Table des matières
Notes
Dépôt Debian QElectroTech
#for Debian Sid aka unstable
deb http://debian.qelectrotech.org/qet/debian/ unstable main deb-src http://debian.qelectrotech.org/qet/debian/ unstable main
#for Debian stable
deb http://debian.qelectrotech.org/qet/debian/ stable main deb-src http://debian.qelectrotech.org/qet/debian/ stable main
Git Debian package
packaging_script Debian, Ubuntu, Windows
#!/bin/bash #nettoyage des chroots #set -x eval $(gpg-agent --daemon) #variables repertoires de travail DEFAULT_DIR="$HOME/paquet_qet" TEMP_DIR="$HOME" SSH_TARGET='scorpio810@ssh.tuxfamily.org:/home/qet/qelectrotech.org-web/htdocs/dl_link.inc.php' SSH_OPTIONS=-B #Find Subversion revision number in 0.60 branch #if [ -z "$HEAD" ] ; then #HEAD=$(svn --xml info svn://svn.tuxfamily.org/svnroot/qet/qet/branches/0.60 | grep revision=\" | tail -1 | cut -d\" -f2) #fi #VERSION=$(svn cat svn://svn.tuxfamily.org/svnroot/qet/qet/branches/0.60/sources/qet.h | grep "const QString version" | cut -d\" -f2 | cut -d\" -f1) #Find version tag in Subversion sources/qet.h #tagName=$(svn cat svn://svn.tuxfamily.org/svnroot/qet/qet/branches/0.60/sources/qet.h | grep displayedVersion | cut -d\" -f2 | cut -d\" -f1) #Find displayedVersion tag in Subversion sources/qet.h cd $DEFAULT_DIR cd qet_git git pull #git checkout test_pugi GITCOMMIT=$(git rev-parse --short HEAD) #Find Subversion revision number in trunk branch if [ -z "$HEAD" ] ; then #HEAD=$(svn --xml info svn://svn.tuxfamily.org/svnroot/qet/qet/trunk | grep revision=\" | tail -1 | cut -d\" -f2) A=$(git rev-list HEAD --count) HEAD=$(($A+473)) # force displayed number fi VERSION=$(cat sources/qet.h | grep "const QString version" | cut -d\" -f2 | cut -d\" -f1) #Find version tag in Subversion sources/qet.h tagName=$(cat sources/qet.h | grep displayedVersion | cut -d\" -f2 | cut -d\" -f1) #Find displayedVersion tag in Subversion sources/qet.h #git ls-remote https://git.tuxfamily.org/qet/qet.git/ | head -1 | cut -c1-10 #95d1fca171 #git rev-list HEAD --count #5475 #clean /var/cache/pbuilder/ .. / result/debs echo -e "\033[1;31mWould you like to clean all debs n/Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then echo -e "\033[1;31mClean_all_base_environment.\033[m" cd /var/cache/pbuilder/stable-amd64/result/ && sudo rm qe* cd /var/cache/pbuilder/unstable-amd64/result/ && sudo rm qe* cd /var/cache/pbuilder/stable-i386/result/ && sudo rm qe* cd /var/cache/pbuilder/unstable-i386/result/ && sudo rm qe* else echo -e "\033[1;33mNo Clean_all_base_environment.\033[m" fi #clean all apt cache echo -e "\033[1;31mWould you like to clean all pbuilder n/Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then echo -e "\033[1;31mClean_all_pbuilder_environment.\033[m" DIST=stable ARCH=i386 sudo pbuilder --clean DIST=stable ARCH=amd64 sudo pbuilder --clean DIST=unstable ARCH=i386 sudo pbuilder --clean DIST=unstable ARCH=amd64 sudo pbuilder --clean else echo -e "\033[1;33mNo Clean_all_pbuilder_environment.\033[m" fi #Update des chroots echo -e "\033[1;31mWould you like to update all chroots n/Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then echo -e "\033[1;33mUpdate_all_base_environment..