn/kwidgetsaddons5_qt.qm
[ 66%] Built target translations_166
Scanning dependencies of target translations_164
[ 66%] Generating ne/kwidgetsaddons5_qt.qm
[ 66%] Built target translations_164
Scanning dependencies of target translations_168
[ 67%] Generating or/kwidgetsaddons5_qt.qm
[ 67%] Built target translations_168
Scanning dependencies of target translations_162
[ 67%] Generating nb/kwidgetsaddons5_qt.qm
[ 67%] Built target translations_162
Scanning dependencies of target translations_161
[ 67%] Generating ms/kwidgetsaddons5_qt.qm
[ 67%] Built target translations_161
Scanning dependencies of target translations_130
[ 68%] Generating fr/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_130
Scanning dependencies of target translations_188
[ 68%] Generating tg/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_188
Scanning dependencies of target translations_187
[ 68%] Generating te/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_187
Scanning dependencies of target translations_126
[ 68%] Generating et/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_126
Scanning dependencies of target translations_190
[ 68%] Generating tr/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_190
Scanning dependencies of target translations_124
[ 68%] Generating eo/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_124
Scanning dependencies of target translations_125
[ 68%] Generating es/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_125
Scanning dependencies of target translations_123
[ 68%] Generating en_GB/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_123
Scanning dependencies of target translations_120
[ 68%] Generating de/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_120
Scanning dependencies of target translations_118
[ 68%] Generating cy/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_118
Scanning dependencies of target translations_106
[ 68%] Generating be/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_106
Scanning dependencies of target translations_136
[ 68%] Generating he/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_136
Scanning dependencies of target translations_165
[ 68%] Generating nl/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_165
Scanning dependencies of target translations_116
[ 68%] Generating cs/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_116
Scanning dependencies of target translations_110
[ 68%] Generating bn_IN/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_110
Scanning dependencies of target translations_115
[ 68%] Generating crh/kwidgetsaddons5_qt.qm
[ 68%] Built target translations_115
Scanning dependencies of target translations_112
[ 69%] Generating bs/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_112
Scanning dependencies of target translations_107
[ 69%] Generating be@latin/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_107
Scanning dependencies of target translations_144
[ 69%] Generating id/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_144
Scanning dependencies of target translations_109
[ 69%] Generating bn/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_109
Scanning dependencies of target translations_122
[ 69%] Generating en/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_122
Scanning dependencies of target translations_103
[ 69%] Generating ar/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_103
Scanning dependencies of target translations_127
[ 69%] Generating eu/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_127
Scanning dependencies of target translations_176
[ 69%] Generating se/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_176
Scanning dependencies of target translations_104
[ 69%] Generating as/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_104
Scanning dependencies of target translations_129
[ 69%] Generating fi/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_129
Scanning dependencies of target translations_156
[ 69%] Generating lv/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_156
Scanning dependencies of target translations_119
[ 69%] Generating da/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_119
Scanning dependencies of target translations_139
[ 69%] Generating hr/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_139
Scanning dependencies of target translations_132
[ 69%] Generating ga/kwidgetsaddons5_qt.qm
[ 69%] Built target translations_132
Scanning dependencies of target translations_149
[ 70%] Generating kk/kwidgetsaddons5_qt.qm
[ 70%] Built target translations_149
Scanning dependencies of target translations_171
[ 70%] Generating ps/kwidgetsaddons5_qt.qm
[ 70%] Built target translations_171
Scanning dependencies of target translations_105
[ 70%] Generating ast/kwidgetsaddons5_qt.qm
[ 70%] Built target translations_105
Scanning dependencies of target translations_135
[ 70%] Generating ha/kwidgetsaddons5_qt.qm
[ 70%] Built target translations_135
Scanning dependencies of target translations_197
[ 70%] Generating wa/kwidgetsaddons5_qt.qm
[ 70%] Built target translations_197
Scanning dependencies of target translations_145
[ 70%] Generating is/kwidgetsaddons5_qt.qm
[ 70%] Built target translations_145
Scanning dependencies of target translations_154
[ 70%] Generating lb/kwidgetsaddons5_qt.qm
[ 70%] Built target translations_154
Scanning dependencies of target translations_121
[ 71%] Generating el/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_121
Scanning dependencies of target translations_111
[ 71%] Generating br/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_111
Scanning dependencies of target translations_170
[ 71%] Generating pl/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_170
Scanning dependencies of target translations_114
[ 71%] Generating ca@valencia/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_114
Scanning dependencies of target translations_113
