1 (edited by De-Backer 2020-07-19 23:04:46)
Topic: Resizing of border line of software
for
https://qelectrotech.org/bugtracker/view.php?id=195
add
pages_list-> setMaximumHeight(500);
to
qet/sources/configdialog.cpp
ConfigDialog::ConfigDialog(QWidget *parent) : QDialog(parent) {
    // liste des pages
    pages_list = new QListWidget();
    pages_list -> setViewMode(QListView::IconMode);
    pages_list -> setIconSize(QSize(128, 128));
    pages_list -> setMovement(QListView::Static);
    pages_list -> setMinimumWidth(168);
    pages_list -> setMaximumWidth(168);
    pages_list -> setSpacing(16);
    pages_list -> setHorizontalScrollBarPolicy(Qt::ScrollBarAlwaysOff);
or reSize Icon
    // liste des pages
    pages_list -> setIconSize(QSize(64, 64));
Screenshot_20200719_225346.png, 94.55 kb, 1519 x 1122
Re: Resizing of border line of software
Great, you could add it?
3 (edited by De-Backer 2020-07-19 23:14:49)
which
reSize Icon
or
(the screenshot)
Maybe better with a resize icon if not simply add: pages_list-> setMaximumHeight(500) to use scrollarea;
5 (edited by De-Backer 2020-07-19 23:33:36)
works, but I don't think it will be solved yet.
the other widget will also be too big
and this is also the case for
we need to know the max size of the monitor and put it as max pixel for everything
QScreen *screen = QGuiApplication::primaryScreen();
QRect  screenGeometry = screen->geometry();
int height = screenGeometry.height();
int width = screenGeometry.width();
https://doc.qt.io/qt-5/qscreen.html
test:
    compilation_info += "</br> - height :" + QString::number(screenGeometry.height());
    compilation_info += "</br> - width  :" + QString::number(screenGeometry.width());
Screenshot_20200719_233312.png, 38.1 kb, 747 x 196
Wrong values..
QElectroTech V 0.80-DEV
Compilation : GCC 9.3.0
Built with Qt 5.12.5 - Date : Jul 20 2020 : 10:50:43
Run with Qt 5.12.5 using 48 thread(s)
OS : linux - x86_64 - Version : Debian GNU/Linux bullseye/sid - Kernel : 5.7.9-vanilla - height :1662 - width :2954
xrandr
Screen 0: minimum 320 x 200, current 5759 x 2160, maximum 16384 x 16384
DisplayPort-0 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
   3840x2160     60.00*+  30.00
   2560x1440     59.95
   1920x1200     60.00
   1920x1080     60.00    59.94
   1600x1200     60.00
   1680x1050     60.00
   1600x900      60.00
   1280x1024     60.02
   1440x900      60.00
   1280x800      59.81
   1280x720      60.00    59.94
   1024x768      60.00
   800x600       60.32
   720x480       60.00    59.94
   640x480       60.00    59.94
HDMI-A-0 connected 1920x1080+3839+0 (normal left inverted right x axis y axis) 598mm x 336mm
   1920x1080     60.00*+  50.00    59.94
   1680x1050     59.88
   1280x1024     60.02
   1440x900      59.90
   1280x800      60.00
   1280x720      60.00    50.00    59.94
   1024x768      60.00
   800x600       60.32
   720x576       50.00
   720x480       60.00    59.94
   640x480       66.67    60.00    59.94
   720x400       70.08
DVI-D-0 disconnected (normal left inverted right x axis y axis)
7 (edited by De-Backer 2020-07-20 11:22:55)
https://stackoverflow.com/questions/259 … n-geometry
https://doc.qt.io/qt-5/qscreen.html#dev … Ratio-prop
https://cpp.hotexamples.com/fr/examples … mples.html
    Returns the width of the display in pixels.
    \sa screenHeight(), screenDepth()
int QDirectPainter::screenWidth()
    QScreen *screen = getPrimaryScreen();
    if (!screen)
        return 0;
    return screen->deviceWidth();
9 (edited by De-Backer 2020-07-20 21:29:26)
    if (!screen)
        return 0;
can you get the code to work?
