commit 139241e77314c3beb229141cce5ec7e956334527
Author: Claveau Joshua <Joshua@>
Date:   Wed Sep 16 21:28:47 2020 +0200
    Change the way how the database is exported to file
    The export of internal database to file is now do by sqlite3 native
    function instead of a dirty home made function.
    For the moment, the export to file function is unavailable on macOSX (we
    need some help to add sqlite3 lib on macOSX)
Je rencontre des problemes avec ce commit:
Pas de soucis pour Linux (Debian, ubuntu, etc) ni pour Windows,
mais sous AppImage et macOS l'ajout des libs Sqlite3 provoque une segfault et plante QET lors de l'export de la bdd, de plus le fichier sqlite est vide et sur Flatpak ça ne fonctionne pas non plus ...
On revert?
https://www.tuxfamily.org/
Air conditioning failure
Posté le mardi 22 septembre 2020, à 08:52 UTC
Everything is down since 05:05 UTC, secondary services (ns2 and mx2) are up, about half of hosts are currently unreachable, we will keep you in touch.
https://forum.kicad.info/t/kicad-fusion … nlab/24891
KiCAD fusion with QElectroTech and MyOpenLab
External Plugins
Sep 22
1 / 9
Sep 22
2d ago
jtm2020hyo
Hello, I am new in this forum, I write this post with hope than any developer read it.
… actually exist a massiva migration since privative software to open source, in this issue we need be more competitive, for this motive I request a fusion between KiCAD, QElectroTech, and MyOpenLab (Or software similars or equvalents), similar to FreeCAD with KiCAD, this for complement and fight at same level than privative software, integrate all those mentioned software and complement their workflow.
PD: the forum link belongs to a new architect group than are trying to impulse a the open source in new projects, everyone is welcome.
229
KiCAD and QElectroTech are  two different beasts.
KiCAD is PCB oriented package which incorporates associated schematic software which is NEEDED to be able to produce decent PCB's.
QET is a totally different kind of software, mainly for electrical (not electronic) and automation diagrams.
Although it is possible to make an electrical diagram for entire house in KiCAD, it is not possible to produce PCB of that size nomicons/grin
Soo... integrating apples and oranges ... possible, but only squeezed as juice nomicons/grin
KiCAD is not even coded in QT. LibrePCB is.
231 (edited by galexis 2020-10-09 10:52:23)
est-il possible de mémoriser la taille du sommaire une fois inséré ? Chaque fois que je ferme et réouvre le projet la taille est réinitialisée et du coup toute petite. Faut à chaque fois redimensionner  à la main....
De plus avec la git6826, la colonne date reste vide....
Merci.
Cordialement.
Oui bien sure.
D'ailleurs c'est un bug que je doit résoudre, pas un comportement à la con nomicons/wink
sur la dernière version la date ne s'affiche dans dans la liste des folios
Ça provient peut-être de ce commit :
https://git.tuxfamily.org/qet/qet.git/c … fc4234b7c1
commit cb29a4d3830778a4657c83507cdffbcba22c379a
Author: Laurent Trinques <scorpio@q>
Date:   Thu Oct 22 18:28:52 2020 +0200
    Fix date on summary pages
J’ai vu je teste demain
La date fonctionne bien
Super, merci du retour.nomicons/wink
239 (edited by S.DEFFAUX 2020-10-25 11:20:33)
j'ai des soucis avec les widget
config.jpg, 243.11 kb, 1366 x 768
la suite
pb affichage.png, 71.9 kb, 1366 x 768
241 (edited by De-Backer 2020-10-25 13:25:26)
@ S.DEFFAUX
code:
https://git.tuxfamily.org/qet/qet.git/t … .cpp#n1769
void QETApp::configureQET()
    // determine the parent widget to use for the dialog
    // determine le widget parent a utiliser pour le dialogue
    QWidget *parent_widget = qApp->activeWindow();
    // create dialogue
    // cree le dialogue
    ConfigDialog cd;
    cd.setWindowTitle(tr("Configurer QElectroTech", "window title"));
    cd.setWindowModality(Qt::WindowModal);
    cd.addPage(new GeneralConfigurationPage());
    cd.addPage(new NewDiagramPage());
    cd.addPage(new ExportConfigPage());
    cd.addPage(new PrintConfigPage());
    // associates the dialog with a possible parent widget
    // associe le dialogue a un eventuel widget parent
    if (parent_widget) {
        cd.setParent(parent_widget, cd.windowFlags());
    // display the dialog then avoid linking it to any parent widget
    // affiche le dialogue puis evite de le lier a un quelconque widget parent
    cd.exec();
    cd.setParent(nullptr, cd.windowFlags());
    qDebug() <<"configureQET"<<cd.size();
Debug: configureQET QSize(1400, 1000) (../../qet/sources/qetapp.cpp:1802, void QETApp::configureQET())
the 1000 is your problem, right?
Mod code:
to
        cd.resize(parent_widget->size());
Debug: configureQET QSize(1280, 720) (../../qet/sources/qetapp.cpp:1803, void QETApp::configureQET())
but this is a problem for large screens.
        cd.setMaximumSize(parent_widget->size());
is ok
https://git.tuxfamily.org/qet/qet.git/c … f343adb020
great
le nom des dossiers des éléments importé dans le projet ne sont plus traduit
no translate.png, 94.35 kb, 1366 x 768
@S.DEFFAUX I skip this one
Have you ever wondered why some bugs take a long time to fix?
dir_08d237fc27d4ecd563f71c5d52f2fecc_dep.png, 199.77 kb, 1045 x 869
ôo my God.
palhenrique wrote:
ôo my God.
https://www.openhub.net/p/qelectrotech
ending with its most recent commit about 1 year ago
time for an update
https://github.com/AlDanial/cloc
cloc counts blank lines, comment lines, and physical lines of source code in many programming languages.
cloc qet/
    9373 text files.
    9048 unique files.
    8765 files ignored.
github.com/AlDanial/cloc v 1.86  T=2.77 s (220.1 files/s, 189010.3 lines/s)
Language                         files          blank        comment           code
Qt Linguist                         29            739              0         370299
C++                                242          13541          24860          73027
C/C++ Header                       245           3577           6443          13413
Qt                                  58              0              0          11900
diff                                 2              5            107           1043
XML                                  7              0             22            826
CSS                                  1            132              4            607
Markdown                             5            251              0            599
Perl                                 1             22             35            310
Bourne Shell                         6             99             96            274
ProGuard                             3             49             44            230
YAML                                 1             12              3            109
DOS Batch                            3             19             21             94
DTD                                  1              8              0             61
JSON                                 1              0              0             37
CMake                                1              8              4             31
SVG                                  1              0              0             17
Qt Project                           1              2              1              8
Windows Resource File                1              0              0              1
SUM:                               609          18464          31640         472886
Corrigé.
Joshua wrote:
Corrigé.
Good job Joshua,