[ 71%] Generating ca/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_113
Scanning dependencies of target translations_134
[ 71%] Generating gu/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_134
Scanning dependencies of target translations_117
[ 71%] Generating csb/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_117
Scanning dependencies of target translations_131
[ 71%] Generating fy/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_131
Scanning dependencies of target translations_199
[ 71%] Generating zh_CN/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_199
Scanning dependencies of target translations_153
[ 71%] Generating ku/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_153
Scanning dependencies of target translations_201
[ 71%] Generating zh_TW/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_201
Scanning dependencies of target translations_133
[ 71%] Generating gl/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_133
Scanning dependencies of target translations_192
[ 71%] Generating ug/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_192
Scanning dependencies of target translations_181
[ 71%] Generating sr/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_181
Scanning dependencies of target translations_158
[ 71%] Generating mk/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_158
Scanning dependencies of target translations_137
[ 71%] Generating hi/kwidgetsaddons5_qt.qm
[ 71%] Built target translations_137
Scanning dependencies of target translations_159
[ 72%] Generating ml/kwidgetsaddons5_qt.qm
[ 72%] Built target translations_159
Scanning dependencies of target translations_138
[ 72%] Generating hne/kwidgetsaddons5_qt.qm
[ 72%] Built target translations_138
Scanning dependencies of target translations_147
[ 72%] Generating ja/kwidgetsaddons5_qt.qm
[ 72%] Built target translations_147
Scanning dependencies of target translations_140
[ 72%] Generating hsb/kwidgetsaddons5_qt.qm
[ 72%] Built target translations_140
Scanning dependencies of target translations_151
[ 72%] Generating kn/kwidgetsaddons5_qt.qm
[ 72%] Built target translations_151
Scanning dependencies of target translations_141
[ 72%] Generating hu/kwidgetsaddons5_qt.qm
[ 72%] Built target translations_141
Scanning dependencies of target translations_200
[ 72%] Generating zh_HK/kwidgetsaddons5_qt.qm
[ 72%] Built target translations_200
Scanning dependencies of target translations_102
[ 73%] Generating af/kwidgetsaddons5_qt.qm
[ 73%] Built target translations_102
Scanning dependencies of target translations_142
[ 73%] Generating hy/kwidgetsaddons5_qt.qm
[ 73%] Built target translations_142
Scanning dependencies of target translations_186
[ 74%] Generating ta/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_186
Scanning dependencies of target translations_157
[ 74%] Generating mai/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_157
Scanning dependencies of target translations_143
[ 74%] Generating ia/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_143
Scanning dependencies of target translations_146
[ 74%] Generating it/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_146
Scanning dependencies of target translations_108
[ 74%] Generating bg/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_108
Scanning dependencies of target translations_148
[ 74%] Generating ka/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_148
Scanning dependencies of target translations_152
[ 74%] Generating ko/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_152
Scanning dependencies of target translations_128
[ 74%] Generating fa/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_128
Scanning dependencies of target translations_150
[ 74%] Generating km/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_150
Scanning dependencies of target translations_163
[ 74%] Generating nds/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_163
Scanning dependencies of target translations_155
[ 74%] Generating lt/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_155
Scanning dependencies of target translations_160
[ 74%] Generating mr/kwidgetsaddons5_qt.qm
[ 74%] Built target translations_160
Scanning dependencies of target kwidgetsaddonswidgets_autogen
[ 74%] Automatic MOC and UIC for target kwidgetsaddonswidgets
[ 74%] Built target kwidgetsaddonswidgets_autogen
[ 74%] Generating qrc_designerplugin.cpp
[ 74%] Building CXX object _deps/kwidgetsaddons-build/src/designer/CMakeFiles/kwidgetsaddonswidgets.dir/kwidgetsaddonswidgets_autogen/mocs_compilation.cpp.o
[ 75%] Building CXX object _deps/kwidgetsaddons-build/src/designer/CMakeFiles/kwidgetsaddonswidgets.dir/kwidgetsaddonswidgets_ECMQtDesignerPlugin/designerplugin.cpp.o
[ 75%] Building CXX object _deps/kwidgetsaddons-build/src/designer/CMakeFiles/kwidgetsaddonswidgets.dir/qrc_designerplugin.cpp.o
[ 75%] Linking CXX shared module ../../../../bin/kwidgetsaddons5widgets.so
[ 75%] Built target kwidgetsaddonswidgets
Scanning dependencies of target kcolumnresizertest_autogen
[ 75%] Automatic MOC and UIC for target kcolumnresizertest
[ 75%] Built target kcolumnresizertest_autogen
[ 75%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kcolumnresizertest.dir/kcolumnresizertest_autogen/mocs_compilation.cpp.o
[ 75%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kcolumnresizertest.dir/kcolumnresizertest.cpp.o
[ 75%] Linking CXX executable ../../../bin/kcolumnresizertest
Scanning dependencies of target kpasswordlineedittest_autogen
[ 75%] Automatic MOC and UIC for target kpasswordlineedittest
[ 75%] Built target kpasswordlineedittest_autogen
[ 75%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kpasswordlineedittest.dir/kpasswordlineedittest_autogen/mocs_compilation.cpp.o
[ 75%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kpasswordlineedittest.dir/kpasswordlineedittest.cpp.o
