Topic: fix deprecated warning int QWheelEvent::delta() break macOS build
2 errors generated.
make: *** [release/diagramview.o] Error 1
make: *** Waiting for unfinished jobs....
sources/createdxf.cpp:1041:15: warning: unused function 'scaleRect'
      [-Wunused-function]
static QRectF scaleRect(QRectF rect)
In file included from sources/qetapp.cpp:33:
sources/projectview.h:46:21: error: no member named 'delta' in 'QWheelEvent'
                                        delta = event->delta() * scale_fa...
sources/projectview.h:51:83: error: no member named 'delta' in 'QWheelEvent'
  ...<< index << "temp_index" << temp_index << "  " << event->delta() << delta;
In file included from sources/qetmainwindow.cpp:29:
In file included from sources/qetdiagrameditor.cpp:29:
In file included from sources/autoNum/ui/autonumberingdockwidget.h:22:
sources/qetapp.cpp:1497:9: warning: @TODO Segmentation fault when closing program
      before loading elements is finished [-W#pragma-messages]
#pragma message("@TODO Segmentation fault when closing program before loa...
2 errors generated.
make: *** [release/projectview.o] Error 1
Re: fix deprecated warning int QWheelEvent::delta() break macOS build
Can't build on Debian Buster chroot : https://packages.debian.org/buster/qt5-default
qt5-default (5.11.3+dfsg1-1+deb10u3)
In file included from sources/main.cpp:18:
sources/qetapp.h:202:3: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
   QSignalMapper signal_map;
   QWidgetMapper
In file included from sources/diagramposition.cpp:19:
   QWidgetMapper
sources/elementscollectioncache.cpp: In constructor 'ElementsCollectionCache::ElementsCollectionCache(const QString&, QObject*)':
sources/elementscollectioncache.cpp:56:62: note: #pragma message: @TODO remove this code for qet 0.6 or later
#pragma message("@TODO remove this code for qet 0.6 or later")
In file included from sources/elementtextpattern.cpp:19:
   QWidgetMapper
In file included from sources/qetapp.cpp:18:
   QWidgetMapper
In file included from sources/elementdialog.cpp:26:
   QWidgetMapper
make[2]: *** [Makefile.Release:4336: release/diagramposition.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [Makefile.Release:4820: release/main.o] Error 1
In file included from sources/elementspanel.cpp:19:
   QWidgetMapper
In file included from sources/qetdiagrameditor.cpp:18:
sources/qetdiagrameditor.h:211:3: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
   QSignalMapper windowMapper;
   QSignalBlocker
In file included from sources/conductorautonumerotation.cpp:20:
   QSignalBlocker
In file included from sources/qetdiagrameditor.cpp:21:
sources/recentfiles.h:66:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
  QSignalMapper *mapper_;
  QSignalBlocker
make[2]: *** [Makefile.Release:4472: release/elementdialog.o] Error 1
In file included from sources/qetapp.cpp:21:
sources/qetdiagrameditor.h:211:3: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
   QWidgetMapper
In file included from sources/qetapp.cpp:28:
sources/recentfiles.h:66:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
  QWidgetMapper
sources/qetapp.cpp: In constructor 'QETApp::QETApp()':
sources/qetapp.cpp:89:11: error: 'signal_map' was not declared in this scope
  connect(&signal_map, SIGNAL(mapped(QWidget *)),
sources/qetapp.cpp:89:11: note: suggested alternative: 'signals'
           signals
sources/qetapp.cpp: In member function 'void QETApp::quitQET()':
sources/qetapp.cpp:1497:100: note: #pragma message: @TODO Segmentation fault when closing program before loading elements is finished
#pragma message("@TODO Segmentation fault when closing program before loading elements is finished")
sources/qetapp.cpp: In member function 'void QETApp::addWindowsListToMenu(QMenu*, const QList<T*>&)':
sources/qetapp.cpp:2092:47: error: 'signal_map' was not declared in this scope
   connect(current_menu, SIGNAL(triggered()), &signal_map, SLOT(map()));
sources/qetapp.cpp:2092:47: note: suggested alternative: 'signals'
                                               signals
In file included from sources/genericpanel.cpp:25:
   QWidgetMapper
In file included from sources/qetgraphicsitem/ViewItem/qetgraphicstableitem.h:24,
                 from sources/elementprovider.cpp:22:
sources/qetapp.h:202:3: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
   QSignalBlocker
In file included from sources/configpages.cpp:35:
   QSignalBlocker
In file included from sources/configdialog.cpp:21:
   QSignalBlocker
In file included from sources/bordertitleblock.cpp:26:
   QSignalBlocker
In file included from sources/diagramview.cpp:31:
   QSignalBlocker
In file included from sources/createdxf.cpp:23:
sources/exportdialog.h:75:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
  QSignalMapper *preview_mapper_;
  QWidgetMapper
                 from sources/diagramcontent.cpp:30:
   QWidgetMapper
sources/exportdialog.h:76:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
  QSignalMapper *width_mapper_;
  QWidgetMapper
In file included from sources/projectview.cpp:23:
sources/exportdialog.h:75:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
  QSignalBlocker
sources/exportdialog.h:77:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
  QSignalMapper *height_mapper_;
  QWidgetMapper
In file included from sources/elementspanelwidget.cpp:21:
   QWidgetMapper
sources/exportdialog.h:76:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
  QSignalBlocker
sources/exportdialog.h:78:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
  QSignalMapper *ratio_mapper_;
  QWidgetMapper
sources/exportdialog.h:77:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
  QSignalBlocker
sources/exportdialog.h:79:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
  QSignalMapper *reset_mapper_;
  QWidgetMapper
sources/exportdialog.h:80:2: error: 'QSignalMapper' does not name a type; did you mean 'QWidgetMapper'?
