1 (edited by De-Backer 2020-08-30 23:17:52)
Topic: removing orientation for element.
can this be removed?
#pragma message("@TODO remove this code? the orientation for element")
    // we keep the orientation for compatibility with previous version of qet
    root.setAttribute("orientation", "dyyy");
https://git.tuxfamily.org/qet/qet.git/t … e.cpp#n433
pre
<element name="colectorsolarpiscina.elmt">
                                <definition hotspot_x="47" hotspot_y="35" version="0.4" link_type="simple" orientation="dyyy" width="70" type="element" height="60">
after
                                <definition height="60" width="70" hotspot_x="47" hotspot_y="35" version="0.8" link_type="simple" type="element" >
test with custom element lib
pre:
8ms in linux
61.788.886 bits
after:
6ms in linux
61.686.963 bits
not the big improvement, but nevertheless it is a improvement.
Re: removing orientation for element.
It should be found in the GIT logs since when the changes were made, and what version is impacted.
I think no one is using the old 0.3, 0.4 or 0.5 versions anymore?
BTW, it would be interesting to put a counter for the loading time of collections, but rather in the aboutQet widget.
I will work on this Tonight.
Yes you can safely remove this part of code, like Laurent say, it's not use since 0.3 or 0.4.
https://git.tuxfamily.org/qet/qet.git/c … ff3a148130
(Add loading time of collections inf to log)
and
Add log file's viewer in AboutQETDialog for user
Great, thanks Simon, but here not log..
don,
is form:
https://git.tuxfamily.org/qet/qet.git/c … e786bc8018
8 (edited by De-Backer 2020-08-31 21:55:09)
can give you some more info on how to compile it.
make clean
before
qmake qelectrotech.pro
mabie
https://stackoverflow.com/questions/438 … te-the-gui
I had the same problem and was able to solve it by deleting all the Makefiles in the build directory, then rebuilding from scratch. For some reason, these files are not deleted when you run Clean Project from Qt Creator.
Tried with Qtcreator, same thing with :
git pull
mkdir build && cd build
qmake ../qelectrotech.pro
time make -j48
10 (edited by De-Backer 2020-08-31 22:08:10)
and if je klikt on QComboBox ?
info of de code:
https://git.tuxfamily.org/qet/qet.git/c … 186da49f15
wat if dir are no log files in  QETApp::configDir() ...?
no, on startup QET makes a  log file
Nothing QETApp::configDir()
No log in my ~/.qet/ directory.
12 (edited by De-Backer 2020-08-31 22:19:11)
put a breakpoint in main.cpp lines 119 and 112 and test if you see this.
Strange .... work on macOS VM..
20:26:29.930 Info: Start-up
20:26:29.930 Debug: "File /Users/laurent/.qet/20200815.log is deleted!" (sources/main.cpp:148, void delete_old_log_files(int))
20:26:29.948 Info: debugging enabled: false
20:26:29.948 Info: Qt library version: 5.15.0
20:26:29.948 Info: Qt library location default prefix: "/Volumes/qelectrotech/qelectrotech.app/Contents"
20:26:29.948 Info: Qt library location documentation: "/Volumes/qelectrotech/qelectrotech.app/Contents/doc"
20:26:29.949 Info: Qt library location headers: "/Volumes/qelectrotech/qelectrotech.app/Contents/include"
20:26:29.949 Info: Qt library location libraries: "/Volumes/qelectrotech/qelectrotech.app/Contents/lib"
20:26:29.950 Info: Qt library location executables: "/Volumes/qelectrotech/qelectrotech.app/Contents/libexec"
20:26:29.950 Info: Qt library location Qt binaries: "/Volumes/qelectrotech/qelectrotech.app/Contents/bin"
20:26:29.950 Info: Qt library location Qt plugins: "/Volumes/qelectrotech/qelectrotech.app/Contents/PlugIns"
20:26:29.950 Info: Qt library location installed QML extensions: "/Volumes/qelectrotech/qelectrotech.app/Contents/Resources/qml"
20:26:29.951 Info: Qt library location installed QML extensions: "/Volumes/qelectrotech/qelectrotech.app/Contents/Resources/qml"
20:26:29.951 Info: Qt library location dependent Qt data: "/Volumes/qelectrotech/qelectrotech.app/Contents"
20:26:29.951 Info: Qt library location independent Qt data: "/Volumes/qelectrotech/qelectrotech.app/Contents"
20:26:29.951 Info: Qt library location translation: "/Volumes/qelectrotech/qelectrotech.app/Contents/translations"
20:26:29.951 Info: Qt library location examples: "/Volumes/qelectrotech/qelectrotech.app/Contents/examples"
20:26:29.951 Info: Qt library location Qt testcases: "/Volumes/qelectrotech/qelectrotech.app/Contents/tests"
20:26:29.952 Info: Qt library location Qt settings: "/Volumes/qelectrotech/qelectrotech.app/Contents"
20:26:29.952 Info: "QElectroTech V 0.80-DEV rd8cbcf3b5"
20:26:29.952 Info: "Compilation: CLANG 11.0.3 (clang-1103.0.32.29)"
20:26:29.952 Info: "Built with Qt 5.15.0 - Date : Aug 27 2020 : 21:17:59"
20:26:29.952 Info: "Run with Qt 5.15.0 using 48 thread(s)"
20:26:29.952 Info: "CPU : Intel Core 2 Duo P9xxx (Penryn Class Core 2)\n"
20:26:29.952 Info: "RAM Total : 32768 MB"
20:26:29.953 Info: ""
20:26:29.953 Info: "GPU : "
20:26:29.953 Info: "GPU RAM : "
20:26:29.953 Info: "OS : darwin  - x86_64 - Version : macOS 10.15 - Kernel : 19.6.0"
20:26:29.953 Info: *** Qt screens ***
20:26:29.953 Info: "( 1 : 1920 x 1080 )"
20:26:51.114 Warning: Populating font family aliases took 694 ms. Replace uses of missing font family "Sans Serif" with one that exists to avoid this cost.  (:0, )
20:26:54.058 Debug: Export XML de 50 schemas (sources/qetproject.cpp:854, QDomDocument QETProject::toXml())
20:26:54.059 Debug: "exporting diagram \"References Page\"" [ Diagram(0x7faadfc22280) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.061 Debug: "exporting diagram \"Folio list 1\"" [ Diagram(0x7fabafc11ba0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.061 Debug: "exporting diagram \"Folio list 2\"" [ Diagram(0x7fabafc14a60) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.061 Debug: "exporting diagram \"Mains Power Supply\"" [ Diagram(0x7fabafc16270) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.065 Debug: "exporting diagram \"Auxiliary Power Supply\"" [ Diagram(0x7fabafc648b0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.072 Debug: "exporting diagram \"Emergency Stop Circuit\"" [ Diagram(0x7fabafcb1be0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.084 Debug: "exporting diagram \"Emergency Stop Power\"" [ Diagram(0x7fa97861a5f0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.088 Debug: "exporting diagram \"VX Gate Control Circuit\"" [ Diagram(0x7fa978639500) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.095 Debug: "exporting diagram \"V1 Gate Control Circuit\"" [ Diagram(0x7fa978675eb0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.111 Debug: "exporting diagram \"V2 Gate Control Circuit\"" [ Diagram(0x7fa9786fd590) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.119 Debug: "exporting diagram \"V3 Gate Control Circuit\"" [ Diagram(0x7fabafc15e00) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.128 Debug: "exporting diagram \"V4 Gate Control Circuit\"" [ Diagram(0x7fa9787f74e0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.137 Debug: "exporting diagram \"V5 Gate Control Circuit\"" [ Diagram(0x7fa978876ec0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.146 Debug: "exporting diagram \"V6 Gate Control Circuit\"" [ Diagram(0x7fa9788f1db0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.154 Debug: "exporting diagram \"V7 Gate Control Circuit\"" [ Diagram(0x7fa9789715c0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.163 Debug: "exporting diagram \"A0 PLC Layout\"" [ Diagram(0x7fab4fe61600) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.166 Debug: "exporting diagram \"A0 Input Module\"" [ Diagram(0x7fab4fea4990) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.167 Debug: "exporting diagram \"A0 Output Module\"" [ Diagram(0x7fab4febd320) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.169 Debug: "exporting diagram \"A1/1 Input Module\"" [ Diagram(0x7fab4fecdc50) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.172 Debug: "exporting diagram \"A1/2 Input Module\"" [ Diagram(0x7fab4fef9690) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.175 Debug: "exporting diagram \"A1 Output Module\"" [ Diagram(0x7fa978a2a5f0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.180 Debug: "exporting diagram \"A2/1 Input Module\"" [ Diagram(0x7fa978a67de0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.183 Debug: "exporting diagram \"A2/2 Input Module\"" [ Diagram(0x7fa978a90b60) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.187 Debug: "exporting diagram \"A2 Output Module\"" [ Diagram(0x7fa978abb740) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.191 Debug: "exporting diagram \"A3/1 Input Module\"" [ Diagram(0x7fa978af6bc0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.195 Debug: "exporting diagram \"A3/2 Input Module\"" [ Diagram(0x7fa978b24440) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.198 Debug: "exporting diagram \"A3 Output Module\"" [ Diagram(0x7fa978b4ebe0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.203 Debug: "exporting diagram \"A4/1 Input Module\"" [ Diagram(0x7fa978b89e50) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.206 Debug: "exporting diagram \"A4/2 Input Module\"" [ Diagram(0x7fa97899e9d0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.207 Debug: "exporting diagram \"A4 Output Module\"" [ Diagram(0x7fa9789b2d00) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.210 Debug: "exporting diagram \"A5/1 Ana Input Module\"" [ Diagram(0x7fa9789d7c70) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.213 Debug: "exporting diagram \"A5/2 Ana Input Module\"" [ Diagram(0x7fa9789fac00) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.215 Debug: "exporting diagram \"TB1 Terminal Bord\"" [ Diagram(0x7fa978c1d510) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.222 Debug: "exporting diagram \"TB2 Terminal Bord\"" [ Diagram(0x7fa978c7f140) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.227 Debug: "exporting diagram \"TB3 Terminal Bord\"" [ Diagram(0x7fa978cc7d50) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.229 Debug: "exporting diagram \"TB4 Terminal Bord\"" [ Diagram(0x7fa978cf48f0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.234 Debug: "exporting diagram \"TB5 Terminal Bord\"" [ Diagram(0x7fa978d37be0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.234 Debug: "exporting diagram \"PB1 Panel Front View\"" [ Diagram(0x7fa978d38840) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.236 Debug: "exporting diagram \"PB2 Panel Front View\"" [ Diagram(0x7fa978d37870) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.244 Debug: "exporting diagram \"CX1 Modbus TCP\"" [ Diagram(0x7fa978d95910) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.250 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa978dcfa20) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.250 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa978dd1a60) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.250 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa978dd3730) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.250 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa978dd52e0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.250 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa9789fa890) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.251 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa978dd7530) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.251 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa978dd8480) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.251 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa978dd9f40) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.251 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa978dd1750) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.251 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa978ddc880) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:26:54.409 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.410 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.415 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.417 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.418 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.419 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.420 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.421 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.422 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.423 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.424 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.425 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.426 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.427 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.428 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.429 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:26:54.431 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:38.277 Info: Start-up
20:35:38.292 Info: debugging enabled: false
20:35:38.292 Info: Qt library version: 5.15.0
20:35:38.292 Info: Qt library location default prefix: "/Volumes/qelectrotech/qelectrotech.app/Contents"
20:35:38.292 Info: Qt library location documentation: "/Volumes/qelectrotech/qelectrotech.app/Contents/doc"
20:35:38.293 Info: Qt library location headers: "/Volumes/qelectrotech/qelectrotech.app/Contents/include"
20:35:38.293 Info: Qt library location libraries: "/Volumes/qelectrotech/qelectrotech.app/Contents/lib"
20:35:38.293 Info: Qt library location executables: "/Volumes/qelectrotech/qelectrotech.app/Contents/libexec"
20:35:38.293 Info: Qt library location Qt binaries: "/Volumes/qelectrotech/qelectrotech.app/Contents/bin"
20:35:38.293 Info: Qt library location Qt plugins: "/Volumes/qelectrotech/qelectrotech.app/Contents/PlugIns"
20:35:38.294 Info: Qt library location installed QML extensions: "/Volumes/qelectrotech/qelectrotech.app/Contents/Resources/qml"
20:35:38.294 Info: Qt library location dependent Qt data: "/Volumes/qelectrotech/qelectrotech.app/Contents"
20:35:38.294 Info: Qt library location independent Qt data: "/Volumes/qelectrotech/qelectrotech.app/Contents"
20:35:38.294 Info: Qt library location translation: "/Volumes/qelectrotech/qelectrotech.app/Contents/translations"
20:35:38.295 Info: Qt library location examples: "/Volumes/qelectrotech/qelectrotech.app/Contents/examples"
20:35:38.295 Info: Qt library location Qt testcases: "/Volumes/qelectrotech/qelectrotech.app/Contents/tests"
20:35:38.295 Info: Qt library location Qt settings: "/Volumes/qelectrotech/qelectrotech.app/Contents"
20:35:38.295 Info: "QElectroTech V 0.80-DEV r00eb139f7"
20:35:38.296 Info: "Compilation: CLANG 11.0.3 (clang-1103.0.32.29)"
20:35:38.296 Info: "Built with Qt 5.15.0 - Date : Aug 29 2020 : 20:27:53"
20:35:38.296 Info: "Run with Qt 5.15.0 using 48 thread(s)"
20:35:38.296 Info: "CPU : Intel Core 2 Duo P9xxx (Penryn Class Core 2)\n"
20:35:38.296 Info: "RAM Total : 32768 MB"
20:35:38.296 Info: ""
20:35:38.297 Info: "GPU : "
20:35:38.297 Info: "GPU RAM : "
20:35:38.297 Info: "OS : darwin  - x86_64 - Version : macOS 10.15 - Kernel : 19.6.0"
20:35:38.297 Info: *** Qt screens ***
20:35:38.297 Info: "( 1 : 1920 x 1080 )"
20:35:50.567 Warning: Populating font family aliases took 329 ms. Replace uses of missing font family "Sans Serif" with one that exists to avoid this cost.  (:0, )