[ 75%] Linking CXX executable ../../../bin/kpasswordlineedittest
Scanning dependencies of target kpassworddialogautotest_autogen
[ 75%] Automatic MOC and UIC for target kpassworddialogautotest
[ 75%] Built target kpassworddialogautotest_autogen
[ 75%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kpassworddialogautotest.dir/kpassworddialogautotest_autogen/mocs_compilation.cpp.o
[ 75%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kpassworddialogautotest.dir/kpassworddialogautotest.cpp.o
[ 75%] Linking CXX executable ../../../bin/kpassworddialogautotest
Scanning dependencies of target kpagedialogautotest_autogen
[ 75%] Automatic MOC and UIC for target kpagedialogautotest
[ 75%] Built target kpagedialogautotest_autogen
[ 75%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kpagedialogautotest.dir/kpagedialogautotest_autogen/mocs_compilation.cpp.o
[ 75%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kpagedialogautotest.dir/kpagedialogautotest.cpp.o
[ 75%] Linking CXX executable ../../../bin/kpagedialogautotest
Scanning dependencies of target kmessagewidgetautotest_autogen
[ 75%] Automatic MOC and UIC for target kmessagewidgetautotest
[ 75%] Built target kmessagewidgetautotest_autogen
[ 75%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kmessagewidgetautotest.dir/kmessagewidgetautotest_autogen/mocs_compilation.cpp.o
[ 75%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kmessagewidgetautotest.dir/kmessagewidgetautotest.cpp.o
[ 75%] Linking CXX executable ../../../bin/kmessagewidgetautotest
Scanning dependencies of target kacceleratormanagertest_autogen
[ 76%] Automatic MOC and UIC for target kacceleratormanagertest
[ 76%] Built target kacceleratormanagertest_autogen
[ 76%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kacceleratormanagertest.dir/kacceleratormanagertest_autogen/mocs_compilation.cpp.o
[ 76%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kacceleratormanagertest.dir/kacceleratormanagertest.cpp.o
[ 76%] Linking CXX executable ../../../bin/kacceleratormanagertest
Scanning dependencies of target kcharselect_unittest_autogen
[ 76%] Automatic MOC and UIC for target kcharselect_unittest
[ 76%] Built target kcharselect_unittest_autogen
[ 76%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kcharselect_unittest.dir/kcharselect_unittest_autogen/mocs_compilation.cpp.o
[ 76%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kcharselect_unittest.dir/kcharselect_unittest.cpp.o
[ 76%] Linking CXX executable ../../../bin/kcharselect_unittest
Scanning dependencies of target ksplittercollapserbuttontest_autogen
[ 76%] Automatic MOC and UIC for target ksplittercollapserbuttontest
[ 76%] Built target ksplittercollapserbuttontest_autogen
[ 76%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/ksplittercollapserbuttontest.dir/ksplittercollapserbuttontest_autogen/mocs_compilation.cpp.o
[ 76%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/ksplittercollapserbuttontest.dir/ksplittercollapserbuttontest.cpp.o
[ 76%] Linking CXX executable ../../../bin/ksplittercollapserbuttontest
Scanning dependencies of target kcollapsiblegroupbox_test_autogen
[ 76%] Automatic MOC and UIC for target kcollapsiblegroupbox_test
[ 76%] Built target kcollapsiblegroupbox_test_autogen
[ 76%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kcollapsiblegroupbox_test.dir/kcollapsiblegroupbox_test_autogen/mocs_compilation.cpp.o
[ 77%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kcollapsiblegroupbox_test.dir/kcollapsiblegroupbox_test.cpp.o
[ 77%] Linking CXX executable ../../../bin/kcollapsiblegroupbox_test
[ 77%] Built target kcollapsiblegroupbox_test
Scanning dependencies of target kcolorbuttontest_autogen
[ 77%] Automatic MOC and UIC for target kcolorbuttontest
[ 77%] Built target kcolorbuttontest_autogen
[ 77%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kcolorbuttontest.dir/kcolorbuttontest_autogen/mocs_compilation.cpp.o
[ 77%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kcolorbuttontest.dir/kcolorbuttontest.cpp.o
[ 77%] Linking CXX executable ../../../bin/kcolorbuttontest
Scanning dependencies of target kdatecomboboxtest_autogen
[ 78%] Automatic MOC and UIC for target kdatecomboboxtest
[ 78%] Built target kdatecomboboxtest_autogen
[ 78%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kdatecomboboxtest.dir/kdatecomboboxtest_autogen/mocs_compilation.cpp.o
[ 78%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kdatecomboboxtest.dir/kdatecomboboxtest.cpp.o
[ 78%] Linking CXX executable ../../../bin/kdatecomboboxtest
Scanning dependencies of target kdualactiontest_autogen
[ 78%] Automatic MOC and UIC for target kdualactiontest
[ 78%] Built target kdualactiontest_autogen
[ 78%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kdualactiontest.dir/kdualactiontest_autogen/mocs_compilation.cpp.o
[ 78%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kdualactiontest.dir/kdualactiontest.cpp.o
[ 78%] Linking CXX executable ../../../bin/kdualactiontest
Scanning dependencies of target kselectaction_unittest_autogen
[ 78%] Automatic MOC and UIC for target kselectaction_unittest
[ 78%] Built target kselectaction_unittest_autogen
[ 78%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kselectaction_unittest.dir/kselectaction_unittest_autogen/mocs_compilation.cpp.o
[ 78%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kselectaction_unittest.dir/kselectaction_unittest.cpp.o
[ 78%] Linking CXX executable ../../../bin/kselectaction_unittest
Scanning dependencies of target ksqueezedtextlabelautotest_autogen
[ 78%] Automatic MOC and UIC for target ksqueezedtextlabelautotest
[ 78%] Built target ksqueezedtextlabelautotest_autogen
[ 79%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/ksqueezedtextlabelautotest.dir/ksqueezedtextlabelautotest_autogen/mocs_compilation.cpp.o
[ 79%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/ksqueezedtextlabelautotest.dir/ksqueezedtextlabelautotest.cpp.o