  QSignalMapper *clipboard_mapper_;
  QWidgetMapper
sources/exportdialog.h:78:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
  QSignalBlocker
In file included from sources/exportdialog.cpp:18:
  QWidgetMapper
sources/exportdialog.h:79:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
  QSignalBlocker
  QWidgetMapper
sources/exportdialog.h:80:2: error: 'QSignalMapper' does not name a type; did you mean 'QSignalBlocker'?
  QSignalBlocker
  QWidgetMapper
In file included from sources/projectview.cpp:24:
   QSignalBlocker
  QWidgetMapper
  QWidgetMapper
  QWidgetMapper
                 from sources/qetdiagrameditor.cpp:38:
   QSignalBlocker
sources/qetdiagrameditor.cpp: In constructor 'QETDiagramEditor::QETDiagramEditor(const QStringList&, QWidget*)':
sources/qetdiagrameditor.cpp:87:11: error: 'windowMapper' was not declared in this scope
  connect(&windowMapper, SIGNAL(mapped(QWidget *)), this, SLOT(activateWidget(QWidget *)));
make[2]: *** [Makefile.Release:4682: release/elementtextpattern.o] Error 1
                 from sources/exportdialog.cpp:34:
   QWidgetMapper
sources/qetdiagrameditor.cpp:87:11: note: suggested alternative: 'windowType'
           windowType
In file included from sources/diagram.cpp:27:
  QWidgetMapper
  QWidgetMapper
sources/exportdialog.cpp: In member function 'QWidget* ExportDialog::initDiagramsListPart()':
sources/exportdialog.cpp:134:2: error: 'preview_mapper_' was not declared in this scope
  preview_mapper_   = new QSignalMapper(this);
  QWidgetMapper
  QWidgetMapper
sources/exportdialog.cpp:134:26: error: expected type-specifier before 'QSignalMapper'
sources/exportdialog.cpp:135:2: error: 'width_mapper_' was not declared in this scope
  width_mapper_     = new QSignalMapper(this);
  QWidgetMapper
sources/exportdialog.cpp:135:26: error: expected type-specifier before 'QSignalMapper'
sources/exportdialog.cpp:136:2: error: 'height_mapper_' was not declared in this scope
  height_mapper_    = new QSignalMapper(this);
  QWidgetMapper
sources/exportdialog.cpp:136:2: note: suggested alternative: 'QWidgetMapper'
  QWidgetMapper
sources/exportdialog.cpp:136:26: error: expected type-specifier before 'QSignalMapper'
sources/exportdialog.cpp:137:2: error: 'ratio_mapper_' was not declared in this scope
  ratio_mapper_     = new QSignalMapper(this);
In file included from sources/diagram.cpp:33:
   QWidgetMapper
In file included from sources/qetmainwindow.cpp:27:
   QSignalBlocker
sources/exportdialog.cpp:137:26: error: expected type-specifier before 'QSignalMapper'
sources/exportdialog.cpp:138:2: error: 'reset_mapper_' was not declared in this scope
  reset_mapper_     = new QSignalMapper(this);
make[2]: *** [Makefile.Release:4606: release/elementspanel.o] Error 1
sources/exportdialog.cpp:138:26: error: expected type-specifier before 'QSignalMapper'
sources/exportdialog.cpp:139:2: error: 'clipboard_mapper_' was not declared in this scope
  clipboard_mapper_ = new QSignalMapper(this);
sources/qetdiagrameditor.cpp: In member function 'void QETDiagramEditor::slot_updateWindowsMenu()':
sources/qetdiagrameditor.cpp:1905:41: error: 'windowMapper' was not declared in this scope
   connect(action, SIGNAL(triggered()), &windowMapper, SLOT(map()));
make[2]: *** [Makefile.Release:4506: release/elementprovider.o] Error 1