20:35:53.449 Debug: Export XML de 50 schemas (sources/qetproject.cpp:854, QDomDocument QETProject::toXml())
20:35:53.449 Debug: "exporting diagram \"References Page\"" [ Diagram(0x7fa6c8c0e960) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.451 Debug: "exporting diagram \"Folio list 1\"" [ Diagram(0x7fa5d940cd30) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.452 Debug: "exporting diagram \"Folio list 2\"" [ Diagram(0x7fa5d940fc60) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.452 Debug: "exporting diagram \"Mains Power Supply\"" [ Diagram(0x7fa5d9411320) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.456 Debug: "exporting diagram \"Auxiliary Power Supply\"" [ Diagram(0x7fa5d945f7e0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.462 Debug: "exporting diagram \"Emergency Stop Circuit\"" [ Diagram(0x7fa5d94acd30) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.469 Debug: "exporting diagram \"Emergency Stop Power\"" [ Diagram(0x7fa4c9515990) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.471 Debug: "exporting diagram \"VX Gate Control Circuit\"" [ Diagram(0x7fa4c9534320) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.475 Debug: "exporting diagram \"V1 Gate Control Circuit\"" [ Diagram(0x7fa4c9570dc0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.484 Debug: "exporting diagram \"V2 Gate Control Circuit\"" [ Diagram(0x7fa4c95f8410) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.493 Debug: "exporting diagram \"V3 Gate Control Circuit\"" [ Diagram(0x7fa4c9677880) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.502 Debug: "exporting diagram \"V4 Gate Control Circuit\"" [ Diagram(0x7fa4c96f3290) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.511 Debug: "exporting diagram \"V5 Gate Control Circuit\"" [ Diagram(0x7fa4c9772f00) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.520 Debug: "exporting diagram \"V6 Gate Control Circuit\"" [ Diagram(0x7fa5d9411000) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.529 Debug: "exporting diagram \"V7 Gate Control Circuit\"" [ Diagram(0x7fa4c986cd50) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.537 Debug: "exporting diagram \"A0 PLC Layout\"" [ Diagram(0x7fa4c98e0e20) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.540 Debug: "exporting diagram \"A0 Input Module\"" [ Diagram(0x7fa4c9923fb0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.542 Debug: "exporting diagram \"A0 Output Module\"" [ Diagram(0x7fa4c993c750) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.543 Debug: "exporting diagram \"A1/1 Input Module\"" [ Diagram(0x7fa4c994c450) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.547 Debug: "exporting diagram \"A1/2 Input Module\"" [ Diagram(0x7fa4c9977a40) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.550 Debug: "exporting diagram \"A1 Output Module\"" [ Diagram(0x7fa4c99a49e0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.555 Debug: "exporting diagram \"A2/1 Input Module\"" [ Diagram(0x7fa4c99e20a0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.558 Debug: "exporting diagram \"A2/2 Input Module\"" [ Diagram(0x7fa4c994c0e0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.562 Debug: "exporting diagram \"A2 Output Module\"" [ Diagram(0x7fa4c9a39290) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.566 Debug: "exporting diagram \"A3/1 Input Module\"" [ Diagram(0x7fa4c9a74a70) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.570 Debug: "exporting diagram \"A3/2 Input Module\"" [ Diagram(0x7fa4c9a9e3a0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.573 Debug: "exporting diagram \"A3 Output Module\"" [ Diagram(0x7fa4c9ac8f20) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.578 Debug: "exporting diagram \"A4/1 Input Module\"" [ Diagram(0x7fa4c9b07a00) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.581 Debug: "exporting diagram \"A4/2 Input Module\"" [ Diagram(0x7fa4c9b314d0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.582 Debug: "exporting diagram \"A4 Output Module\"" [ Diagram(0x7fa4c9b3dd20) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.585 Debug: "exporting diagram \"A5/1 Ana Input Module\"" [ Diagram(0x7fa4c9b619c0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.588 Debug: "exporting diagram \"A5/2 Ana Input Module\"" [ Diagram(0x7fa4c9b84260) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.590 Debug: "exporting diagram \"TB1 Terminal Bord\"" [ Diagram(0x7fa4c9ba2dd0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.597 Debug: "exporting diagram \"TB2 Terminal Bord\"" [ Diagram(0x7fa4c9c08420) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.602 Debug: "exporting diagram \"TB3 Terminal Bord\"" [ Diagram(0x7fa4c9c50810) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.605 Debug: "exporting diagram \"TB4 Terminal Bord\"" [ Diagram(0x7fa4c9c7d2f0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.610 Debug: "exporting diagram \"TB5 Terminal Bord\"" [ Diagram(0x7fa4c9cbbca0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.610 Debug: "exporting diagram \"PB1 Panel Front View\"" [ Diagram(0x7fa4c9cbc900) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.612 Debug: "exporting diagram \"PB2 Panel Front View\"" [ Diagram(0x7fa4c9cc90f0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.620 Debug: "exporting diagram \"CX1 Modbus TCP\"" [ Diagram(0x7fa4c9d1e1e0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.626 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa4c9d576c0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.627 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa4c9d595f0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.627 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa4c9d5b2b0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.627 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa5d940f410) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.627 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa4c9d5d5e0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.627 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa4c9d5efc0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.628 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa4c9d60280) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.628 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa4c9d61a10) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.628 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa4c9d635c0) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.628 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x7fa4c9d5ae80) ] (sources/qetproject.cpp:859, QDomDocument QETProject::toXml())
20:35:53.802 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.803 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.804 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.809 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.810 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.811 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.812 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.813 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.814 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.815 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.816 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.817 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.818 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.819 Warning: Calling appendChild() on a null node does nothing. (:0, )
20:35:53.822 Warning: Calling appendChild() on a null node does nothing. (:0, )
14 (edited by De-Backer 2020-08-31 22:39:53)
mmm.... file dir .... //...log
Fix ?
