Re: deprecated fix patch files
warning: ‘typename Container::const_iterator qUpperBound(const Container&, const T&) [with Container = QList<double>; T = double; typename Container::const_iterator = QList<double>::const_iterator]’ is deprecated: Use std::upper_bound [-Wdeprecated-declarations]
-3 issues Qt -> C++ (should be ok, no version differences)
Attachment icon 0001-fix-deprecated-warning-qUpperBound.patch 1.11 kb, 355 downloads since 2020-06-07
27 (edited by De-Backer 2020-06-07 10:23:11)
attempt 2 for deprecated warning QList::swap(int i, int j)
I had to revert it
https://git.tuxfamily.org/qet/qet.git/c … e91882a445
Edit : ok I understood, I use Qt version 5.12.5 and this function was introduced in Qt 5.13.
*fix deprecated warning QList::swap(int i, int j)
Attachment icon 0001-fix-deprecated-warning-QList-swap-attempt-2.patch 1.4 kb, 336 downloads since 2020-06-07
* fix_deprecated_QModelIndex
warning: ‘QModelIndex QModelIndex::child(int, int) const’ is deprecated: Use QAbstractItemModel::index [-Wdeprecated-declarations]
-11 issues
Attachment icon 0001-fix-deprecated-warning-QModelIndex-child.patch 3.97 kb, 350 downloads since 2020-06-07
I tried "0001-fix-deprecated-Wdeprecated-copy.patch" is reduce warnings 50 to 6, but I don't know if I can push it?
First patch in attached patch reduce warnings 50 -> ~20.
i think this is the answer, use default default constructor (does only shallow copy).
Attachment icon 0001-remove-user-defined-copy-constructor.patch 4.07 kb, 309 downloads since 2020-06-07
Thanks Simon.
De-Backer wrote:
warning: ‘QSet<T> QList<T>::toSet() const [with T = IndependentTextItem*]’ is deprecated:
Use QSet<T>(list.begin(), list.end()) instead. [-Wdeprecated-declarations]
-5 issues  for QT 5.14
don't forget
last patch:
QAbstractTableModel explicitly initialized in copy constructor
warning: base class ‘class QAbstractTableModel’
should be explicitly initialized in the copy constructor [-Wextra]
Attachment icon 0001-QAbstractTableModel-explicitly-initialized-in-copy-c.patch 1.27 kb, 343 downloads since 2020-06-08
Thanks Simon.
