1 (edited by De-Backer 2020-06-01 10:32:36)
Topic: deprecated fix patch files
*fix deprecated warning qVariantFromValue
-14 Issues
*fix deprecated warning QTime::start()
This function was introduced in Qt 5.4.
-2 Issues
*fix deprecated warning QFontMetrics::width(QChar ch)
This function was introduced in Qt 5.11.
! "#if QT_VERSION < QT_VERSION_CHECK" used
-16 Issues
*fix deprecated warning QLineF::intersect
This function was introduced in Qt 5.14.
-1 Issue
please check before you merge (! "#if QT_VERSION < QT_VERSION_CHECK" used !)
Re: deprecated fix patch files
*fix Wmisleading-indentation warning
there were spaces used to indent the conditional line
-3 Issue
Attachment icon 0001-fix-Wmisleading-indentation-warning.patch 1.58 kb, 355 downloads since 2020-05-28
*fix deprecated warning QWidget::getContentsMargins
This function is obsolete.
Use contentsMargins().
instead.
This function was introduced in Qt 4.6.
-1 Issue
please check before you merge see:
void IntegrationMoveTitleBlockTemplatesHandler::radioButtonleftMargin(QRadioButton *button) {
-    int a, b, c, d;
-    button -> getContentsMargins(&a, &b, &c, &d);
-    button -> setContentsMargins(a + 15, b, c, d);
+    button->contentsMargins().setLeft(button->contentsMargins().left()+15);
Attachment icon 0001-fix-deprecated-warning-QWidget-getContentsMargins.patch 1.12 kb, 334 downloads since 2020-05-28
Merged (all), thanks Simon.
I tried quickly on old projects and did not notice any major problems.
Of course, this is a devel version, it's time to clean up the old code a bit.
I finally managed to build the cross-compilation MXE environment with KDE Framework (KF5_VERSION 5.70) for Qt 5.15.0 (only x86_64-w64-mingw32 now for checking).
Well, is time for me to try Qt 5.15.0 under MS Windows and saw if I can provide packages with this Qt version..
https://qelectrotech.org/forum/viewtopi … 561#p10561
Edit: same font issue only for MS Windows again ... .element text "Sans Serif" fonts are blurred..
https://download.qelectrotech.org/qet/forum_img_2/Qt5.15_win_font%20_issue.png
A workaround to fix this issue on MS Windows with >=Qt 5.12.0 is to replace all Sans Serif default font by MS Shell Dlg 2 in all elements and all collections XML.. Btw users need hack our XML project also and replace Sans Serif police.
https://docs.microsoft.com/en-us/window … hell-dlg-2
It's really a shame to be stuck on Qt 5.12.0 for Windows packages, and not to take advantage of the advances in the framework ..
I try to fix the compile warnings first, afterwards i try to understand the code. (french is difficult for me)
My goal is to understand why the content of the .qet file always changes when saving, because this makes it difficult for git.
(everything is always different)
(i am using git to track the changes in my project 'cv.qet')
For MS Windows I will need more time.
I always want to help but my knowledge is still too limited.
Qt save XML attributes in a random order each time, this is one of the reasons why we added UUID to control the versions of the elements.
https://qelectrotech.org/forum/viewtopi … 4283#p4283
Attributes
For some time and over the succeeding versions of Qt, it became obvious that the attributes in the XML definition of the elements were not always be read and saved in the same order on each QET startup.
A Qt class compares attributes to know if a newly dragged/dropped element on the diagram already exists in the project. In this case, the class compares all the attributes.
For some speed reasons, this method compares the whole attributes string: if the position of an attribute is changed, the element is considered as different (new).
Among all possible solutions, the one which seems to us to be the easiest one is the generation of an universal unique identifier (UUID) for each element of the collection. In this way, only the UUID attributes of the files must be compared and not the whole XML attributes strings.
The elements editor generates automaticaly an UUID during the saving of the element file.
The database speeds up the loading of numberous elements by managing changes of element thumbnails in tables. To update the thumbnails cache, the database does no longer compare the modification date of these files, only the UUID attributes.
The official collection was patched to add the new UUID attribute.
Script bash unpretentious, for those on GNU/Linux who want to patch their own collection.
For the warnings: Qt prepares the future and Qt 6, that is understandable and therefore marks a lot of obsolete method, if you compile it in an old version of Qt, you do not see any warning.
Thanks a lot for your work.
Qt save XML
then I will use an external program for the dif's of my project.
I am currently working on fix preprocessor Issue error: 'foo.h' file not found
this provides the in QT editor linking.
9 (edited by De-Backer 2020-05-30 00:59:36)
*fix deprecated warning QList::swap(int i, int j)
*fix deprecated warning QDir& QDir::operator=(const QString&)
*fix -Wswitch warning   Qt::MarkdownText: //This enum value was added in Qt 5.14.
I had to revert it
https://git.tuxfamily.org/qet/qet.git/c … e91882a445
Edit : ok I understood, I use Qt version 5.12.5 and this function was introduced in Qt 5.13.
I will have to do more checks before releasing the patch files
this is an example of a wrong patch:
fix deprecated -Wdeprecated-copy (C++11)
warning: implicitly-declared ‘NamesList& NamesList::operator=(const NamesList&)’ is deprecated [-Wdeprecated-copy]
Use copy and swap idiom to implement assignment.