[ 79%] Linking CXX executable ../../../bin/ksqueezedtextlabelautotest
[ 79%] Built target ksqueezedtextlabelautotest
Scanning dependencies of target kpixmapsequencewidgettest_autogen
[ 80%] Automatic MOC and UIC for target kpixmapsequencewidgettest
[ 80%] Built target kpixmapsequencewidgettest_autogen
[ 80%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kpixmapsequencewidgettest.dir/kpixmapsequencewidgettest_autogen/mocs_compilation.cpp.o
[ 80%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kpixmapsequencewidgettest.dir/kpixmapsequencewidgettest.cpp.o
[ 80%] Linking CXX executable ../../../bin/kpixmapsequencewidgettest
Scanning dependencies of target kdatetimeedittest_autogen
[ 80%] Automatic MOC and UIC for target kdatetimeedittest
[ 80%] Built target kdatetimeedittest_autogen
[ 81%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kdatetimeedittest.dir/kdatetimeedittest_autogen/mocs_compilation.cpp.o
[ 81%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/kdatetimeedittest.dir/kdatetimeedittest.cpp.o
[ 81%] Linking CXX executable ../../../bin/kdatetimeedittest
[ 81%] Built target kdatetimeedittest
Scanning dependencies of target ktimecomboboxtest_autogen
[ 81%] Automatic MOC and UIC for target ktimecomboboxtest
[ 81%] Built target ktimecomboboxtest_autogen
[ 81%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/ktimecomboboxtest.dir/ktimecomboboxtest_autogen/mocs_compilation.cpp.o
[ 81%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/ktimecomboboxtest.dir/ktimecomboboxtest.cpp.o
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/autotests/ktimecomboboxtest.cpp: In memberfunctie ‘void KTimeComboBoxTest::testMask()’:
/home/simon/GIT/qet/_deps/kwidgetsaddons-src/autotests/ktimecomboboxtest.cpp:202:42: let op: ‘QLocale::Norwegian’ is deprecated: Obsolete name, use NorwegianBokmal [-Wdeprecated-declarations]
  202 |     QLocale::setDefault(QLocale(QLocale::Norwegian, QLocale::Norway));
In file included from /usr/include/qt5/QtCore/qtextstream.h:46,
                 from /usr/include/qt5/QtCore/qdebug.h:49,
                 from /usr/include/qt5/QtCore/qcborcommon.h:45,
                 from /usr/include/qt5/QtTest/qtest.h:53,
                 from /usr/include/qt5/QtTest/QTest:1,
                 from /home/simon/GIT/qet/_deps/kwidgetsaddons-src/autotests/ktimecomboboxtest.cpp:24:
/usr/include/qt5/QtCore/qlocale.h:506:9: note: declared here
  506 |         Norwegian Q_DECL_ENUMERATOR_DEPRECATED_X("Obsolete name, use NorwegianBokmal") = NorwegianBokmal,
[ 81%] Linking CXX executable ../../../bin/ktimecomboboxtest
Scanning dependencies of target knewpasswordwidgettest_autogen
[ 81%] Automatic MOC and UIC for target knewpasswordwidgettest
[ 81%] Built target knewpasswordwidgettest_autogen
[ 81%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/knewpasswordwidgettest.dir/knewpasswordwidgettest_autogen/mocs_compilation.cpp.o
[ 81%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/knewpasswordwidgettest.dir/knewpasswordwidgettest.cpp.o
[ 81%] Linking CXX executable ../../../bin/knewpasswordwidgettest
Scanning dependencies of target ktooltipwidgettest_autogen
[ 81%] Automatic MOC and UIC for target ktooltipwidgettest
[ 81%] Built target ktooltipwidgettest_autogen
[ 81%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/ktooltipwidgettest.dir/ktooltipwidgettest_autogen/mocs_compilation.cpp.o
[ 81%] Building CXX object _deps/kwidgetsaddons-build/autotests/CMakeFiles/ktooltipwidgettest.dir/ktooltipwidgettest.cpp.o
[ 81%] Linking CXX executable ../../../bin/ktooltipwidgettest
Scanning dependencies of target kcolumnresizertestapp_autogen
[ 81%] Automatic MOC and UIC for target kcolumnresizertestapp
[ 81%] Built target kcolumnresizertestapp_autogen
[ 81%] Generating ui_kcolumnresizertestapp.h
[ 81%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kcolumnresizertestapp.dir/kcolumnresizertestapp_autogen/mocs_compilation.cpp.o
[ 82%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kcolumnresizertestapp.dir/kcolumnresizertestapp.cpp.o
[ 82%] Linking CXX executable ../../../bin/kcolumnresizertestapp
[ 82%] Built target kcolumnresizertestapp
Scanning dependencies of target kpasswordlineedit_test_autogen
[ 82%] Automatic MOC and UIC for target kpasswordlineedit_test
[ 82%] Built target kpasswordlineedit_test_autogen
[ 82%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpasswordlineedit_test.dir/kpasswordlineedit_test_autogen/mocs_compilation.cpp.o
[ 82%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpasswordlineedit_test.dir/kpasswordlineedit_test.cpp.o
[ 82%] Linking CXX executable ../../../bin/kpasswordlineedit_test
Scanning dependencies of target ktooltipwidget_test_autogen
[ 82%] Automatic MOC and UIC for target ktooltipwidget_test
[ 82%] Built target ktooltipwidget_test_autogen
[ 82%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/ktooltipwidget_test.dir/ktooltipwidget_test_autogen/mocs_compilation.cpp.o
[ 82%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/ktooltipwidget_test.dir/ktooltipwidget_test.cpp.o
[ 83%] Linking CXX executable ../../../bin/ktooltipwidget_test
[ 83%] Built target ktooltipwidget_test
Scanning dependencies of target kmimetypechoosertest_autogen
[ 83%] Automatic MOC and UIC for target kmimetypechoosertest
[ 83%] Built target kmimetypechoosertest_autogen
[ 83%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kmimetypechoosertest.dir/kmimetypechoosertest_autogen/mocs_compilation.cpp.o
[ 83%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kmimetypechoosertest.dir/kmimetypechoosertest.cpp.o
[ 83%] Linking CXX executable ../../../bin/kmimetypechoosertest
Scanning dependencies of target kselectactiontest_autogen
[ 83%] Automatic MOC and UIC for target kselectactiontest
[ 83%] Built target kselectactiontest_autogen