see:
https://git.tuxfamily.org/qet/qet.git/c … 30d3e75724
WIN10 VM :
10:08:44.883 Info: Start-up
10:08:45.268 Info: debugging enabled: false
10:08:45.269 Info: Qt library version: 5.15.0
10:08:45.270 Info: Qt library location default prefix: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
10:08:45.270 Info: Qt library location documentation: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/doc"
10:08:45.270 Info: Qt library location headers: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/include"
10:08:45.270 Info: Qt library location libraries: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/lib"
10:08:45.270 Info: Qt library location executables: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
10:08:45.276 Info: Qt library location Qt binaries: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
10:08:45.277 Info: Qt library location Qt plugins: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/plugins"
10:08:45.277 Info: Qt library location installed QML extensions: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/imports"
10:08:45.278 Info: Qt library location installed QML extensions: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/qml"
10:08:45.279 Info: Qt library location dependent Qt data: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
10:08:45.280 Info: Qt library location independent Qt data: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
10:08:45.281 Info: Qt library location translation: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/translations"
10:08:45.281 Info: Qt library location examples: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/examples"
10:08:45.282 Info: Qt library location Qt testcases: "/home/laurent/digikam/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/tests"
10:08:45.283 Info: "QElectroTech V 0.80-DEV+0e6b385bed79751d3"
10:08:45.283 Info: "Compilation : GCC 9.3.0"
10:08:45.284 Info: "Built with Qt 5.15.0 - Date : Aug 21 2020 : 13:28:11"
10:08:45.285 Info: "Run with Qt 5.15.0 using 24 thread(s)"
10:08:45.286 Info: "CPU : NAME                                            \r\r\nAMD RYZEN THREADRIPPER 3960X 24-CORE PROCESSOR  \r\r\n\r\r\n"
10:08:45.287 Info: "RAM Total : 25738 MB"
10:08:45.287 Info: "RAM Available : 21829 MB"
10:08:45.288 Info: "GPU : VideoProcessor  \r\r\n                \r\r\n\r\r\n"
10:08:45.289 Info: "GPU RAM : RAM Total : AdapterRAM  \r\r\n            \r\r\n\r\r\n B"
10:08:45.290 Info: "OS : winnt  - x86_64 - Version : Windows 10 Version 2004 - Kernel : 10.0.19041"
10:08:45.290 Info: *** Qt screens ***
10:08:45.291 Info: "( 1 : 3840 x 2160 )"
10:09:52.245 Debug: Export XML de 50 schemas (../sources/qetproject.cpp:852, QDomDocument QETProject::toXml())
10:09:52.247 Debug: "exporting diagram \"References Page\"" [ Diagram(0x1107e1e0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.249 Debug: "exporting diagram \"Folio list 1\"" [ Diagram(0xc8dacb0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.250 Debug: "exporting diagram \"Folio list 2\"" [ Diagram(0x11a14bf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.251 Debug: "exporting diagram \"Mains Power Supply\"" [ Diagram(0x11b7ee80) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.256 Debug: "exporting diagram \"Auxiliary Power Supply\"" [ Diagram(0x1178a290) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.263 Debug: "exporting diagram \"Emergency Stop Circuit\"" [ Diagram(0x113232d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.270 Debug: "exporting diagram \"Emergency Stop Power\"" [ Diagram(0x11322c90) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.273 Debug: "exporting diagram \"VX Gate Control Circuit\"" [ Diagram(0xc37c0c0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.278 Debug: "exporting diagram \"V1 Gate Control Circuit\"" [ Diagram(0xc37ba80) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.288 Debug: "exporting diagram \"V2 Gate Control Circuit\"" [ Diagram(0x15930f70) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.297 Debug: "exporting diagram \"V3 Gate Control Circuit\"" [ Diagram(0x1592e9f0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.307 Debug: "exporting diagram \"V4 Gate Control Circuit\"" [ Diagram(0x15931290) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.317 Debug: "exporting diagram \"V5 Gate Control Circuit\"" [ Diagram(0x15931bf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.326 Debug: "exporting diagram \"V6 Gate Control Circuit\"" [ Diagram(0xc50f570) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.336 Debug: "exporting diagram \"V7 Gate Control Circuit\"" [ Diagram(0xc510830) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.342 Debug: "exporting diagram \"A0 PLC Layout\"" [ Diagram(0x1656c3a0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.348 Debug: "exporting diagram \"A0 Input Module\"" [ Diagram(0x1656e600) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.352 Debug: "exporting diagram \"A0 Output Module\"" [ Diagram(0x1656dfc0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.353 Debug: "exporting diagram \"A1/1 Input Module\"" [ Diagram(0x1656c080) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.357 Debug: "exporting diagram \"A1/2 Input Module\"" [ Diagram(0x1656ec40) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.361 Debug: "exporting diagram \"A1 Output Module\"" [ Diagram(0x1656cd00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.367 Debug: "exporting diagram \"A2/1 Input Module\"" [ Diagram(0x1656d020) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.371 Debug: "exporting diagram \"A2/2 Input Module\"" [ Diagram(0x16caad00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.375 Debug: "exporting diagram \"A2 Output Module\"" [ Diagram(0x16cab660) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.380 Debug: "exporting diagram \"A3/1 Input Module\"" [ Diagram(0x16caa3a0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.384 Debug: "exporting diagram \"A3/2 Input Module\"" [ Diagram(0x16cabfc0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.388 Debug: "exporting diagram \"A3 Output Module\"" [ Diagram(0x16cac920) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.393 Debug: "exporting diagram \"A4/1 Input Module\"" [ Diagram(0x16f0dbd0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.397 Debug: "exporting diagram \"A4/2 Input Module\"" [ Diagram(0x16f0b010) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.399 Debug: "exporting diagram \"A4 Output Module\"" [ Diagram(0x16f0bfb0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.402 Debug: "exporting diagram \"A5/1 Ana Input Module\"" [ Diagram(0x16f0acf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.406 Debug: "exporting diagram \"A5/2 Ana Input Module\"" [ Diagram(0x16f0d270) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.408 Debug: "exporting diagram \"TB1 Terminal Bord\"" [ Diagram(0x16f0b970) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.416 Debug: "exporting diagram \"TB2 Terminal Bord\"" [ Diagram(0x16f0a070) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.422 Debug: "exporting diagram \"TB3 Terminal Bord\"" [ Diagram(0x16f0cc30) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.425 Debug: "exporting diagram \"TB4 Terminal Bord\"" [ Diagram(0x16f0c2d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.430 Debug: "exporting diagram \"TB5 Terminal Bord\"" [ Diagram(0x16f0b330) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.431 Debug: "exporting diagram \"PB1 Panel Front View\"" [ Diagram(0x16f0bc90) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.433 Debug: "exporting diagram \"PB2 Panel Front View\"" [ Diagram(0x16f0c5f0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.442 Debug: "exporting diagram \"CX1 Modbus TCP\"" [ Diagram(0x16f0cf50) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.448 