26 (edited by stromie 2019-09-17 19:57:32)
Re: feature set xref slave position
I am now unbroken for debugging on Linux. That makes a lot of things easy.
But there is still a bug. If you put on text alignment and then change the alignment from top to button something happens when you move the master.
Bild1.PNG, 8.08 kb, 409 x 339
27 (edited by stromie 2019-09-17 19:59:39)
Bild2.PNG, 7.68 kb, 260 x 219
Because the Xref is update When you move the master.
What you need to do is when you change the alignment properties, you need to force the update of the displayed Xref
29 (edited by stromie 2019-11-16 07:37:07)
Hi
i have fix the issue, can you test it.
Attachment icon 0001-bugfix-XREF-Update-when-Text-Alignment-used.patch 925 b, 370 downloads since 2019-11-16
added, thanks Stromie.