[ 83%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kselectactiontest.dir/kselectactiontest_autogen/mocs_compilation.cpp.o
[ 83%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kselectactiontest.dir/kselectactiontest.cpp.o
[ 83%] Linking CXX executable ../../../bin/kselectactiontest
Scanning dependencies of target kmessageboxwidtest_autogen
[ 83%] Automatic MOC and UIC for target kmessageboxwidtest
[ 83%] Built target kmessageboxwidtest_autogen
[ 84%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kmessageboxwidtest.dir/kmessageboxwidtest_autogen/mocs_compilation.cpp.o
[ 84%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kmessageboxwidtest.dir/kmessageboxwidtest.cpp.o
[ 84%] Linking CXX executable ../../../bin/kmessageboxwidtest
[ 84%] Built target kmessageboxwidtest
Scanning dependencies of target kledtest_autogen
[ 84%] Automatic MOC and UIC for target kledtest
[ 84%] Built target kledtest_autogen
[ 84%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kledtest.dir/kledtest_autogen/mocs_compilation.cpp.o
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kledtest.dir/kledtest.cpp.o
[ 85%] Linking CXX executable ../../../bin/kledtest
[ 85%] Built target kledtest
Scanning dependencies of target kanimatedbuttontest_autogen
[ 85%] Automatic MOC and UIC for target kanimatedbuttontest
[ 85%] Built target kanimatedbuttontest_autogen
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kanimatedbuttontest.dir/kanimatedbuttontest_autogen/mocs_compilation.cpp.o
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kanimatedbuttontest.dir/kanimatedbuttontest.cpp.o
[ 85%] Linking CXX executable ../../../bin/kanimatedbuttontest
Scanning dependencies of target ktoolbarlabelactiontest_autogen
[ 85%] Automatic MOC and UIC for target ktoolbarlabelactiontest
[ 85%] Built target ktoolbarlabelactiontest_autogen
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/ktoolbarlabelactiontest.dir/ktoolbarlabelactiontest_autogen/mocs_compilation.cpp.o
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/ktoolbarlabelactiontest.dir/ktoolbarlabelactiontest.cpp.o
[ 85%] Linking CXX executable ../../../bin/ktoolbarlabelactiontest
Scanning dependencies of target kpixmapsequenceoverlaypaintertest_autogen
[ 85%] Automatic MOC and UIC for target kpixmapsequenceoverlaypaintertest
[ 85%] Built target kpixmapsequenceoverlaypaintertest_autogen
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpixmapsequenceoverlaypaintertest.dir/kpixmapsequenceoverlaypaintertest_autogen/mocs_compilation.cpp.o
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpixmapsequenceoverlaypaintertest.dir/kpixmapsequenceoverlaypaintertest.cpp.o
[ 85%] Linking CXX executable ../../../bin/kpixmapsequenceoverlaypaintertest
Scanning dependencies of target ksqueezedtextlabeltest_autogen
[ 85%] Automatic MOC and UIC for target ksqueezedtextlabeltest
[ 85%] Built target ksqueezedtextlabeltest_autogen
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/ksqueezedtextlabeltest.dir/ksqueezedtextlabeltest_autogen/mocs_compilation.cpp.o
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/ksqueezedtextlabeltest.dir/ksqueezedtextlabeltest.cpp.o
[ 85%] Linking CXX executable ../../../bin/ksqueezedtextlabeltest
Scanning dependencies of target ksplittercollapserbuttongui_test_autogen
[ 85%] Automatic MOC and UIC for target ksplittercollapserbuttongui_test
[ 85%] Built target ksplittercollapserbuttongui_test_autogen
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/ksplittercollapserbuttongui_test.dir/ksplittercollapserbuttongui_test_autogen/mocs_compilation.cpp.o
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/ksplittercollapserbuttongui_test.dir/ksplittercollapserbuttongui_test.cpp.o
[ 85%] Linking CXX executable ../../../bin/ksplittercollapserbuttongui_test
Scanning dependencies of target kdatepicktest_autogen
[ 85%] Automatic MOC and UIC for target kdatepicktest
[ 85%] Built target kdatepicktest_autogen
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kdatepicktest.dir/kdatepicktest_autogen/mocs_compilation.cpp.o
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kdatepicktest.dir/kdatepicktest.cpp.o
[ 85%] Linking CXX executable ../../../bin/kdatepicktest
Scanning dependencies of target kmessageboxtest_autogen
[ 85%] Automatic MOC and UIC for target kmessageboxtest
[ 85%] Built target kmessageboxtest_autogen
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kmessageboxtest.dir/kmessageboxtest_autogen/mocs_compilation.cpp.o
[ 85%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kmessageboxtest.dir/kmessageboxtest.cpp.o
[ 85%] Linking CXX executable ../../../bin/kmessageboxtest
Scanning dependencies of target kseparatortest_autogen
[ 85%] Automatic MOC and UIC for target kseparatortest
[ 85%] Built target kseparatortest_autogen
[ 86%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kseparatortest.dir/kseparatortest_autogen/mocs_compilation.cpp.o
[ 86%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kseparatortest.dir/kseparatortest.cpp.o
[ 86%] Linking CXX executable ../../../bin/kseparatortest
[ 86%] Built target kseparatortest
Scanning dependencies of target kcollapsiblegroupboxtest_autogen
[ 86%] Automatic MOC and UIC for target kcollapsiblegroupboxtest
[ 86%] Built target kcollapsiblegroupboxtest_autogen
[ 86%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kcollapsiblegroupboxtest.dir/kcollapsiblegroupboxtest_autogen/mocs_compilation.cpp.o
[ 86%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kcollapsiblegroupboxtest.dir/kcollapsiblegroupboxtest.cpp.o
[ 86%] Linking CXX executable ../../../bin/kcollapsiblegroupboxtest
Scanning dependencies of target kpixmapregionselectordialogtest_autogen
[ 86%] Automatic MOC and UIC for target kpixmapregionselectordialogtest
[ 86%] Built target kpixmapregionselectordialogtest_autogen
[ 86%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpixmapregionselectordialogtest.dir/kpixmapregionselectordialogtest_autogen/mocs_compilation.cpp.o