I can not do it.
this code works.
    compilation_info += "<br>  *** Qt screens *** </br>";
    const auto screens = qApp->screens();
    for (int ii = 0; ii < screens.count(); ++ii) {
      compilation_info += "<br> ( "
              + QString::number(ii + 1)
              + QString::number(screens[ii]->geometry().width() * screens[ii]->devicePixelRatio())
              + " x "
              + QString::number(screens[ii]->geometry().height() * screens[ii]->devicePixelRatio())
              + " ) </br>";
Screenshot_20200720_212901.png, 36.06 kb, 594 x 151
#include <QScreen>
Built with Qt 5.12.5 - Date : Jul 20 2020 : 21:31:12
*** Qt screens ***
( 1 : 3840.2 x 2160.6 )
( 2 : 1920.1 x 1080.3 )
Great! if you can push it?
btw, interest thing to get CPU and GPU informations in about QET for debug.
https://forum.qt.io/topic/102337/how-to … cpu-name/4
https://thecodeprogram.com/reading-deta … ith-qt-c--
https://github.com/thecodeprogram/Syste … e/main.cpp
https://doc.qt.io/QtApplicationManager/ … tatus.html
thanks,
I compiled the kde incorrectly,
=> no QDebug available.
I try to solve this first.
#include <QScreen>
*** Qt screens ***
ok
Now that we know the maximum values.
Start the real work, adjusting the gui.
@De-Backer
Welkom op dit forum.
@scorpio810
You forget
17:9     = 2K (2048 X 1080 ) and 4K (4096 X 2160) screens
see picture :
https://commons.wikimedia.org/wiki/File … dards8.svg
Erik
Add Linux cpu info 'model name'
#else
    compilation_info += "  GCC " + QString(__VERSION__);
    compilation_info += "<br>Built with Qt " + QString(QT_VERSION_STR);
    compilation_info += " - Date : " + QString(__DATE__);
    compilation_info += " : " + QString(__TIME__);
    compilation_info += " <br>Run with Qt "+ QString(qVersion());
    compilation_info += " using" + QString(" %1 thread(s)").arg(QThread::idealThreadCount());
QProcess linuxcpuinfo;
         linuxcpuinfo.start("bash", QStringList() << "-c" << "cat /proc/cpuinfo | grep 'model name' | uniq");
         linuxcpuinfo.waitForFinished();
         QString linuxOutput = linuxcpuinfo.readAllStandardOutput();
    compilation_info += "<br>" + QString(linuxOutput.toLocal8Bit().constData());
    compilation_info +=  QString(QSysInfo::currentCpuArchitecture().toUpper());
    compilation_info += "<br>" "  OS : " +  QString(QSysInfo::kernelType());
    compilation_info += "  -   " + QString(QSysInfo::currentCpuArchitecture());
    compilation_info += " -  Version :    " + QString(QSysInfo::prettyProductName());
    compilation_info += "</br>" " -  Kernel :     " + QString(QSysInfo::kernelVersion());
                 + " x "
                 + " ) </br>";
#endif
#endif
cpuinfo.png, 63.33 kb, 910 x 650
Nice example but in qml ...
https://doc.qt.io/QtApplicationManager/ … ample.html
https://stackoverflow.com/questions/183 … pplication
https://docs.microsoft.com/fr-fr/window … dfrom=MSDN
Add Linux gpu info 'model name'
QString OSName = QSysInfo::kernelType();
    if (OSName == "linux")
    linuxcpuinfo.start("bash", QStringList() << "-c" << "cat /proc/cpuinfo |grep 'model name' | uniq");
    compilation_info +=  "<br>"" CPU : " + QString(linuxOutput.toLocal8Bit().constData());
    QProcess linuxgpuinfo;
    linuxgpuinfo.start("bash", QStringList() << "-c" << "lspci | grep VGA | cut -d : -f 3");
    linuxgpuinfo.waitForFinished();
    QString linuxGPUOutput = linuxgpuinfo.readAllStandardOutput();
    compilation_info += "<br>"" GPU : " + QString(linuxGPUOutput.toLocal8Bit().constData());
gpuinfo.png, 74.4 kb, 910 x 650
@Simon,
if you could try this patch on Windows?
Attachment icon 0001-AboutQETDialog-try-to-add-cpuifo-model-name-and-AM-T (1).patch 1.76 kb, 404 downloads since 2020-07-21
ram.png, 80.97 kb, 910 x 650
@Simon,
https://download.qelectrotech.org/qet/builds/nightly/
not yet.
on Win 10 no Qt installed
21 (edited by De-Backer 2020-07-21 19:05:04)
Bdw. the plan was to adjust the gui if the screen is too small.
