1 (edited by mentor 2020-06-30 13:41:27)
Topic: reference folio ver8
hello
I have problem with reference folio arrow.
In ver 7 I customise reference arrow by adding %{tension-protocol}  / %{label} to get more information
in ver 8 I don't get crossing information in my elements.
When I copy crossing arrow to user collection and don't change anything crossing reference works fine but if I change anything for example move dynamic text file "/" crossing stop work. Even if I undo changes crossing don't work.
I use this crossing functionality to make PLC symbols and in ver 8 crossing reference in my PLC symbols don't work too.
Re: reference folio ver8
Hi Mentor,
you could share an example project and more explanations?
[img][/img]
qelectrotech_ver7.png, 23.17 kb, 1047 x 606
[img][/img]
qelectrotech ver8.png, 20.12 kb, 879 x 537
example in attachment
Thanks for report this issue, maybe since we change minus by underscore?
https://git.tuxfamily.org/qet/qet.git/c … 5fa9a304f7
If I try with %{function} seems working.
%{tension_protocol} or %{tension-protocol} is missing in this widget and wrote %{void} ?!...
There also seems to be a bug with composite text and %{label}.
https://download.qelectrotech.org/qet/forum_img_2/0.8-bug_check_report_folio.png
Maybe a first patch.
Attachment icon 0001-Try-to-fix-conductorInfoKeys.patch 5.07 kb, 313 downloads since 2020-07-01
I use AppImage version in debian.
I don't know how implement this code.
You can't on AppImage, these patch is to apply on GIT local sources and need to compile code after to try the changes..
These patches are just one todo task for me, Joshua, maybe Simon to keep improving.
10 (edited by De-Backer 2020-07-02 18:55:30)
fout bij "dynamicelementtextitem.cpp"
@ 1183
label = elmt->actualLabel();
QString DynamicElementTextItem::reportReplacedCompositeText() const
    QString string;
    if(m_parent_element.data()->linkType() & Element::AllReport)
        string = m_composite_text;
        if (string.contains("%{label}") && m_other_report)
            Element *elmt = m_other_report.data();
            QString label = m_report_formula;
            label = elmt->actualLabel(); // <======= set to NULL!!!!!
            string.replace("%{label}", label);
            qDebug()<<string<<label<<elmt->actualLabel(); // test van De-Backer
        if (m_watched_conductor)
            if(string.contains("%{function}"))
                string.replace("%{function}", m_watched_conductor.data()->properties().m_function);
            if(string.contains("%{tension-protocol}"))
                string.replace("%{tension-protocol}", m_watched_conductor.data()->properties().m_tension_protocol);
            if(string.contains("%{couleur-conducteur"))
                string.replace("%{couleur-conducteur}", m_watched_conductor.data()->properties().m_wire_color);
            if(string.contains("%{section-conducteur"))
                string.replace("%{section-conducteur}", m_watched_conductor.data()->properties().m_wire_section);
    return string;
Seeking further....
the origin of the bug is id fc73d53d73bc341e853e7f36e797bd8b9ad47b46
test: it works for that, but not after that
Joshua can certainly find the bug faster. Than me.
CSV export : correctly export label https://git.tuxfamily.org/qet/qet.git/c … 8b9ad47b46   ?
12 (edited by De-Backer 2020-07-02 20:51:22)
yes that's the commit
I hope the Joshua or anyone else can fix this is a bit too complex for me.
I will see that tomorrow
Fixed.
De-Backer, you was in the good way, it was the good line and the good comit wich broke the formula. nomicons/wink
That solution would take me weeks.
The autonum class is one that I do not yet master.
In any case, good job Joshua.
@ Mentor: fixed, but you need to add again Voltage /protocol informations for each conductor, and edit your report folioa nd change
{tension-protocol} -> {tension_protocol}
https://git.tuxfamily.org/qet/qet.git/c … 2d235417cf
Screenshot1.png, 165.77 kb, 2453 x 1569
https://git.tuxfamily.org/qet/qet.git/c … 67831fa112
thank you for very fast reaction
regards
jarek
@ 1183
    QString string;
    return string;
Seeking further....
In the above code is another bug regarding the color and the section of the conductor:
The if statement is missing a curly brace.
I must not be awake enough I do not see where?
https://git.tuxfamily.org/qet/qet.git/t … .cpp#n1139
Edit : already fixed typo.
21 (edited by De-Backer 2020-07-06 13:33:35)
fix => Joshua
@@ -1186,12 +1186,12 @@ QString DynamicElementTextItem::reportReplacedCompositeText() const
-            if(string.contains("%{tension-protocol}"))
-                string.replace("%{tension-protocol}", m_watched_conductor.data()->properties().m_tension_protocol);
-            if(string.contains("%{}couleur-conducteur"))
-                string.replace("%{couleur-conducteur}", m_watched_conductor.data()->properties().m_wire_color);
-            if(string.contains("%{}section-conducteur"))
-                string.replace("%{section-conducteur}", m_watched_conductor.data()->properties().m_wire_section);
+            if(string.contains("%{tension_protocol}"))
+                string.replace("%{tension_protocol}", m_watched_conductor.data()->properties().m_tension_protocol);
+            if(string.contains("%{conductor_color}"))
+                string.replace("%{conductor_color}", m_watched_conductor.data()->properties().m_wire_color);
+            if(string.contains("%{conductor_section}"))
+                string.replace("%{conductor_section}", m_watched_conductor.data()->properties().m_wire_section);