Attachment icon 0001-fix-deprecated-Wdeprecated-copy.patch 2.93 kb, 366 downloads since 2020-05-30
I tried "0001-fix-deprecated-Wdeprecated-copy.patch" is reduce warnings 50 to 6, but I don't know if I can push it?
First patch in attached patch reduce warnings 50 -> ~20.
14 (edited by De-Backer 2020-05-30 11:36:11)
No it is not according to the + c11 rules.
https://en.cppreference.com/w/cpp/langu … e_of_three
I see, thanks.
fix deprecated warning QDrag::start
Use
QDrag::exec
instead.
This function was introduced in Qt 4.3.
and for "fix deprecated -Wdeprecated-copy (C++11)"
I can't get my head around it, I will probably need some help.
Attachment icon 0001-fix-deprecated-warning-QDrag-start.patch 800 b, 341 downloads since 2020-05-31
Merged, thanks.
I prefer saw some deprecated function warnings marked during compilation and still don't have much time to see them (Linux time make -j49 ~ 16 seconds, Catalina VM ~ 20 seconds..cross-compile for Windows ~20 seconds,  rather than silently adding new bugs which will be hard to find. nomicons/wink
16  + 20 + 20 = 56s
Wooo less than 1 min to build for three OS.
linksingleelementwidget.cpp:482:28: warning: 'setBackgroundColor' is deprecated: Use QTreeWidgetItem::setBackground() instead
qtreewidget.h:141:5: note: 'setBackgroundColor' has been explicitly marked deprecated here
qglobal.h:294:33: note: expanded from macro 'QT_DEPRECATED_X'
qcompilerdetection.h:675:55: note: expanded from macro 'Q_DECL_DEPRECATED_X'
"linksingleelementwidget.cpp"
@@ -478,11 +478,11 @@ void LinkSingleElementWidget::linkTriggered()
-            m_qtwi_at_context_menu->setBackgroundColor(i, Qt::green);
+            m_qtwi_at_context_menu->setBackground(i, QBrush(Qt::green,Qt::SolidPattern));
void QTreeWidgetItem::setBackgroundColor(int column, const QColor &color)
This function is deprecated. Use setBackground() instead.
See also backgroundColor().
void QTreeWidgetItem::setBackground(int column, const QBrush &brush)
Sets the background brush of the label in the given column to the specified brush. Setting a default-constructed brush will let the view use the default color from the style.
Note: If Qt Style Sheets are used on the same widget as setBackground(), style sheets will take precedence if the settings conflict.
This function was introduced in Qt 4.2.
Merged, thanks.
FYI, AppImage use now Qt 5.15.0.
https://invent.kde.org/sdk/kdesrc-build/-/issues/45
fix_deprecated_drawRoundRect
warning: ‘void QPainter::drawRoundRect(const QRectF&, int, int)’ is deprecated: Use drawRoundedRect(..., Qt::RelativeSize) instead [-Wdeprecated-declarations]
void QPainter::drawRoundRect(const QRectF &r, int xRnd = 25, int yRnd = 25)
This function is obsolete. It is provided to keep old source code working. We strongly advise against using it in new code.
void QPainter::drawRoundedRect(const QRectF &rect, qreal xRadius, qreal yRadius, Qt::SizeMode mode = Qt::AbsoluteSize)
Draws the given rectangle rect with rounded corners.
The xRadius and yRadius arguments specify the radii of the ellipses defining the corners of the rounded rectangle. When mode is Qt::RelativeSize, xRadius and yRadius are specified in percentage of half the rectangle's width and height respectively, and should be in the range 0.0 to 100.0.
A filled rectangle has a size of rect.size(). A stroked rectangle has a size of rect.size() plus the pen width.
QRectF rectangle(10.0, 20.0, 80.0, 60.0);
QPainter painter(this);
painter.drawRoundedRect(rectangle, 20.0, 15.0);
This function was introduced in Qt 4.4.
Attachment icon 0001-fix-deprecated-warning-QPainter-drawRoundRect.patch 2.64 kb, 364 downloads since 2020-06-01
Merged, thanks.
warning: base class ‘class QAbstractTableModel’ should be explicitly initialized in the copy constructor [-Wextra]
sources/qetgraphicsitem/ViewItem/nomenclaturemodel.cpp:46:1:
-NomenclatureModel::NomenclatureModel(const NomenclatureModel &other_model)
+NomenclatureModel::NomenclatureModel(const NomenclatureModel &other_model) :
+    QAbstractTableModel(this),
+    m_project(project())
is ok?
info of https://stackoverflow.com/questions/211 … onstructor
Attachment icon 0001-fix-warning-QAbstractTableModel-initialized-in-the-c.patch 1.29 kb, 371 downloads since 2020-06-04
warning: ‘QSet<T> QList<T>::toSet() const [with T = IndependentTextItem*]’ is deprecated:
Use QSet<T>(list.begin(), list.end()) instead. [-Wdeprecated-declarations]
-5 issues  for QT 5.14
Attachment icon 0001-fix-deprecated-warning-QSet-T-QList-T-toSet.patch 2.15 kb, 390 downloads since 2020-06-07
