Topic: Mod version name
Get the version name from git.
eg: git describe
add line in qelectrotech.pro
DEFINES += GIT_VERSION="\\\"$(shell git -C \""$$_PRO_FILE_PWD_"\" describe)\\\""
mod line in aboutqetdialog.cpp
@@ -141,7 +141,7 @@ void AboutQETDialog::setContributors()
void AboutQETDialog::setVersion()
     QString str = "<span style=\"font-weight:bold;font-size:16pt;\">QElectroTech V "
-            + QET::displayedVersion
+            + QString(GIT_VERSION)
             + "</span>";
condition: add "Make clean" at the beginning of the Build Steps
Question: Is it worth knowing the git SHA1 ID if you will always need to build full
Re: Mod version name
I already do it in the packaging scripts.
https://qelectrotech.org/forum/viewtopi … 045#p10045
https://qelectrotech.org/wiki_new/doc/packaging_debian
GITCOMMIT=$(git rev-parse --short HEAD)
#Find Subversion revision number in trunk branch
if [ -z "$HEAD" ] ; then
#HEAD=$(svn --xml info svn://svn.tuxfamily.org/svnroot/qet/qet/trunk | grep revision=\" | tail -1 | cut -d\" -f2)
A=$(git rev-list HEAD --count)
HEAD=$(($A+473))
fi
VERSION=$(cat sources/qet.h | grep "const QString version" |  cut -d\" -f2 | cut -d\" -f1)          #Find version tag in Subversion sources/qet.h
tagName=$(cat sources/qet.h | grep displayedVersion |  cut -d\" -f2 | cut -d\" -f1)                 #Find displayedVersion tag in Subversion sources/qet.h
cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD/debian/patches/
sed -i 's/'"$tagName+[0-9]*"'/'"$tagName+$GITCOMMIT"'/' 03_qet.diff
https://qelectrotech.org/wiki_new/doc/p … n#appimage
https://git.tuxfamily.org/qet/qet.git/t … t.yaml#n98
3 (edited by De-Backer 2020-07-24 15:25:46)
Okay I drop it,
About the loading time (especially under Windows): can I help with that or not?
And so what?
Yes you can help to improve QET under Windows.
