Can't build on Debian Buster chroot : https://packages.debian.org/buster/qt5-default
qt5-default (5.11.3+dfsg1-1+deb10u3)
In file included from sources/main.cpp:18:
sources/qetapp.h:202:3: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
QSignalMapper signal_map;
QWidgetMapper
In file included from sources/diagramposition.cpp:19:
QWidgetMapper
sources/elementscollectioncache.cpp: In constructor 'ElementsCollectionCache::ElementsCollectionCache(const QString&, QObject*)':
sources/elementscollectioncache.cpp:56:62: note: #pragma message: @TODO remove this code for qet 0.6 or later
#pragma message("@TODO remove this code for qet 0.6 or later")
In file included from sources/elementtextpattern.cpp:19:
QWidgetMapper
In file included from sources/qetapp.cpp:18:
QWidgetMapper
In file included from sources/elementdialog.cpp:26:
QWidgetMapper
make[2]: *** [Makefile.Release:4336: release/diagramposition.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [Makefile.Release:4820: release/main.o] Error 1
In file included from sources/elementspanel.cpp:19:
QWidgetMapper
In file included from sources/qetdiagrameditor.cpp:18:
sources/qetdiagrameditor.h:211:3: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
QSignalMapper windowMapper;
QSignalBlocker
In file included from sources/conductorautonumerotation.cpp:20:
QSignalBlocker
In file included from sources/qetdiagrameditor.cpp:21:
sources/recentfiles.h:66:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
QSignalMapper *mapper_;
QSignalBlocker
make[2]: *** [Makefile.Release:4472: release/elementdialog.o] Error 1
In file included from sources/qetapp.cpp:21:
sources/qetdiagrameditor.h:211:3: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
QWidgetMapper
In file included from sources/qetapp.cpp:28:
sources/recentfiles.h:66:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
QWidgetMapper
sources/qetapp.cpp: In constructor 'QETApp::QETApp()':
sources/qetapp.cpp:89:11: error: 'signal_map' was not declared in this scope
connect(&signal_map, SIGNAL(mapped(QWidget *)),
sources/qetapp.cpp:89:11: note: suggested alternative: 'signals'
signals
sources/qetapp.cpp: In member function 'void QETApp::quitQET()':
sources/qetapp.cpp:1497:100: note: #pragma message: @TODO Segmentation fault when closing program before loading elements is finished
#pragma message("@TODO Segmentation fault when closing program before loading elements is finished")
sources/qetapp.cpp: In member function 'void QETApp::addWindowsListToMenu(QMenu*, const QList<T*>&)':
sources/qetapp.cpp:2092:47: error: 'signal_map' was not declared in this scope
connect(current_menu, SIGNAL(triggered()), &signal_map, SLOT(map()));
sources/qetapp.cpp:2092:47: note: suggested alternative: 'signals'
signals
In file included from sources/genericpanel.cpp:25:
QWidgetMapper
In file included from sources/qetgraphicsitem/ViewItem/qetgraphicstableitem.h:24,
from sources/elementprovider.cpp:22:
sources/qetapp.h:202:3: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
QSignalBlocker
In file included from sources/configpages.cpp:35:
QSignalBlocker
In file included from sources/configdialog.cpp:21:
QSignalBlocker
In file included from sources/bordertitleblock.cpp:26:
QSignalBlocker
In file included from sources/diagramview.cpp:31:
QSignalBlocker
In file included from sources/createdxf.cpp:23:
sources/exportdialog.h:75:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
QSignalMapper *preview_mapper_;
QWidgetMapper
from sources/diagramcontent.cpp:30:
QWidgetMapper
sources/exportdialog.h:76:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
QSignalMapper *width_mapper_;
QWidgetMapper
In file included from sources/projectview.cpp:23:
sources/exportdialog.h:75:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
QSignalBlocker
sources/exportdialog.h:77:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
QSignalMapper *height_mapper_;
QWidgetMapper
In file included from sources/elementspanelwidget.cpp:21:
QWidgetMapper
sources/exportdialog.h:76:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
QSignalBlocker
sources/exportdialog.h:78:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
QSignalMapper *ratio_mapper_;
QWidgetMapper
sources/exportdialog.h:77:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
QSignalBlocker
sources/exportdialog.h:79:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
QSignalMapper *reset_mapper_;
QWidgetMapper
sources/exportdialog.h:80:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
QSignalMapper *clipboard_mapper_;
QWidgetMapper
sources/exportdialog.h:78:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
QSignalBlocker
In file included from sources/exportdialog.cpp:18:
QWidgetMapper
sources/exportdialog.h:79:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
QSignalBlocker
QWidgetMapper
sources/exportdialog.h:80:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
QSignalBlocker
QWidgetMapper
In file included from sources/projectview.cpp:24:
QSignalBlocker
QWidgetMapper
QWidgetMapper
QWidgetMapper
from sources/qetdiagrameditor.cpp:38:
