Topic: Unable to exclude page references from nomenclature/BOM
Hello all
I created a BOM as described here. It basically works but I am not able to exclude the page references.
You find the result attached. I don't want to have the page references in the BOM, but I am unable to define the right filter option to ignore them.
Does anybody have an idea?
Kind regards
Felix
qet-bom.png, 58.14 kb, 2545 x 753
Re: Unable to exclude page references from nomenclature/BOM
A BOM page must not contain any schemes..
Yes, this allowed for showing the problem in one screenshot nomicons/wink
I haven't tried out the procedure in the thread yet. But if I understand correctly you have to build a query using the SQL browser. Once this query works, you can put it in qelectrotech and save the setup.
Thank you very much for the quick response.
Kind regards
Felix
I finally was able to try it out, this is exactly what I was looking for. Thanks!
You somewhere posted the schematic of the vibration platform - congratulations btw, it's a really impressive what this software can do!
Hello Flix,
thanks for compliments. nomicons/wink
Yes on https://download.qelectrotech.org/qet/schemas_pdf/ You see many schemes drawn by many authors and a little by me with QET software.
Best regards,
Could you clarify if excluding page references from the nomenclature/BOM in QElectroTech involves building a query using the SQL browser and saving the setup?