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0d590) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.449 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0a6b0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.450 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0a9d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.451 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888220) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.451 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc886f60) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.452 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888860) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.453 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888540) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.454 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc884d00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.454 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc885660) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:09:52.455 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc886c40) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:19.986 Debug: BOMExportDialog::getBom : query errir :  QSqlError("", "Impossible de r�cup�rer la ligne", "Pas de requ�te") (../sources/ui/bomexportdialog.cpp:102, QString BOMExportDialog::getBom())
10:10:19.987 Debug: "" (../sources/ui/bomexportdialog.cpp:157, QString BOMExportDialog::getBom())
10:10:52.464 Debug: Export XML de 50 schemas (../sources/qetproject.cpp:852, QDomDocument QETProject::toXml())
10:10:52.466 Debug: "exporting diagram \"References Page\"" [ Diagram(0x1107e1e0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.469 Debug: "exporting diagram \"Folio list 1\"" [ Diagram(0xc8dacb0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.471 Debug: "exporting diagram \"Folio list 2\"" [ Diagram(0x11a14bf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.472 Debug: "exporting diagram \"Mains Power Supply\"" [ Diagram(0x11b7ee80) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.478 Debug: "exporting diagram \"Auxiliary Power Supply\"" [ Diagram(0x1178a290) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.485 Debug: "exporting diagram \"Emergency Stop Circuit\"" [ Diagram(0x113232d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.492 Debug: "exporting diagram \"Emergency Stop Power\"" [ Diagram(0x11322c90) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.495 Debug: "exporting diagram \"VX Gate Control Circuit\"" [ Diagram(0xc37c0c0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.500 Debug: "exporting diagram \"V1 Gate Control Circuit\"" [ Diagram(0xc37ba80) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.510 Debug: "exporting diagram \"V2 Gate Control Circuit\"" [ Diagram(0x15930f70) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.520 Debug: "exporting diagram \"V3 Gate Control Circuit\"" [ Diagram(0x1592e9f0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.530 Debug: "exporting diagram \"V4 Gate Control Circuit\"" [ Diagram(0x15931290) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.540 Debug: "exporting diagram \"V5 Gate Control Circuit\"" [ Diagram(0x15931bf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.550 Debug: "exporting diagram \"V6 Gate Control Circuit\"" [ Diagram(0xc50f570) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.561 Debug: "exporting diagram \"V7 Gate Control Circuit\"" [ Diagram(0xc510830) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.571 Debug: "exporting diagram \"A0 PLC Layout\"" [ Diagram(0x1656c3a0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.575 Debug: "exporting diagram \"A0 Input Module\"" [ Diagram(0x1656e600) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.577 Debug: "exporting diagram \"A0 Output Module\"" [ Diagram(0x1656dfc0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.579 Debug: "exporting diagram \"A1/1 Input Module\"" [ Diagram(0x1656c080) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.583 Debug: "exporting diagram \"A1/2 Input Module\"" [ Diagram(0x1656ec40) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.587 Debug: "exporting diagram \"A1 Output Module\"" [ Diagram(0x1656cd00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.593 Debug: "exporting diagram \"A2/1 Input Module\"" [ Diagram(0x1656d020) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.597 Debug: "exporting diagram \"A2/2 Input Module\"" [ Diagram(0x16caad00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.601 Debug: "exporting diagram \"A2 Output Module\"" [ Diagram(0x16cab660) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.607 Debug: "exporting diagram \"A3/1 Input Module\"" [ Diagram(0x16caa3a0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.611 Debug: "exporting diagram \"A3/2 Input Module\"" [ Diagram(0x16cabfc0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.615 Debug: "exporting diagram \"A3 Output Module\"" [ Diagram(0x16cac920) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.621 Debug: "exporting diagram \"A4/1 Input Module\"" [ Diagram(0x16f0dbd0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.625 Debug: "exporting diagram \"A4/2 Input Module\"" [ Diagram(0x16f0b010) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.626 Debug: "exporting diagram \"A4 Output Module\"" [ Diagram(0x16f0bfb0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.630 Debug: "exporting diagram \"A5/1 Ana Input Module\"" [ Diagram(0x16f0acf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.633 Debug: "exporting diagram \"A5/2 Ana Input Module\"" [ Diagram(0x16f0d270) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.636 Debug: "exporting diagram \"TB1 Terminal Bord\"" [ Diagram(0x16f0b970) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.644 Debug: "exporting diagram \"TB2 Terminal Bord\"" [ Diagram(0x16f0a070) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.650 Debug: "exporting diagram \"TB3 Terminal Bord\"" [ Diagram(0x16f0cc30) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.653 Debug: "exporting diagram \"TB4 Terminal Bord\"" [ Diagram(0x16f0c2d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.659 Debug: "exporting diagram \"TB5 Terminal Bord\"" [ Diagram(0x16f0b330) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.660 Debug: "exporting diagram \"PB1 Panel Front View\"" [ Diagram(0x16f0bc90) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.662 Debug: "exporting diagram \"PB2 Panel Front View\"" [ Diagram(0x16f0c5f0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.671 Debug: "exporting diagram \"CX1 Modbus TCP\"" [ Diagram(0x16f0cf50) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.678 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0d590) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.678 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0a6b0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.679 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0a9d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.680 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888220) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.681 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc886f60) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.681 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888860) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.682 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888540) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.683 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc884d00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.684 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc885660) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:10:52.684 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc886c40) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:14.164 Debug: ("{63-rev3}", "{53-desr3}", "{43-dater3}", "{33-initr3}", "DATE", "{20-emissiondate}", "", "{title}", "{projecttitle}", "{01-numproj}", "{62-rev2}", "{52-desr2}", "{42-dater2}", "{32-initr2}", "DSGN", "{21-design}", "{61-rev1}", "{51-desr1}", "{41-dater1}", "{31-initr1}", "CHKD", "{22-chkd}", "{machine}", "{locmach}", "{folio-id}", "REV", "MOD", "DATE", "INIT", "APPD", "{23-appd}", "{11-service1}", "{12-service2}", "{10-source}", "{71-nextpg}") (../sources/titleblocktemplate.cpp:1719, QStringList TitleBlockTemplate::listOfVariables())