\033[m" sudo DIST=stable ARCH=i386 pbuilder update --override-config --configfile /home/laurent/.pbuilderrc sudo DIST=sid ARCH=i386 pbuilder update --override-config --configfile /home/laurent/.pbuilderrc sudo DIST=stable pbuilder update --override-config --configfile /home/laurent/.pbuilderrc sudo DIST=sid pbuilder update --override-config --configfile /home/laurent/.pbuilderrc else echo -e "\033[1;33mNo Update_all_base_environment.\033[m" fi echo -e "\033[1;34mdownload source qelectrotech-$VERSION.r$HEAD.\033[m" cd $TEMP_DIR #get latest source revision # svn export svn://svn.tuxfamily.org/svnroot/qet/qet/trunk --revision 5212 qelectrotech-$VERSION.r$HEAD/ # force a specific version in trunk #svn export svn://svn.tuxfamily.org/svnroot/qet/qet/trunk qelectrotech-$VERSION.r$HEAD/ #svn export svn://svn.tuxfamily.org/svnroot/qet/qet/branches/0.60 qelectrotech-$VERSION.r$HEAD/ # Branch 0.61 cp -r $DEFAULT_DIR/qet_git/ $TEMP_DIR/qelectrotech-$VERSION.r$HEAD/ rm -rf qelectrotech-$VERSION.r$HEAD/.git #create svn tarball tar cfvz qelectrotech-$VERSION.r$HEAD.tar.gz qelectrotech-$VERSION.r$HEAD/ #copy tarball in $DEFAULT_DIR cp qelectrotech-$VERSION.r$HEAD.tar.gz $DEFAULT_DIR clean $TEMP_DIR rm -Rf qelectrotech-$VERSION.r$HEAD/ && rm qelectrotech-$VERSION.r$HEAD.tar.gz #return to working directory cd $DEFAULT_DIR #extract tarball and go to archive tar zxvf qelectrotech-$VERSION.r$HEAD.tar.gz && cd qelectrotech-$VERSION.r$HEAD/ #create origin.tar.gz dh_make -e scorpio@qelectrotech.org -c gpl2 -f ../qelectrotech-$VERSION.r$HEAD.tar.gz #clean debian folder cd / rm -Rf debian/ #return to working directory cd $DEFAULT_DIR #copy debian folder cp -r debian/ qelectrotech-$VERSION.r$HEAD/ #update changelog to new release cd qelectrotech-$VERSION.r$HEAD/ dch -d -D unstable "New upstream subversion version " #edit changelog echo -e "\033[1;31mWould you like to edit changelog n/Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then echo -e "\033[1;31mEdit debian changelog..\033[m" dch --edit else echo -e "\033[1;33mNo edit changelog.\033[m" fi cd debian/ && rm -rf *ex *EX README* cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD/debian/patches/ sed -i 's/'"$tagName+[0-9]*"'/'"$tagName+$GITCOMMIT"'/' 03_qet.diff #deplacement dans le paquet_qet cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD/ quilt push quilt push quilt refresh echo -e "\033[1;31mWould you like to build Debian packages n/Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then #build echo -e "\033[1;34mBuild_all_environements.\033[m" sudo DIST=sid ARCH=amd64 pdebuild --configfile /home/laurent/.pbuilderrc sudo DIST=sid ARCH=i386 pdebuild --configfile /home/laurent/.pbuilderrc dch -i -D stable "Backport stable " && sudo DIST=stable ARCH=amd64 pdebuild --configfile /home/laurent/.pbuilderrc sudo DIST=stable ARCH=i386 pdebuild --configfile /home/laurent/.pbuilderrc STRING="Build_all_environements is ready!!!" echo $STRING #save debian/ #echo -e "\033[1;33mDebian sauvegardé.