1 (edited by De-Backer 2020-05-06 19:07:52)
Topic: Shortcut (Space key) for language nl be does not work.
For rotate selection (Shortcut is Space)
does not work for language nl be (this has been since 2019)
file qetdiagrameditor.cpp at line 545
m_rotate_selection->setShortcut(QKeySequence( tr("Space")));
test mod Space to Ctrl+R works
Updating 'lang/qet_be.ts'...
    Found 2294 source text(s) (1 new and 2293 already existing)
    Kept 1 obsolete entries
m_rotate_selection->setShortcut(QKeySequence(tr("Ctrl+R")));
I cannot find the Space key in qt nl be.
does anyone know the key for space?
I have tested "spatie",  "Spatiebalk"
A bug in Qt?
edited :add Screenshot of test with Ctrl+R
Screenshot.jpg, 29.72 kb, 540 x 396
2 (edited by Joshua 2020-05-06 19:06:25)
Re: Shortcut (Space key) for language nl be does not work.
After test,
m_rotate_selection->setShortcut(QKeySequence( tr("SPACE")));
work well for nl be local and also for french.
I will try for all local and if it's ok I commit the change.
Thanks for report
In theory these QKeySequence names should not be translated by translators, but by framework..
See in qet_fr.ts.
uppercase Space
weird, it works in german (lowercase Space)
Work well for every local. Pushed to git master.
Thanks.
https://git.tuxfamily.org/qet/qet.git/t … r.ts#n5775
https://git.tuxfamily.org/qet/qet.git/c … d4640293fe
Well this is an oversight in the Qt translation for be, for example in french I don't need to translate this key, Qt does it alone.
@Joshua and scorpio810
great work, can you also change the next line please?
file qetdiagrameditor.cpp at line 546
m_rotate_texts    ->setShortcut(QKeySequence( tr("Ctrl+Space")));
in to
m_rotate_texts    ->setShortcut(QKeySequence( tr("Ctrl+SPACE")));
it is the last space.
@De-Backer,
done, and generated new ts files.