10:11:52.246 Debug: Export XML de 50 schemas (../sources/qetproject.cpp:852, QDomDocument QETProject::toXml())
10:11:52.252 Debug: "exporting diagram \"References Page\"" [ Diagram(0x1107e1e0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.254 Debug: "exporting diagram \"Folio list 1\"" [ Diagram(0xc8dacb0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.255 Debug: "exporting diagram \"Folio list 2\"" [ Diagram(0x11a14bf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.256 Debug: "exporting diagram \"Mains Power Supply\"" [ Diagram(0x11b7ee80) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.262 Debug: "exporting diagram \"Auxiliary Power Supply\"" [ Diagram(0x1178a290) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.269 Debug: "exporting diagram \"Emergency Stop Circuit\"" [ Diagram(0x113232d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.277 Debug: "exporting diagram \"Emergency Stop Power\"" [ Diagram(0x11322c90) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.282 Debug: "exporting diagram \"VX Gate Control Circuit\"" [ Diagram(0xc37c0c0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.291 Debug: "exporting diagram \"V1 Gate Control Circuit\"" [ Diagram(0xc37ba80) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.304 Debug: "exporting diagram \"V2 Gate Control Circuit\"" [ Diagram(0x15930f70) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.317 Debug: "exporting diagram \"V3 Gate Control Circuit\"" [ Diagram(0x1592e9f0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.326 Debug: "exporting diagram \"V4 Gate Control Circuit\"" [ Diagram(0x15931290) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.337 Debug: "exporting diagram \"V5 Gate Control Circuit\"" [ Diagram(0x15931bf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.347 Debug: "exporting diagram \"V6 Gate Control Circuit\"" [ Diagram(0xc50f570) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.357 Debug: "exporting diagram \"V7 Gate Control Circuit\"" [ Diagram(0xc510830) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.366 Debug: "exporting diagram \"A0 PLC Layout\"" [ Diagram(0x1656c3a0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.370 Debug: "exporting diagram \"A0 Input Module\"" [ Diagram(0x1656e600) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.372 Debug: "exporting diagram \"A0 Output Module\"" [ Diagram(0x1656dfc0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.374 Debug: "exporting diagram \"A1/1 Input Module\"" [ Diagram(0x1656c080) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.378 Debug: "exporting diagram \"A1/2 Input Module\"" [ Diagram(0x1656ec40) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.382 Debug: "exporting diagram \"A1 Output Module\"" [ Diagram(0x1656cd00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.387 Debug: "exporting diagram \"A2/1 Input Module\"" [ Diagram(0x1656d020) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.391 Debug: "exporting diagram \"A2/2 Input Module\"" [ Diagram(0x16caad00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.395 Debug: "exporting diagram \"A2 Output Module\"" [ Diagram(0x16cab660) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.401 Debug: "exporting diagram \"A3/1 Input Module\"" [ Diagram(0x16caa3a0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.405 Debug: "exporting diagram \"A3/2 Input Module\"" [ Diagram(0x16cabfc0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.409 Debug: "exporting diagram \"A3 Output Module\"" [ Diagram(0x16cac920) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.415 Debug: "exporting diagram \"A4/1 Input Module\"" [ Diagram(0x16f0dbd0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.419 Debug: "exporting diagram \"A4/2 Input Module\"" [ Diagram(0x16f0b010) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.420 Debug: "exporting diagram \"A4 Output Module\"" [ Diagram(0x16f0bfb0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.424 Debug: "exporting diagram \"A5/1 Ana Input Module\"" [ Diagram(0x16f0acf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.427 Debug: "exporting diagram \"A5/2 Ana Input Module\"" [ Diagram(0x16f0d270) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.430 Debug: "exporting diagram \"TB1 Terminal Bord\"" [ Diagram(0x16f0b970) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.438 Debug: "exporting diagram \"TB2 Terminal Bord\"" [ Diagram(0x16f0a070) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.443 Debug: "exporting diagram \"TB3 Terminal Bord\"" [ Diagram(0x16f0cc30) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.446 Debug: "exporting diagram \"TB4 Terminal Bord\"" [ Diagram(0x16f0c2d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.452 Debug: "exporting diagram \"TB5 Terminal Bord\"" [ Diagram(0x16f0b330) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.452 Debug: "exporting diagram \"PB1 Panel Front View\"" [ Diagram(0x16f0bc90) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.454 Debug: "exporting diagram \"PB2 Panel Front View\"" [ Diagram(0x16f0c5f0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.464 Debug: "exporting diagram \"CX1 Modbus TCP\"" [ Diagram(0x16f0cf50) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.470 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0d590) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.471 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0a6b0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.471 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0a9d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.472 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888220) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.473 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc886f60) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.473 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888860) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.474 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888540) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.475 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc884d00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.476 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc885660) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.476 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc886c40) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.495 Debug: Export XML de 50 schemas (../sources/qetproject.cpp:852, QDomDocument QETProject::toXml())