\033[m" #cp -r debian/ $DEFAULT_DIR #prepare download copys cd $DEFAULT_DIR mkdir -p $HEAD/stable/amd64 mkdir -p $HEAD/stable/i386 mkdir -p $HEAD/sid/amd64 mkdir -p $HEAD/sid/i386 #copie des debs des results vers $HEAD find /var/cache/pbuilder/stable-amd64/result -name "qe*" -exec cp {} $DEFAULT_DIR/$HEAD/stable/amd64 \; find /var/cache/pbuilder/stable-i386/result -name "qe*" -exec cp {} $DEFAULT_DIR/$HEAD/stable/i386 \; find /var/cache/pbuilder/unstable-amd64/result -name "qe*" -exec cp {} $DEFAULT_DIR/$HEAD/sid/amd64 \; find /var/cache/pbuilder/unstable-i386/result -name "qe*" -exec cp {} $DEFAULT_DIR/$HEAD/sid/i386 \; #debsign echo -e "\033[1;31mWould you like to sign all packages n/Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then #debsign stable amd64 cd $DEFAULT_DIR/$HEAD/stable/amd64 debsign -k D3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 *.changes echo -e "\033[1;33mAll stable amd64 are sign.\033[m" #debsign sid amd64 cd $DEFAULT_DIR/$HEAD/sid/amd64 debsign -k D3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 *.changes echo -e "\033[1;33mAll sid amd64 are sign.\033[m" #debsign stable i386 cd $DEFAULT_DIR/$HEAD/stable/i386 debsign -k D3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 *.changes echo -e "\033[1;33mAll stable i386 are sign.\033[m" #debsign sid i386 cd $DEFAULT_DIR/$HEAD/sid/i386 debsign -k D3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 *.changes echo -e "\033[1;33mAll sid i386 are sign.\033[m" else echo -e "\033[1;33mExit.\033[m" fi #upload vers incoming echo -e "\033[1;31mWould you like to upload to incoming n/Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then echo -e "\033[1;33mUpload qelectrotech-$VERSION.r$HEAD.\033[m" cd ~/apt #rm db/* reprepro -vb . include unstable $DEFAULT_DIR/$HEAD/sid/amd64/*.changes reprepro -vb . includedeb unstable $DEFAULT_DIR/$HEAD/sid/i386/*i386.deb reprepro -vb . include stable $DEFAULT_DIR/$HEAD/stable/amd64/*.changes reprepro -vb . includedeb stable $DEFAULT_DIR/$HEAD/stable/i386/*i386.deb reprepro -b . export else echo -e "\033[1;33mExit.\033[m" fi #rsync to TF echo -e "\033[1;31mWould you like to RSYNC Debian packages to TF n/Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then echo -e "\033[1;33mRsync to TF qelectrotech-$VERSION.r$HEAD .\033[m" echo -e "\033[1;31mrsync to TF password ssh and TF\033[m" cd $DEFAULT_DIR/script rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/debian/ if [ $? != 0 ]; then { echo "RSYNC ERROR: problem syncing qelectrotech-$VERSION.r$HEAD " rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress --exclude-from=ExclusionRSync ~/apt/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/debian/ } fi else echo -e "\033[1;33mExit.\033[m" fi else echo -e "\033[1;33mExit.\033[m" fi ############# Ubuntu packages ################################################################################################ echo -e "\033[1;31mWould you like to build Ubuntu PPA packages n/Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then #deplacement dans le paquet_qet cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD/ #dch -i -D yakkety "Yakkety Upload to ppa" #debuild -S -sa -k D3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 #dch -i -D xenial "Xenial Upload to ppa" #debuild -S -sa -kD3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 #dch -i -D artful "Artful Upload to ppa" #debuild -S -kD3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 dch -i -D bionic "Bionic Upload to ppa" debuild -S -sa -kD3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 dch -i -D eoan "Eoan Upload to ppa" debuild -S -kD3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 dch -i -D disco "Disco Upload to ppa" debuild -S -kD3439F4E2273F7DCD3228C9EBC9F825E1D4FB6C1 cd $DEFAULT_DIR/ #dput my-ppa qelectrotech_$VERSION.r$HEAD-*ubuntu1_source.changes #dput my-ppa qelectrotech_$VERSION.r$HEAD-*ubuntu2_source.changes #dput my-ppa qelectrotech_$VERSION.r$HEAD-*ubuntu3_source.changes dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu1_source.changes dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu2_source.changes dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu3_source.changes #dput my-ppa-dev qelectrotech_$VERSION.r$HEAD-*ubuntu4_source.changes else echo -e "\033[1;33mExit.\033[m" fi ############# Windows packages ################################################################################################ #copy and update folders of nsis_base skeleton echo -e "\033[1;31mWould you like to build Window packages n/Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then # 32 bits cd $DEFAULT_DIR cp -r qelectrotech-$VERSION.r$HEAD/ qelectrotech-$VERSION.r$HEAD-XP/ cp -r nsis_base nsis_base$HEAD cd qelectrotech-$VERSION.r$HEAD/ cp -r {elements,examples,titleblocks} /$DEFAULT_DIR/nsis_base$HEAD/files cp -r lang/*.qm /$DEFAULT_DIR/nsis_base$HEAD/files/lang cd $DEFAULT_DIR cd qelectrotech-$VERSION.r$HEAD/build-aux/windows/ cp {lang_extra.nsh,QET.nsi,lang_extra_fr.nsh} /$DEFAULT_DIR/nsis_base$HEAD/ # 64 bits cd $DEFAULT_DIR cp -r nsis_base nsis_base64$HEAD cd qelectrotech-$VERSION.r$HEAD/ cp -r {elements,examples,titleblocks} /$DEFAULT_DIR/nsis_base64$HEAD/files cp -r lang/*.qm /$DEFAULT_DIR/nsis_base64$HEAD/files/lang cd $DEFAULT_DIR cd qelectrotech-$VERSION.r$HEAD/build-aux/windows/ cp {lang_extra.nsh,QET64.nsi,lang_extra_fr.nsh} /$DEFAULT_DIR/nsis_base64$HEAD/ #copy and update folders of readytouse_base skeleton cd $DEFAULT_DIR cp -r readytouse_base qelectrotech-$tagName+git$HEAD-x86-win32-readytouse cd qelectrotech-$VERSION.r$HEAD/ cp -r {elements,examples,titleblocks} /$DEFAULT_DIR/qelectrotech-$tagName+git$HEAD-x86-win32-readytouse cp -r lang/*.qm /$DEFAULT_DIR/qelectrotech-$tagName+git$HEAD-x86-win32-readytouse/lang ################################################################################################################# export PATH=/media/backup6/digikam_new2/project/bundles/mxe/build.win32/usr/bin:$PATH #cross-compil 32 bits cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD mkdir build/ && cd build #mxe: qmake-qt5 i686-w64 #/home/laurent/mxe/usr/bin/i686-w64-mingw32.static.posix-qmake-qt5 $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD/qelectrotech.pro /media/backup6/digikam_new2/project/bundles/mxe/build.win32/usr/bin/i686-w64-mingw32.static-qmake-qt5 $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD/qelectrotech.pro #build jobs=17 #build jobs=17 #make -j17 make -j$(nproc) #copy 32 bits binarie to /bin Windows packages cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD/build/release/ cp qelectrotech.exe /$DEFAULT_DIR/nsis_base$HEAD/files/bin cp qelectrotech.exe /$DEFAULT_DIR/qelectrotech-$tagName+git$HEAD-x86-win32-readytouse/bin #copy manifest file to /bin Windows packages #cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD #cp qelectrotech.exe.manifest /$DEFAULT_DIR/nsis_base$HEAD/files/bin #cp qelectrotech.exe.manifest /$DEFAULT_DIR/qelectrotech-$tagName+git$HEAD-x86-win32-readytouse/bin #tag $HEAD by sed for nsis script cd $DEFAULT_DIR/nsis_base$HEAD sed -i 's/'"0.5-dev+[0-9]*"'/'"$tagName"+git"$HEAD"'/' QET.nsi #build Windows installer makensis QET.nsi ################################################################################################################# export PATH=/media/backup6/digikam_new2/project/bundles/mxe/build.win64/usr/bin:$PATH #export PATH=/media/backup6/digikam_new2/project/bundles/mxe/build.win64/usr/bin:$PATH #cross-compil 64 bits cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD rm -r build/ mkdir build/ && cd build #mxe: qmake-qt5 x86_64-w64 #/home/laurent/mxe/usr/bin/x86_64-w64-mingw32.static.posix-qmake-qt5 $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD/qelectrotech.pro /media/backup6/digikam_new2/project/bundles/mxe/build.win64/usr/bin/x86_64-w64-mingw32.static-qmake-qt5 $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD/qelectrotech.pro #/media/backup6/digikam_new2/project/bundles/mxe/build.win64/usr/bin/x86_64-w64-mingw32.static.posix.seh-qmake-qt5 $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD/qelectrotech.pro #build jobs=17 #make -j17 make -j$(nproc) cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD/build/release/ mv qelectrotech.exe /$DEFAULT_DIR/nsis_base64$HEAD/files/bin #copy manifest file to /bin Windows packages #cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD #cp qelectrotech.exe.manifest /$DEFAULT_DIR/nsis_base64$HEAD/files/bin cd $DEFAULT_DIR/nsis_base64$HEAD sed -i 's/'"0.5-dev_x86_64-win64+[0-9]*"'/'"$tagName"_x86_64-win64+git"$HEAD"'/' QET64.nsi makensis QET64.nsi ################################################################################################################# #cross-compil 32 bits XP VISTA # WIN XP VISTA build #cd $DEFAULT_DIR #cp -r nsis_base nsis_baseXP$HEAD #cd qelectrotech-$VERSION.r$HEAD/ #cp -r {elements,examples,titleblocks} /$DEFAULT_DIR/nsis_baseXP$HEAD/files #cp -r elements/ examples/ titleblocks/ /$DEFAULT_DIR/nsis_base$HEAD/files #cp -r lang/*.qm /$DEFAULT_DIR/nsis_baseXP$HEAD/files/lang #cd $DEFAULT_DIR #cd qelectrotech-$VERSION.r$HEAD/build-aux/windows/ #cp {lang_extra.nsh,QET.nsi,lang_extra_fr.nsh} /$DEFAULT_DIR/nsis_baseXP$HEAD/ #copy and update folders of readytouse_XP_base skeleton #cd $DEFAULT_DIR #cp -r readytouse_base qelectrotech-$tagName+git$HEAD-WIN_XP-x86-win32-readytouse #cd qelectrotech-$VERSION.r$HEAD/ #cp -r {elements,examples,titleblocks} /$DEFAULT_DIR/qelectrotech-$tagName+git$HEAD-WIN_XP-x86-win32-readytouse #cp -r lang/*.qm /$DEFAULT_DIR/qelectrotech-$tagName+git$HEAD-WIN_XP-x86-win32-readytouse/lang #cd /home/$USER #mv mxe mxe_old #mv mxeXP mxe #sleep 4 #cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD-XP #mkdir build/ && cd build #mxe: qmake-qt5 i686-w64 #/home/laurent/mxe/usr/bin/i686-w64-mingw32.static.posix-qmake-qt5 $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD-XP/qelectrotech.pro #/home/laurent/mxe/usr/bin/i686-w64-mingw32.static.posix-qmake-qt5.7 $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD-XP/qelectrotech.pro #build jobs=17 #make -j17 #make -j$(nproc) #cd /home/$USER #mv mxe mxeXP #mv mxe_old mxe #copy 32 bits binarie to /bin Windows packages #cd $DEFAULT_DIR/qelectrotech-$VERSION.r$HEAD-XP/build/release #cp qelectrotech.exe /$DEFAULT_DIR/nsis_baseXP$HEAD/files/bin #cp qelectrotech.exe /$DEFAULT_DIR/qelectrotech-$tagName+git$HEAD-WIN_XP-x86-win32-readytouse/bin #tag $HEAD by sed for nsis script #cd $DEFAULT_DIR/nsis_baseXP$HEAD #sed -i 's/'"0.5-dev+[0-9]*"'/'"$tagName"+git"$HEAD"'/' QET.nsi #build Windows installer #makensis QET.nsi #crompress readytouse cd $DEFAULT_DIR 7za a -m0=lzma qelectrotech-$tagName+git$HEAD-x86-win32-readytouse.7z qelectrotech-$tagName+git$HEAD-x86-win32-readytouse/ #7za a -m0=lzma qelectrotech-$tagName+git$HEAD-WIN_XP-x86-win32-readytouse.7z qelectrotech-$tagName+git$HEAD-WIN_XP-x86-win32-readytouse/ echo -e "\033[1;31mWould you like to prepare to RSYNC Windows packages /Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then cd /home/laurent/builds/nightly/ name=$(date +%Y-%m-%d-) #defined a name based on the date #start increment to 1 i=1 #increment by i if the builds have already been created while [ "$(ls /home/$USER/builds/nightly/ | grep $name$i)" != "" ]; do ((i++)) done #create a new folder incremented by 1 mkdir /home/$USER/builds/nightly/$name$i #mkdir /home/$USER/builds/nightly/$name$i/WIN_XP_VISTA cd $DEFAULT_DIR/ cp qelectrotech-$tagName+git$HEAD-x86-win32-readytouse.7z /home/laurent/builds/nightly/$name$i #cp qelectrotech-$tagName+git$HEAD-WIN_XP-x86-win32-readytouse.7z /home/laurent/builds/nightly/$name$i/WIN_XP_VISTA cd /$DEFAULT_DIR/nsis_base$HEAD cp Installer_QElectroTech-$tagName+git$HEAD-1.exe /home/laurent/builds/nightly/$name$i #cd /$DEFAULT_DIR/nsis_baseXP$HEAD #cp Installer_QElectroTech-$tagName+git$HEAD-1.exe /home/laurent/builds/nightly/$name$i/WIN_XP_VISTA cd $DEFAULT_DIR/nsis_base64$HEAD cp Installer_QElectroTech-$tagName"_x86_64-win64+git"$HEAD-1.exe /home/laurent/builds/nightly/$name$i else echo -e "\033[1;33mExit.\033[m" fi #rsync to TF Windows builds echo -e "\033[1;31mWould you like to upload Windows packages n/Y?.\033[m" read a if [[ $a == "Y" || $a == "y" ]]; then rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress /home/laurent/builds/nightly/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/builds/nightly/ if [ $? != 0 ]; then { echo "RSYNC ERROR: problem syncing qelectrotech-$VERSION.r$HEAD " rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress /home/laurent/builds/nightly/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/builds/nightly/ } fi #cd ~/paquet_qet/script #sed -i 's/'[0-9][0-9][0-9][0-9]-[0-9][0-9]-[0-9][0-9]-[0-9]'/'"$name$i"'/' dl_link.inc.php #scp dl_link.inc.php "${SSH_TARGET}" else echo -e "\033[1;33mExit.\033[m" fi else echo -e "\033[1;33mExit.\033[m" fi exit
AppImage