[ 87%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpixmapregionselectordialogtest.dir/kpixmapregionselectordialogtest.cpp.o
[ 87%] Linking CXX executable ../../../bin/kpixmapregionselectordialogtest
[ 87%] Built target kpixmapregionselectordialogtest
Scanning dependencies of target knewpassworddialogtest_autogen
[ 87%] Automatic MOC and UIC for target knewpassworddialogtest
[ 87%] Built target knewpassworddialogtest_autogen
[ 87%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/knewpassworddialogtest.dir/knewpassworddialogtest_autogen/mocs_compilation.cpp.o
[ 87%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/knewpassworddialogtest.dir/knewpassworddialogtest.cpp.o
[ 87%] Linking CXX executable ../../../bin/knewpassworddialogtest
Scanning dependencies of target kcharselecttest_autogen
[ 87%] Automatic MOC and UIC for target kcharselecttest
[ 87%] Built target kcharselecttest_autogen
[ 87%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kcharselecttest.dir/kcharselecttest_autogen/mocs_compilation.cpp.o
[ 87%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kcharselecttest.dir/kcharselecttest.cpp.o
[ 87%] Linking CXX executable ../../../bin/kcharselecttest
Scanning dependencies of target kbusyindicatorwidgettest_autogen
[ 88%] Automatic MOC and UIC for target kbusyindicatorwidgettest
[ 88%] Built target kbusyindicatorwidgettest_autogen
[ 88%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kbusyindicatorwidgettest.dir/kbusyindicatorwidgettest_autogen/mocs_compilation.cpp.o
[ 88%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kbusyindicatorwidgettest.dir/kbusyindicatorwidgettest.cpp.o
[ 88%] Linking CXX executable ../../../bin/kbusyindicatorwidgettest
Scanning dependencies of target kassistantdialogtest_autogen
[ 88%] Automatic MOC and UIC for target kassistantdialogtest
[ 88%] Built target kassistantdialogtest_autogen
[ 88%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kassistantdialogtest.dir/kassistantdialogtest_autogen/mocs_compilation.cpp.o
[ 89%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kassistantdialogtest.dir/kassistantdialogtest.cpp.o
[ 89%] Linking CXX executable ../../../bin/kassistantdialogtest
[ 89%] Built target kassistantdialogtest
Scanning dependencies of target knewpasswordwidget_test_autogen
[ 89%] Automatic MOC and UIC for target knewpasswordwidget_test
[ 89%] Built target knewpasswordwidget_test_autogen
[ 90%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/knewpasswordwidget_test.dir/knewpasswordwidget_test_autogen/mocs_compilation.cpp.o
[ 90%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/knewpasswordwidget_test.dir/knewpasswordwidget_test.cpp.o
[ 90%] Linking CXX executable ../../../bin/knewpasswordwidget_test
[ 90%] Built target knewpasswordwidget_test
Scanning dependencies of target kfontchooserdialogtest_autogen
[ 90%] Automatic MOC and UIC for target kfontchooserdialogtest
[ 90%] Built target kfontchooserdialogtest_autogen
[ 90%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kfontchooserdialogtest.dir/kfontchooserdialogtest_autogen/mocs_compilation.cpp.o
[ 90%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kfontchooserdialogtest.dir/kfontchooserdialogtest.cpp.o
[ 90%] Linking CXX executable ../../../bin/kfontchooserdialogtest
Scanning dependencies of target kfontrequestertest_autogen
[ 91%] Automatic MOC and UIC for target kfontrequestertest
[ 91%] Built target kfontrequestertest_autogen
[ 91%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kfontrequestertest.dir/kfontrequestertest_autogen/mocs_compilation.cpp.o
[ 91%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kfontrequestertest.dir/kfontrequestertest.cpp.o
[ 91%] Linking CXX executable ../../../bin/kfontrequestertest
Scanning dependencies of target kdatetimeedittestapp_autogen
[ 91%] Automatic MOC and UIC for target kdatetimeedittestapp
[ 91%] Built target kdatetimeedittestapp_autogen
[ 91%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kdatetimeedittestapp.dir/kdatetimeedittestapp_autogen/mocs_compilation.cpp.o
[ 91%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kdatetimeedittestapp.dir/kdatetimeedittestapp.cpp.o
[ 91%] Linking CXX executable ../../../bin/kdatetimeedittestapp
Scanning dependencies of target kpassworddialogtest_autogen
[ 92%] Automatic MOC and UIC for target kpassworddialogtest
[ 92%] Built target kpassworddialogtest_autogen
[ 92%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpassworddialogtest.dir/kpassworddialogtest_autogen/mocs_compilation.cpp.o
[ 92%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpassworddialogtest.dir/kpassworddialogtest.cpp.o
[ 92%] Linking CXX executable ../../../bin/kpassworddialogtest
Scanning dependencies of target kratingwidgettest_autogen
[ 92%] Automatic MOC and UIC for target kratingwidgettest
[ 92%] Built target kratingwidgettest_autogen
[ 92%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kratingwidgettest.dir/kratingwidgettest_autogen/mocs_compilation.cpp.o
[ 92%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kratingwidgettest.dir/kratingwidgettest.cpp.o
[ 93%] Linking CXX executable ../../../bin/kratingwidgettest
[ 93%] Built target kratingwidgettest
Scanning dependencies of target kpagewidgettest_autogen
[ 93%] Automatic MOC and UIC for target kpagewidgettest
[ 93%] Built target kpagewidgettest_autogen
[ 94%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpagewidgettest.dir/kpagewidgettest_autogen/mocs_compilation.cpp.o
[ 94%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpagewidgettest.dir/kpagewidgettest.cpp.o
[ 94%] Linking CXX executable ../../../bin/kpagewidgettest
[ 94%] Built target kpagewidgettest
Scanning dependencies of target keditlistwidgettest_autogen
[ 94%] Automatic MOC and UIC for target keditlistwidgettest
[ 94%] Built target keditlistwidgettest_autogen