10:11:52.496 Debug: "exporting diagram \"References Page\"" [ Diagram(0x1107e1e0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.499 Debug: "exporting diagram \"Folio list 1\"" [ Diagram(0xc8dacb0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.500 Debug: "exporting diagram \"Folio list 2\"" [ Diagram(0x11a14bf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.500 Debug: "exporting diagram \"Mains Power Supply\"" [ Diagram(0x11b7ee80) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.502 Debug: "exporting diagram \"Auxiliary Power Supply\"" [ Diagram(0x1178a290) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.512 Debug: "exporting diagram \"Emergency Stop Circuit\"" [ Diagram(0x113232d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.521 Debug: "exporting diagram \"Emergency Stop Power\"" [ Diagram(0x11322c90) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.523 Debug: "exporting diagram \"VX Gate Control Circuit\"" [ Diagram(0xc37c0c0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.528 Debug: "exporting diagram \"V1 Gate Control Circuit\"" [ Diagram(0xc37ba80) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.539 Debug: "exporting diagram \"V2 Gate Control Circuit\"" [ Diagram(0x15930f70) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.548 Debug: "exporting diagram \"V3 Gate Control Circuit\"" [ Diagram(0x1592e9f0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.559 Debug: "exporting diagram \"V4 Gate Control Circuit\"" [ Diagram(0x15931290) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.568 Debug: "exporting diagram \"V5 Gate Control Circuit\"" [ Diagram(0x15931bf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.579 Debug: "exporting diagram \"V6 Gate Control Circuit\"" [ Diagram(0xc50f570) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.588 Debug: "exporting diagram \"V7 Gate Control Circuit\"" [ Diagram(0xc510830) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.599 Debug: "exporting diagram \"A0 PLC Layout\"" [ Diagram(0x1656c3a0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.604 Debug: "exporting diagram \"A0 Input Module\"" [ Diagram(0x1656e600) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.606 Debug: "exporting diagram \"A0 Output Module\"" [ Diagram(0x1656dfc0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.608 Debug: "exporting diagram \"A1/1 Input Module\"" [ Diagram(0x1656c080) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.614 Debug: "exporting diagram \"A1/2 Input Module\"" [ Diagram(0x1656ec40) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.614 Debug: "exporting diagram \"A1 Output Module\"" [ Diagram(0x1656cd00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.623 Debug: "exporting diagram \"A2/1 Input Module\"" [ Diagram(0x1656d020) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.627 Debug: "exporting diagram \"A2/2 Input Module\"" [ Diagram(0x16caad00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.631 Debug: "exporting diagram \"A2 Output Module\"" [ Diagram(0x16cab660) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.637 Debug: "exporting diagram \"A3/1 Input Module\"" [ Diagram(0x16caa3a0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.641 Debug: "exporting diagram \"A3/2 Input Module\"" [ Diagram(0x16cabfc0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.645 Debug: "exporting diagram \"A3 Output Module\"" [ Diagram(0x16cac920) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.651 Debug: "exporting diagram \"A4/1 Input Module\"" [ Diagram(0x16f0dbd0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.654 Debug: "exporting diagram \"A4/2 Input Module\"" [ Diagram(0x16f0b010) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.656 Debug: "exporting diagram \"A4 Output Module\"" [ Diagram(0x16f0bfb0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.659 Debug: "exporting diagram \"A5/1 Ana Input Module\"" [ Diagram(0x16f0acf0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.662 Debug: "exporting diagram \"A5/2 Ana Input Module\"" [ Diagram(0x16f0d270) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.665 Debug: "exporting diagram \"TB1 Terminal Bord\"" [ Diagram(0x16f0b970) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.673 Debug: "exporting diagram \"TB2 Terminal Bord\"" [ Diagram(0x16f0a070) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.679 Debug: "exporting diagram \"TB3 Terminal Bord\"" [ Diagram(0x16f0cc30) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.682 Debug: "exporting diagram \"TB4 Terminal Bord\"" [ Diagram(0x16f0c2d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.687 Debug: "exporting diagram \"TB5 Terminal Bord\"" [ Diagram(0x16f0b330) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.688 Debug: "exporting diagram \"PB1 Panel Front View\"" [ Diagram(0x16f0bc90) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.690 Debug: "exporting diagram \"PB2 Panel Front View\"" [ Diagram(0x16f0c5f0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.699 Debug: "exporting diagram \"CX1 Modbus TCP\"" [ Diagram(0x16f0cf50) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.706 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0d590) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.706 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0a6b0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.707 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0x16f0a9d0) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.708 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888220) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.708 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc886f60) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.709 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888860) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.710 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc888540) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.711 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc884d00) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.711 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc885660) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:11:52.712 Debug: "exporting diagram \"Nomenclature\"" [ Diagram(0xc886c40) ] (../sources/qetproject.cpp:857, QDomDocument QETProject::toXml())
10:18:01.697 Info: Start-up
10:18:02.064 Info: debugging enabled: false
10:18:02.070 Info: Qt library version: 5.12.4
10:18:02.078 Info: Qt library location default prefix: "C:\\Qt\\5.12.4\\mingw73_64"
10:18:02.082 Info: Qt library location documentation: "C:/Qt/5.12.4/mingw73_64/doc"
10:18:02.086 Info: Qt library location headers: "C:/Qt/5.12.4/mingw73_64/include"
10:18:02.091 Info: Qt library location libraries: "C:/Qt/5.12.4/mingw73_64/lib"
10:18:02.097 Info: Qt library location executables: "C:/Qt/5.12.4/mingw73_64/bin"
10:18:02.102 Info: Qt library location Qt binaries: "C:/Qt/5.12.4/mingw73_64/bin"
10:18:02.107 Info: Qt library location Qt plugins: "C:/Qt/5.12.4/mingw73_64/plugins"
10:18:02.112 Info: Qt library location installed QML extensions: "C:/Qt/5.12.4/mingw73_64/imports"
10:18:02.118 Info: Qt library location installed QML extensions: "C:/Qt/5.12.4/mingw73_64/qml"
10:18:02.123 Info: Qt library location dependent Qt data: "C:/Qt/5.12.4/mingw73_64"
10:18:02.129 Info: Qt library location independent Qt data: "C:/Qt/5.12.4/mingw73_64"
10:18:02.135 Info: Qt library location translation: "C:/Qt/5.12.4/mingw73_64/translations"
10:18:02.140 Info: Qt library location examples: "C:/Qt/5.12.4/mingw73_64/examples"
10:18:02.146 Info: Qt library location Qt testcases: "C:/Qt/5.12.4/mingw73_64/tests"
10:18:02.151 Info: "QElectroTech V 0.80-DEV"
10:18:02.156 Info: "Compilation : GCC 7.3.0"
10:18:02.162 Info: "Built with Qt 5.12.4 - Date : Aug 24 2020 : 10:14:55"
10:18:02.167 Info: "Run with Qt 5.12.4 using 24 thread(s)"
10:18:02.173 Info: "CPU : NAME                                            \r\r\nAMD RYZEN THREADRIPPER 3960X 24-CORE PROCESSOR  \r\r\n\r\r\n"
10:18:02.178 Info: "RAM Total : 25738 MB"
10:18:02.184 Info: "RAM Available : 21149 MB"
10:18:02.190 Info: "GPU : VideoProcessor  \r\r\n                \r\r\n\r\r\n"
10:18:02.195 Info: "GPU RAM : RAM Total : AdapterRAM  \r\r\n            \r\r\n\r\r\n B"
10:18:02.201 Info: "OS : winnt  - x86_64 - Version : Windows 10 (10.0) - Kernel : 10.0.19041"
10:18:02.206 Info: *** Qt screens ***
10:18:02.210 Info: "( 1 : 3840 x 2160 )"
Re: removing orientation for element.
WIN10 VM :
15 sec to load all Elements collection
Fix ?
see:
Not fixed here ..