#!/bin/bash #set -x #delete old qet.h rm sources/qet.h cd sources git reset --hard origin/master cd .. git pull sed -i 's/DEFINES += QET_EXPORT_PROJECT_DB/#DEFINES += QET_EXPORT_PROJECT_DB/' qelectrotech.pro GITCOMMIT=$(git rev-parse --short HEAD) A=$(git rev-list HEAD --count) HEAD=$(($A+473)) VERSION=$(cat sources/qet.h | grep "const QString version" | cut -d\" -f2 | cut -d\" -f1) #Find version tag in GIT sources/qet.h tagName=$(cat sources/qet.h | grep displayedVersion | cut -d\" -f2 | cut -d\" -f1) #Find displayedVersion tag in GIT sources/qet.h # recupere le numero de la nouvelle revision #revAp=$(svnversion | cut -d : -f 2 | tr -d '[:alpha:]') # On recupere le numero de version de l'originale tagName=$(sed -n "s/const QString displayedVersion =\(.*\)/\1/p" sources/qet.h | cut -d\" -f2 | cut -d\" -f1 ) # On modifie l'originale avec le numéro de révision du dépôt GIT sed -i 's/'"const QString displayedVersion =.*/const QString displayedVersion = \"$tagName+$GITCOMMIT\";"'/' sources/qet.h rm -Rf build/ mkdir build && cd build qmake ../qelectrotech.pro make -j48 cd ../appdir/ rm qelectrotech/usr/bin/qelectrotech rm -Rf qelectrotech/usr/{lib,plugins} rm -Rf qelectrotech/usr/share/{elements,examples,titleblocks,lang,man,doc} cp ../build/qelectrotech qelectrotech/usr/bin/ cp -r ../{elements,examples,titleblocks,lang,man} qelectrotech/usr/share/ ./linuxdeployqt-continuous-x86_64.AppImage qelectrotech/usr/share/qelectrotech.desktop -appimage -bundle-non-qt-libs -verbose=1 -extra-plugins=iconengines rm qelectrotech/AppRun sed -i 's/'"QElectroTech_0.8-DEV.*/QElectroTech_0.8-DEV-r"$HEAD""'/' qelectrotech/qelectrotech.desktop cp AppRun qelectrotech/ rm QElectroTech_*.AppImage ARCH=x86_64 ./appimagetool-x86_64.AppImage qelectrotech chmod -x QElectroTech_0.8-DEV-r$HEAD-x86_64.AppImage
Flatpak
#!/bin/bash #set -x #delete old qet.h rm sources/qet.h cd sources git reset --hard origin/master cd .. # Fait une mise à jour git pull #git checkout test_pugi sed -i 's/DEFINES += QET_EXPORT_PROJECT_DB/#DEFINES += QET_EXPORT_PROJECT_DB/' qelectrotech.pro GITCOMMIT=$(git rev-parse --short HEAD) A=$(git rev-list HEAD --count) HEAD=$(($A+473)) VERSION=$(cat sources/qet.h | grep "const QString version" | cut -d\" -f2 | cut -d\" -f1) #Find version tag in GIT sources/qet.h tagName=$(cat sources/qet.h | grep displayedVersion | cut -d\" -f2 | cut -d\" -f1) #Find displayedVersion tag in GIT sources/qet.h # recupere le numero de la nouvelle revision #revAp=$(svnversion | cut -d : -f 2 | tr -d '[:alpha:]') # On recupere le numero de version de l'originale tagName=$(sed -n "s/const QString displayedVersion =\(.*\)/\1/p" sources/qet.h | cut -d\" -f2 | cut -d\" -f1 ) # On modifie l'originale avec le numero de revision du depot svn sed -i 's/'"const QString displayedVersion =.*/const QString displayedVersion = \"$tagName+$GITCOMMIT\";"'/' sources/qet.h cd ~ flatpak-builder --force-clean --ccache --repo=qet_git/0.8-dev qet_git/build-dir qet_git/build-aux/flatpak/org.qelectrotech.QElectroTech.json --gpg-sign=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX --gpg-homedir=gpg flatpak build-update-repo qet_git/0.8-dev --title="Development builds of QElectroTech" --prune --prune-depth=4 --generate-static-deltas --gpg-sign=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX --gpg-homedir=gpg rsync -e ssh -av --delete-after --no-owner --no-g --chmod=g+w --progress qet_git/0.8-dev/ scorpio810@ssh.tuxfamily.org:/home/qet/qet-repository/builds/Flatpak/