sources/diagram.cpp: In member function 'virtual void Diagram::keyPressEvent(QKeyEvent*)':
sources/diagram.cpp:357:50: note: #pragma message: @TODO move code to new function
#pragma message("@TODO move code to new function")
sources/qetdiagrameditor.cpp:1905:41: note: suggested alternative: 'windowType'
                                         windowType
make[2]: *** [Makefile.Release:4802: release/genericpanel.o] Error 1
sources/exportdialog.cpp:139:26: error: expected type-specifier before 'QSignalMapper'
In file included from sources/qetmainwindow.cpp:28:
   QSignalBlocker
make[2]: *** [Makefile.Release:4154: release/configpages.o] Error 1
make[2]: *** [Makefile.Release:4986: release/qetapp.o] Error 1
make[2]: *** [Makefile.Release:4120: release/configdialog.o] Error 1
make[2]: *** [Makefile.Release:4457: release/diagramview.o] Error 1
make[2]: *** [Makefile.Release:4319: release/diagramcontent.o] Error 1
make[2]: *** [Makefile.Release:4644: release/elementspanelwidget.o] Error 1
make[2]: *** [Makefile.Release:3995: release/bordertitleblock.o] Error 1
make[2]: *** [Makefile.Release:4036: release/conductorautonumerotation.o] Error 1
sources/createdxf.cpp:1041:15: warning: 'QRectF scaleRect(QRectF)' defined but not used [-Wunused-function]
make[2]: *** [Makefile.Release:4182: release/createdxf.o] Error 1
make[2]: *** [Makefile.Release:4924: release/projectview.o] Error 1
make[2]: *** [Makefile.Release:5063: release/qetdiagrameditor.o] Error 1
make[2]: *** [Makefile.Release:4763: release/exportdialog.o] Error 1
make[2]: *** [Makefile.Release:4237: release/diagram.o] Error 1
In file included from sources/qetproject.cpp:27:
   QWidgetMapper
sources/qetproject.cpp: In member function 'void QETProject::readProjectXml(QDomDocument&)':
sources/qetproject.cpp:1276:47: note: #pragma message: @TODO use of version convert
#pragma message("@TODO use of version convert")
sources/qetproject.cpp: In member function 'void QETProject::readDiagramsXml(QDomDocument&)':
sources/qetproject.cpp:1331:108: note: #pragma message: @TODO try to solve a weird bug (dialog is black) since port to Qt5 with the DialogWaiting
#pragma message("@TODO try to solve a weird bug (dialog is black) since port to Qt5 with the DialogWaiting")
make[2]: *** [Makefile.Release:5096: release/qetmainwindow.o] Error 1
make[2]: *** [Makefile.Release:5147: release/qetproject.o] Error 1
make[2]: Leaving directory '/build/qelectrotech-0.80.r6764'
make[1]: *** [Makefile:40: release] Error 2
Humm, strange build fine on Ubuntu Bionic and focal ..
https://launchpadlibrarian.net/49868991 … ING.txt.gz
set # in pro file
DEFINES += QT_DISABLE_DEPRECATED_BEFORE=0x060000
De-Backer wrote:
set # in pro file
Strange but it compile now on Debian Buster chroot and I don't understand why it's compile without this comment on Ubuntu with Qt 5.9..
Thanks.
If I dont want to see #pragma messages warnings when I compile for packaging?
QMAKE_CXXFLAGS_WARN_ON += -Wunknown-pragmas
or
QMAKE_CXXFLAGS_WARN_ON += -Wno-unknown-pragmas
not help...
It irritates me to see them, or remove this #prama and keep @TODO?
i will look for a solution
These messages are useful during development while compiling, but are not useful to be seen when making packages, they pollute real GCC warnings.
https://git.tuxfamily.org/qet/qet.git/c … 27d13444bc
Great, thanks Simon. ;-)