[ 94%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/keditlistwidgettest.dir/keditlistwidgettest_autogen/mocs_compilation.cpp.o
[ 94%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/keditlistwidgettest.dir/keditlistwidgettest.cpp.o
[ 94%] Linking CXX executable ../../../bin/keditlistwidgettest
Scanning dependencies of target kactionselectortest_autogen
[ 94%] Automatic MOC and UIC for target kactionselectortest
[ 94%] Built target kactionselectortest_autogen
[ 94%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kactionselectortest.dir/kactionselectortest_autogen/mocs_compilation.cpp.o
[ 94%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kactionselectortest.dir/kactionselectortest.cpp.o
[ 94%] Linking CXX executable ../../../bin/kactionselectortest
Scanning dependencies of target kcolorcombotest_autogen
[ 94%] Automatic MOC and UIC for target kcolorcombotest
[ 94%] Built target kcolorcombotest_autogen
[ 95%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kcolorcombotest.dir/kcolorcombotest_autogen/mocs_compilation.cpp.o
[ 95%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kcolorcombotest.dir/kcolorcombotest.cpp.o
[ 95%] Linking CXX executable ../../../bin/kcolorcombotest
[ 95%] Built target kcolorcombotest
Scanning dependencies of target ktitlewidgettest_autogen
[ 95%] Automatic MOC and UIC for target ktitlewidgettest
[ 95%] Built target ktitlewidgettest_autogen
[ 96%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/ktitlewidgettest.dir/ktitlewidgettest_autogen/mocs_compilation.cpp.o
[ 96%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/ktitlewidgettest.dir/ktitlewidgettest.cpp.o
[ 96%] Linking CXX executable ../../../bin/ktitlewidgettest
[ 96%] Built target ktitlewidgettest
Scanning dependencies of target kpagedialogtest_autogen
[ 96%] Automatic MOC and UIC for target kpagedialogtest
[ 96%] Built target kpagedialogtest_autogen
[ 96%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpagedialogtest.dir/kpagedialogtest_autogen/mocs_compilation.cpp.o
[ 96%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kpagedialogtest.dir/kpagedialogtest.cpp.o
[ 96%] Linking CXX executable ../../../bin/kpagedialogtest
Scanning dependencies of target kdatetabletest_autogen
[ 96%] Automatic MOC and UIC for target kdatetabletest
[ 96%] Built target kdatetabletest_autogen
[ 96%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kdatetabletest.dir/kdatetabletest_autogen/mocs_compilation.cpp.o
[ 96%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kdatetabletest.dir/kdatetabletest.cpp.o
[ 96%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kdatetabletest.dir/__/src/kdatetable.cpp.o
[ 96%] Linking CXX executable ../../../bin/kdatetabletest
Scanning dependencies of target kmessagewidgettest_autogen
[ 96%] Automatic MOC and UIC for target kmessagewidgettest
[ 96%] Built target kmessagewidgettest_autogen
[ 96%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kmessagewidgettest.dir/kmessagewidgettest_autogen/mocs_compilation.cpp.o
[ 96%] Building CXX object _deps/kwidgetsaddons-build/tests/CMakeFiles/kmessagewidgettest.dir/kmessagewidgettest.cpp.o
[ 97%] Linking CXX executable ../../../bin/kmessagewidgettest
[ 97%] Built target kmessagewidgettest
Scanning dependencies of target kwidgetaddons-example-kmessagebox_autogen
[ 97%] Automatic MOC and UIC for target kwidgetaddons-example-kmessagebox
[ 97%] Built target kwidgetaddons-example-kmessagebox_autogen
[ 97%] Building CXX object _deps/kwidgetsaddons-build/examples/kmessagebox/CMakeFiles/kwidgetaddons-example-kmessagebox.dir/kwidgetaddons-example-kmessagebox_autogen/mocs_compilation.cpp.o
[ 97%] Building CXX object _deps/kwidgetsaddons-build/examples/kmessagebox/CMakeFiles/kwidgetaddons-example-kmessagebox.dir/main.cpp.o
[ 97%] Linking CXX executable ../../../../bin/kwidgetaddons-example-kmessagebox
Scanning dependencies of target C_unittests_autogen
[ 97%] Automatic MOC and UIC for target C_unittests
[ 97%] Built target C_unittests_autogen
[ 97%] Building CXX object tests/catch/CMakeFiles/C_unittests.dir/C_unittests_autogen/mocs_compilation.cpp.o
[ 97%] Building CXX object tests/catch/CMakeFiles/C_unittests.dir/tst_My_test.cpp.o
[ 97%] Building CXX object tests/catch/CMakeFiles/C_unittests.dir/src/borderproperties_test.cpp.o
[ 97%] Building CXX object tests/catch/CMakeFiles/C_unittests.dir/main.cpp.o
[ 97%] Building CXX object tests/catch/CMakeFiles/C_unittests.dir/__/__/sources/borderproperties.cpp.o
[ 97%] Linking CXX executable C_unittests
Scanning dependencies of target gtest_autogen
[ 97%] Automatic MOC and UIC for target gtest
[ 97%] Built target gtest_autogen
[ 97%] Building CXX object _deps/gtest-build/googletest/CMakeFiles/gtest.dir/gtest_autogen/mocs_compilation.cpp.o
[ 97%] Building CXX object _deps/gtest-build/googletest/CMakeFiles/gtest.dir/src/gtest-all.cc.o
[ 97%] Linking CXX shared library ../../../lib/libgtestd.so
Scanning dependencies of target gtest_main_autogen
[ 97%] Automatic MOC and UIC for target gtest_main
[ 97%] Built target gtest_main_autogen
[ 97%] Building CXX object _deps/gtest-build/googletest/CMakeFiles/gtest_main.dir/gtest_main_autogen/mocs_compilation.cpp.o
[ 97%] Building CXX object _deps/gtest-build/googletest/CMakeFiles/gtest_main.dir/src/gtest_main.cc.o
[ 98%] Linking CXX shared library ../../../lib/libgtest_maind.so
[ 98%] Built target gtest_main
Scanning dependencies of target G_unittests_autogen
[ 98%] Automatic MOC and UIC for target G_unittests
[ 98%] Built target G_unittests_autogen
[ 98%] Building CXX object tests/googletest/CMakeFiles/G_unittests.dir/G_unittests_autogen/mocs_compilation.cpp.o
[ 98%] Building CXX object tests/googletest/CMakeFiles/G_unittests.dir/tst_My_test.cpp.o
[ 98%] Building CXX object tests/googletest/CMakeFiles/G_unittests.dir/main.cpp.o
[ 98%] Linking CXX executable G_unittests
Scanning dependencies of target gmock_autogen
[ 98%] Automatic MOC and UIC for target gmock