@scorpio810, CPU RAM .. this info will be useful for debugging and we have to put a log file.
eg https://docs.syncthing.net/dev/crashrep.html
Maybe add other KF5 lib like https://github.com/KDE/kcrash
But I disable KCrash in my cross-compile env for windows. not compile..
# core KF5 frameworks dependencies
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_extra-cmake-modules -- -j$CPU_CORES
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kconfig             -- -j$CPU_CORES
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_breeze-icons        -- -j$CPU_CORES
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kcoreaddons         -- -j$CPU_CORES
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kwindowsystem       -- -j$CPU_CORES
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_solid               -- -j$CPU_CORES
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_threadweaver        -- -j$CPU_CORES
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_karchive            -- -j$CPU_CORES
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kdbusaddons         -- -j$CPU_CORES
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_ki18n               -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kcrash              -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kcodecs             -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kauth               -- -j$CPU_CORES
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kguiaddons          -- -j$CPU_CORES
${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kwidgetsaddons      -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kitemviews          -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kcompletion         -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kconfigwidgets      -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kiconthemes         -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kservice            -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kglobalaccel        -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kxmlgui             -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kbookmarks          -- -j$CPU_CORES
#${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kimageformats       -- -j$CPU_CORES
23 (edited by De-Backer 2020-07-21 19:47:36)
why reinvent the wheel.
good idea scorpio810
I put it on the todo list.
-use kcrash for Crash Reporting for Developer
by the way, I get the KF5 lib not compiled correctly...
URL transformed to HTTPS due to an HSTS policy
--2020-07-21 19:47:32--  https://download.kde.org/stable/framewo … 0.0.tar.xz
Résolution de download.kde.org (download.kde.org)… 2a01:4f8:171:1f24::3, 136.243.156.189
Connexion à download.kde.org (download.kde.org)|2a01:4f8:171:1f24::3|:443… connecté.
requête HTTP transmise, en attente de la réponse… 302 Found
Emplacement : http://ftp.kaist.ac.kr/kde/stable/frame … 0.0.tar.xz [suivant]
--2020-07-21 19:47:33--  http://ftp.kaist.ac.kr/kde/stable/frame … 0.0.tar.xz
Résolution de ftp.kaist.ac.kr (ftp.kaist.ac.kr)… 103.22.220.133
Connexion à ftp.kaist.ac.kr (ftp.kaist.ac.kr)|103.22.220.133|:80… connecté.
requête HTTP transmise, en attente de la réponse… 200 OK
Taille : 22320 (22K) [application/x-xz, application/x-xz]
Sauvegarde en : « /media/backup2/digikam/project/bundles/mxe/temp.dwnld/kcrash-5.70.0.tar.xz »
     0K .......... .......... .                               100% 70,9K=0,3s
2020-07-21 19:47:34 (70,9 KB/s) — « /media/backup2/digikam/project/bundles/mxe/temp.dwnld/kcrash-5.70.0.tar.xz » sauvegardé [22320/22320]
[  0%] Performing download step (verify and extract) for 'ext_kcrash'
-- verifying file...
     file='/media/backup2/digikam/project/bundles/mxe/temp.dwnld/kcrash-5.70.0.tar.xz'
-- verifying file... done
-- extracting...
     src='/media/backup2/digikam/project/bundles/mxe/temp.dwnld/kcrash-5.70.0.tar.xz'
     dst='/media/backup2/digikam/project/bundles/mxe/temp.build/ext_kf5_frameworks/ext_kcrash-prefix/src/ext_kcrash'
-- extracting... [tar xfz]
-- extracting... [analysis]
-- extracting... [rename]
-- extracting... [clean up]
-- extracting... done
[100%] No patch step for 'ext_kcrash'
[100%] No update step for 'ext_kcrash'
[100%] Performing configure step for 'ext_kcrash'
-- The C compiler identification is GNU 9.3.0
-- The CXX compiler identification is GNU 9.3.0
-- Check for working C compiler: /media/backup2/digikam/project/bundles/mxe/build.win32/usr/x86_64-pc-linux-gnu/bin/i686-w64-mingw32.static-gcc
-- Check for working C compiler: /media/backup2/digikam/project/bundles/mxe/build.win32/usr/x86_64-pc-linux-gnu/bin/i686-w64-mingw32.static-gcc - works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /media/backup2/digikam/project/bundles/mxe/build.win32/usr/x86_64-pc-linux-gnu/bin/i686-w64-mingw32.static-g++
-- Check for working CXX compiler: /media/backup2/digikam/project/bundles/mxe/build.win32/usr/x86_64-pc-linux-gnu/bin/i686-w64-mingw32.static-g++ - works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
Installing in /media/backup2/digikam/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static. Run /media/backup2/digikam/project/bundles/mxe/temp.build/ext_kf5_frameworks/ext_kcrash-prefix/src/ext_kcrash-build/prefix.sh to set the environment for KCrash.