Fix ?
see:
Not fixed here ..
I will probably look over it, I will look again tomorrow.
Try QDir::homePath() + "/.qet/
rather than const QString path = QETApp::configDir() + "/";
Example here :
https://git.tuxfamily.org/qet/qet.git/t … .cpp#n2251
https://git.tuxfamily.org/qet/qet.git/t … .cpp#n1132
Example here :
see
https://git.tuxfamily.org/qet/qet.git/c … a44c426f82
for -win32-readytouse.7z
I build and pushed all packages, please try it.
I checked on Flatpak VM, is ok ~ 2 s to launch QET.
10:27:57.290 Info: Start-up
10:27:57.347 Info: debugging enabled: false
10:27:57.347 Info: Qt library version: 5.14.2
10:27:57.347 Info: Qt library location default prefix: "/usr"
10:27:57.347 Info: Qt library location documentation: "/usr/doc"
10:27:57.347 Info: Qt library location headers: "/usr/include"
10:27:57.347 Info: Qt library location libraries: "/usr/lib/x86_64-linux-gnu"
10:27:57.348 Info: Qt library location executables: "/usr/lib/libexec"
10:27:57.348 Info: Qt library location Qt binaries: "/usr/bin"
10:27:57.348 Info: Qt library location Qt plugins: "/usr/lib/plugins"
10:27:57.348 Info: Qt library location installed QML extensions: "/usr/lib/imports"
10:27:57.348 Info: Qt library location installed QML extensions: "/usr/lib/qml"
10:27:57.348 Info: Qt library location dependent Qt data: "/usr/lib"
10:27:57.348 Info: Qt library location independent Qt data: "/usr"
10:27:57.348 Info: Qt library location translation: "/usr/translations"
10:27:57.348 Info: Qt library location examples: "/usr/examples"
10:27:57.348 Info: Qt library location Qt testcases: "/usr/tests"
10:27:57.348 Info: Qt library location Qt settings: "/usr/etc/xdg"
10:27:57.349 Info: "QElectroTech V 0.80-DEV+81da7c671"
10:27:57.349 Info: "Compilation : GCC 9.3.0"
10:27:57.349 Info: "Built with Qt 5.14.2 - Date : May  1 2020 : 20:10:52"
10:27:57.349 Info: "Run with Qt 5.14.2 using 24 thread(s)"
10:27:57.349 Info: "CPU : model name\t: AMD EPYC Processor (with IBPB)\n"
10:27:57.349 Info: "RAM Total : 15692 MB"
10:27:57.349 Info: "RAM Available : 14708 MB"
10:27:57.349 Info: "GPU :  Red Hat, Inc. Virtio GPU (rev 01)\n"
10:27:57.349 Info: "GPU RAM : @ToDo"
10:27:57.349 Info: "OS : linux  - x86_64 - Version : KDE Flatpak runtime - Kernel : 4.9.0-12-amd64"
10:27:57.349 Info: *** Qt screens ***
10:27:57.349 Info: "( 1 : 1920 x 1080 )"
10:27:57.617 Info: Elements collection reload
10:27:58.177 Info: Elements collection finished to be loaded
11:21:18.660 Info: Start-up
11:21:18.731 Info: debugging enabled: false
11:21:18.731 Info: Qt library version: 5.14.2
11:21:18.731 Info: Qt library location default prefix: "/usr"
11:21:18.731 Info: Qt library location documentation: "/usr/doc"
11:21:18.732 Info: Qt library location headers: "/usr/include"
11:21:18.732 Info: Qt library location libraries: "/usr/lib/x86_64-linux-gnu"
11:21:18.732 Info: Qt library location executables: "/usr/lib/libexec"
11:21:18.732 Info: Qt library location Qt binaries: "/usr/bin"
11:21:18.732 Info: Qt library location Qt plugins: "/usr/lib/plugins"
11:21:18.732 Info: Qt library location installed QML extensions: "/usr/lib/imports"
11:21:18.732 Info: Qt library location installed QML extensions: "/usr/lib/qml"
11:21:18.732 Info: Qt library location dependent Qt data: "/usr/lib"
11:21:18.732 Info: Qt library location independent Qt data: "/usr"
11:21:18.732 Info: Qt library location translation: "/usr/translations"
11:21:18.732 Info: Qt library location examples: "/usr/examples"
11:21:18.732 Info: Qt library location Qt testcases: "/usr/tests"
11:21:18.733 Info: Qt library location Qt settings: "/usr/etc/xdg"
11:21:18.733 Info: "QElectroTech V 0.80-DEV+81da7c671"
11:21:18.733 Info: "Compilation : GCC 9.3.0"
11:21:18.733 Info: "Built with Qt 5.14.2 - Date : May  1 2020 : 20:10:52"
11:21:18.733 Info: "Run with Qt 5.14.2 using 24 thread(s)"
11:21:18.733 Info: "CPU : model name\t: AMD EPYC Processor (with IBPB)\n"
11:21:18.733 Info: "RAM Total : 15692 MB"
11:21:18.733 Info: "RAM Available : 14861 MB"
11:21:18.733 Info: "GPU :  Red Hat, Inc. Virtio GPU (rev 01)\n"
11:21:18.733 Info: "GPU RAM : @ToDo"
11:21:18.733 Info: "OS : linux  - x86_64 - Version : KDE Flatpak runtime - Kernel : 4.9.0-12-amd64"
11:21:18.733 Info: *** Qt screens ***
11:21:18.733 Info: "( 1 : 1920 x 1080 )"
11:21:19.889 Info: Elements collection reload
11:21:20.924 Info: Elements collection finished to be loaded
No time these next days to study why on my Debian SID machine I don't have the logs.
My setup launches QET too quickly which is ashamed to show its logs for fear of making those under Windows cry, uhuhu.
you think we could also find the versions of third-party libraries like KwidgetAddons, KcoreAddons, ECM?
Good work Simon these logs will help us a lot.
when you do have the time launch to qElectroTech through the shell and at the directory dire.
23 (edited by Re-searcher 2020-09-01 16:35:32)
Log files : QET version 6698 on PC laptop from 2009 with 1 hard disk
I have changed the orginal drive to an 320GB harddisk
The Windows on dual boot system with XUbuntu
I have changed the drive to 500GB SSD
Debian stable ( Buster )
I have tree drives now for this pc laptop
Log file : 6698 Windows ready To Use
25 (edited by Re-searcher 2020-09-01 16:41:00)
Log file : 6698 : Debian stable (Buster) on 500GB SSD
Attachment icon 20200901-6698-Debian stable(buster).log 2.33 kb, 329 downloads since 2020-09-01