[ 98%] Built target gmock_autogen
[ 98%] Building CXX object _deps/gtest-build/googlemock/CMakeFiles/gmock.dir/gmock_autogen/mocs_compilation.cpp.o
[ 98%] Building CXX object _deps/gtest-build/googlemock/CMakeFiles/gmock.dir/src/gmock-all.cc.o
[ 98%] Linking CXX shared library ../../../lib/libgmockd.so
Scanning dependencies of target gmock_main_autogen
[ 98%] Automatic MOC and UIC for target gmock_main
[ 98%] Built target gmock_main_autogen
[ 99%] Building CXX object _deps/gtest-build/googlemock/CMakeFiles/gmock_main.dir/gmock_main_autogen/mocs_compilation.cpp.o
[ 99%] Building CXX object _deps/gtest-build/googlemock/CMakeFiles/gmock_main.dir/src/gmock_main.cc.o
[ 99%] Linking CXX shared library ../../../lib/libgmock_maind.so
[ 99%] Built target gmock_main
Scanning dependencies of target G_unitmocktests_autogen
[ 99%] Automatic MOC and UIC for target G_unitmocktests
[ 99%] Built target G_unitmocktests_autogen
[ 99%] Building CXX object tests/googlemock/CMakeFiles/G_unitmocktests.dir/G_unitmocktests_autogen/mocs_compilation.cpp.o
[ 99%] Building CXX object tests/googlemock/CMakeFiles/G_unitmocktests.dir/tst_My_test.cpp.o
[ 99%] Building CXX object tests/googlemock/CMakeFiles/G_unitmocktests.dir/main.cpp.o
[100%] Linking CXX executable G_unitmocktests
[100%] Built target G_unitmocktests
Scanning dependencies of target qt_unittests_autogen
[100%] Automatic MOC and UIC for target qt_unittests
[100%] Built target qt_unittests_autogen
[100%] Building CXX object tests/qttest/CMakeFiles/qt_unittests.dir/qt_unittests_autogen/mocs_compilation.cpp.o
[100%] Building CXX object tests/qttest/CMakeFiles/qt_unittests.dir/tst_mytest.cpp.o
[100%] Linking CXX executable qt_unittests
64 (edited by De-Backer 2020-12-11 22:27:04)
Re: Qt 6.0 development and qelectrotech
21:23:19.583 Info: Start-up
21:23:19.610 Info: debugging enabled: false
21:23:19.610 Info: Qt library version: 5.15.2
21:23:19.610 Info: Qt library location default prefix: "/usr"
21:23:19.610 Info: Qt library location documentation: "/usr/share/doc/packages/qt5"
21:23:19.610 Info: Qt library location headers: "/usr/include/qt5"
21:23:19.610 Info: Qt library location libraries: "/usr/lib64"
21:23:19.610 Info: Qt library location executables: "/usr/lib64/qt5/libexec"
21:23:19.610 Info: Qt library location Qt binaries: "/usr/lib64/qt5/bin"
21:23:19.610 Info: Qt library location Qt plugins: "/usr/lib64/qt5/plugins"
21:23:19.610 Info: Qt library location installed QML extensions: "/usr/lib64/qt5/imports"
21:23:19.610 Info: Qt library location installed QML extensions: "/usr/lib64/qt5/qml"
21:23:19.610 Info: Qt library location dependent Qt data: "/usr/lib64/qt5"
21:23:19.610 Info: Qt library location independent Qt data: "/usr/share/qt5"
21:23:19.610 Info: Qt library location translation: "/usr/share/qt5/translations"
21:23:19.610 Info: Qt library location examples: "/usr/lib64/qt5/examples"
21:23:19.610 Info: Qt library location Qt testcases: "/usr/tests"
21:23:19.610 Info: Qt library location Qt settings: "/etc/xdg"
21:23:19.610 Info: "GitRevision 74b112a4bb794061127313ba6c39ee7762964321"
21:23:19.610 Info: "QElectroTech V 0.80-rc"
21:23:19.610 Info: "Compilatie: GCC 10.2.1 20201202 [revision e563687cf9d3d1278f45aaebd03e0f66531076c9]"
21:23:19.611 Info: "Built with Qt 5.15.2 - Date : Dec 11 2020 : 21:12:45"
21:23:19.611 Info: "Run with Qt 5.15.2 using 16 thread(s)"
21:23:19.611 Info: "CPU : model name\t: AMD Ryzen 7 3700X 8-Core Processor\n"
21:23:19.611 Info: "RAM Total : 32026 MB"
21:23:19.611 Info: "RAM Available : 20002 MB"
21:23:19.611 Info: "GPU : "
21:23:19.611 Info: "GPU RAM : @ToDo"
21:23:19.611 Info: "OS : linux  - x86_64 - Version : openSUSE Tumbleweed - Kernel : 5.9.12-1-default"
21:23:19.611 Info: *** Qt screens ***
21:23:19.611 Info: "( 1 : 3840 x 2160 )"
21:23:19.923 Info: Elements collection reload
21:23:20.467 Info: Elements collection finished to be loaded
https://github.com/qelectrotech/qelectr … 7762964321
65 (edited by De-Backer 2020-12-11 23:28:10)
https://invent.kde.org/frameworks/kcore … ts.txt#L81
${CMAKE_SOURCE_DIR}/src/lib/text/ktexttohtml.cpp
it must be
CMAKE_SOURCE_DIR
that causes mistakes
test:
message("SIMON CMAKE_SOURCE_DIR         " ${CMAKE_SOURCE_DIR})
message("SIMON CMAKE_CURRENT_SOURCE_DIR " ${CMAKE_CURRENT_SOURCE_DIR})
message("SIMON KCoreAddons_BINARY_DIR   " ${KCoreAddons_BINARY_DIR})
return()
set(ktexttohtmltest_SRCS ktexttohtmltest.cpp ${CMAKE_SOURCE_DIR}/src/lib/text/ktexttohtml.cpp)
ecm_add_test(${ktexttohtmltest_SRCS} TEST_NAME ktexttohtmltest LINK_LIBRARIES Qt5::Test)
# include the binary dir in order to get kcoreaddons_export.h
SIMON CMAKE_SOURCE_DIR         /home/simon/GIT/qet
SIMON CMAKE_CURRENT_SOURCE_DIR /home/simon/GIT/qet/simon/autotests
SIMON KCoreAddons_BINARY_DIR   /home/simon/GIT/qet/build/_deps/kcoreaddons-build
set
CMAKE_SOURCE_DIR
to
/home/simon/GIT/build/qet-Desktop_Qt_5_15_1_GCC_64bit-Debug/_deps/kcoreaddons-src
KDE frameworks QT6
KF5 => KF6
https://ervin.ipsquad.net/blog/2020/07/ … y-edition/
https://phabricator.kde.org/project/board/310/
The Qt Company Is Tomorrow Moving Qt 5.15 To Its Commercial-Only LTS Phase
https://www.phoronix.com/scan.php?page= … cial-Phase
https://www.kdab.com/kdsingleapplication/
to change SingleApplication?
https://github.com/itay-grudev/SingleApplication
Only if the other depot was abandoned.
Maybe indeed it may make sense to see if on Windows it can speed up the launch and reduce some unexplained crashes: see
https://qelectrotech.org/forum/viewtopi … 427#p14427
72 (edited by De-Backer 2021-02-28 23:09:01)
Cmake is stil on SingleApplication v3.1.5
https://git.tuxfamily.org/qet/qet.git/t … tion.cmake
on https://github.com/itay-grudev/SingleAp … n/releases
Latest release v3.2.0
https://www.qt.io/blog/porting-from-qt- … azy-checks
https://wiki.qt.io/New_Features_in_Qt_6.1
If you want I can build it into Cmake with a compiler flag.