-- Looking for __GLIBC__
-- Looking for __GLIBC__ - not found
-- Performing Test HAVE_DATE_TIME
-- Performing Test HAVE_DATE_TIME - Success
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Performing Test COMPILER_HAS_DEPRECATED_ATTR
-- Performing Test COMPILER_HAS_DEPRECATED_ATTR - Success
-- The following features have been enabled:
* Core Pattern Raising, Raising signals to kernel core patterns (iff the pattern is a process). You may wish to not install drkonqi if this can cause a UI conflict.
-- The following REQUIRED packages have been found:
* ECM (required version >= 5.70.0), Extra CMake Modules., <https://commits.kde.org/extra-cmake-modules>
* Qt5 (required version >= 5.12.0)
* Qt5Core (required version >= 5.12.0)
* KF5CoreAddons (required version >= 5.70.0)
* Qt5EventDispatcherSupport
* Qt5FontDatabaseSupport
* Threads
* Qt5Svg
* Qt5Network
* Qt5ThemeSupport
* Qt5AccessibilitySupport
* Qt5WindowsUIAutomationSupport
* Qt5Gui (required version >= 5.15.0)
* KF5WindowSystem (required version >= 5.70.0)
-- The following features have been disabled:
* QCH, API documentation in QCH format (for e.g. Qt Assistant, Qt Creator & KDevelop)
-- The following OPTIONAL packages have not been found:
* X11
-- Configuring done
CMake Error at src/CMakeLists.txt:20 (add_library):
  Target "KF5Crash" links to target "Qt5::WinExtras" but the target was not
  found.  Perhaps a find_package() call is missing for an IMPORTED target, or
  an ALIAS target is missing?
-- Generating done
CMake Warning:
  Manually-specified variables were not used by the project:
    CMAKE_FIND_PREFIX_PATH
    CMAKE_INCLUDE_PATH
    CMAKE_SYSTEM_INCLUDE_PATH
    INSTALL_ROOT
    MXE_TOOLCHAIN
    ZLIB_ROOT
CMake Generate step failed.  Build files cannot be regenerated correctly.
gmake[3]: *** [ext_kf5_frameworks/CMakeFiles/ext_kcrash.dir/build.make:130 : ext_kf5_frameworks/ext_kcrash-prefix/src/ext_kcrash-stamp/ext_kcrash-configure] Erreur 1
gmake[2]: *** [CMakeFiles/Makefile2:1393 : ext_kf5_frameworks/CMakeFiles/ext_kcrash.dir/all] Erreur 2
gmake[1]: *** [CMakeFiles/Makefile2:1400 : ext_kf5_frameworks/CMakeFiles/ext_kcrash.dir/rule] Erreur 2
gmake: *** [Makefile:450 : ext_kcrash] Erreur 2
FAILED COMMAND: ${MXE_BUILD_TARGETS}-cmake --build . --config RelWithDebInfo --target ext_kcrash -- -j$CPU_CORES
# Switch to a more recent gcc version
echo 'override MXE_PLUGIN_DIRS += plugins/gcc9' >> settings.mk
make -j48 MXE_TARGETS=$MXE_BUILD_TARGETS \
     cmake \
     gettext \
     freeglut \
     libxml2 \
     libxslt \
     libjpeg-turbo \
     libpng \
     tiff \
     boost \
     expat \
     lcms \
     liblqr-1 \
     eigen \
     jasper \
     zlib \
     mman-win32 \
     pthreads \
     qtbase \
     qttranslations \
     qtimageformats \
     qtwebkit \
     qttools \
     qtwinextras \
     sqlite  \
     qtscript \
     x265 \
     ffmpeg \
     openal \
     libical \
     imagemagick
echo -e "\n"
https://api.kde.org/frameworks/kcrash/html/index.html
I check tomorow, time to go to my work..