QSignalBlocker
sources/qetdiagrameditor.cpp: In constructor 'QETDiagramEditor::QETDiagramEditor(const QStringList&, QWidget*)':
sources/qetdiagrameditor.cpp:87:11: error: 'windowMapper' was not declared in this scope
connect(&windowMapper, SIGNAL(mapped(QWidget *)), this, SLOT(activateWidget(QWidget *)));
make[2]: *** [Makefile.Release:4682: release/elementtextpattern.o] Error 1
from sources/exportdialog.cpp:34:
QWidgetMapper
sources/qetdiagrameditor.cpp:87:11: note: suggested alternative: 'windowType'
windowType
In file included from sources/diagram.cpp:27:
QWidgetMapper
QWidgetMapper
sources/exportdialog.cpp: In member function 'QWidget* ExportDialog::initDiagramsListPart()':
sources/exportdialog.cpp:134:2: error: 'preview_mapper_' was not declared in this scope
preview_mapper_ = new QSignalMapper(this);
QWidgetMapper
QWidgetMapper
sources/exportdialog.cpp:134:26: error: expected type-specifier before 'QSignalMapper'
sources/exportdialog.cpp:135:2: error: 'width_mapper_' was not declared in this scope
width_mapper_ = new QSignalMapper(this);
QWidgetMapper
sources/exportdialog.cpp:135:26: error: expected type-specifier before 'QSignalMapper'
sources/exportdialog.cpp:136:2: error: 'height_mapper_' was not declared in this scope
height_mapper_ = new QSignalMapper(this);
QWidgetMapper
sources/exportdialog.cpp:136:2: note: suggested alternative: 'QWidgetMapper'
QWidgetMapper
sources/exportdialog.cpp:136:26: error: expected type-specifier before 'QSignalMapper'
sources/exportdialog.cpp:137:2: error: 'ratio_mapper_' was not declared in this scope
ratio_mapper_ = new QSignalMapper(this);
In file included from sources/diagram.cpp:33:
QWidgetMapper
In file included from sources/qetmainwindow.cpp:27:
QSignalBlocker
sources/exportdialog.cpp:137:26: error: expected type-specifier before 'QSignalMapper'
sources/exportdialog.cpp:138:2: error: 'reset_mapper_' was not declared in this scope
reset_mapper_ = new QSignalMapper(this);
make[2]: *** [Makefile.Release:4606: release/elementspanel.o] Error 1
sources/exportdialog.cpp:138:26: error: expected type-specifier before 'QSignalMapper'
sources/exportdialog.cpp:139:2: error: 'clipboard_mapper_' was not declared in this scope
clipboard_mapper_ = new QSignalMapper(this);
sources/qetdiagrameditor.cpp: In member function 'void QETDiagramEditor::slot_updateWindowsMenu()':
sources/qetdiagrameditor.cpp:1905:41: error: 'windowMapper' was not declared in this scope
connect(action, SIGNAL(triggered()), &windowMapper, SLOT(map()));
make[2]: *** [Makefile.Release:4506: release/elementprovider.o] Error 1
sources/diagram.cpp: In member function 'virtual void Diagram::keyPressEvent(QKeyEvent*)':
sources/diagram.cpp:357:50: note: #pragma message: @TODO move code to new function
#pragma message("@TODO move code to new function")
sources/qetdiagrameditor.cpp:1905:41: note: suggested alternative: 'windowType'
windowType
make[2]: *** [Makefile.Release:4802: release/genericpanel.o] Error 1
sources/exportdialog.cpp:139:26: error: expected type-specifier before 'QSignalMapper'
In file included from sources/qetmainwindow.cpp:28:
QSignalBlocker
make[2]: *** [Makefile.Release:4154: release/configpages.o] Error 1
make[2]: *** [Makefile.Release:4986: release/qetapp.o] Error 1
make[2]: *** [Makefile.Release:4120: release/configdialog.o] Error 1
make[2]: *** [Makefile.Release:4457: release/diagramview.o] Error 1
make[2]: *** [Makefile.Release:4319: release/diagramcontent.o] Error 1
make[2]: *** [Makefile.Release:4644: release/elementspanelwidget.o] Error 1
make[2]: *** [Makefile.Release:3995: release/bordertitleblock.o] Error 1
make[2]: *** [Makefile.Release:4036: release/conductorautonumerotation.o] Error 1
sources/createdxf.cpp:1041:15: warning: 'QRectF scaleRect(QRectF)' defined but not used [-Wunused-function]
static QRectF scaleRect(QRectF rect)
make[2]: *** [Makefile.Release:4182: release/createdxf.o] Error 1
make[2]: *** [Makefile.Release:4924: release/projectview.o] Error 1
make[2]: *** [Makefile.Release:5063: release/qetdiagrameditor.o] Error 1
make[2]: *** [Makefile.Release:4763: release/exportdialog.o] Error 1
make[2]: *** [Makefile.Release:4237: release/diagram.o] Error 1
In file included from sources/qetproject.cpp:27:
QWidgetMapper
sources/qetproject.cpp: In member function 'void QETProject::readProjectXml(QDomDocument&)':
sources/qetproject.cpp:1276:47: note: #pragma message: @TODO use of version convert
#pragma message("@TODO use of version convert")
sources/qetproject.cpp: In member function 'void QETProject::readDiagramsXml(QDomDocument&)':
sources/qetproject.cpp:1331:108: note: #pragma message: @TODO try to solve a weird bug (dialog is black) since port to Qt5 with the DialogWaiting
#pragma message("@TODO try to solve a weird bug (dialog is black) since port to Qt5 with the DialogWaiting")
make[2]: *** [Makefile.Release:5096: release/qetmainwindow.o] Error 1
make[2]: *** [Makefile.Release:5147: release/qetproject.o] Error 1
make[2]: Leaving directory '/build/qelectrotech-0.80.r6764'
make[1]: *** [Makefile:40: release] Error 2
