1 (edited by LievenC 2023-03-14 12:09:29)
Topic: Master Slave reference
The cross reference for master slave shows the folio number instead of the folio label.
In the project settings cross reference I have set %F-%l%c for the master and (%F-%l%c) for the slave indication
where to change so that te cross reference shows the folio label (%F)
Re: Master Slave reference
Your folio label is 12
With %f it's show 1 because is the first folio
With %F is's show 12
Also found in mean time:
the setting for cross reference has to be done 3 times for each type of element
coil - organ of protection - switch/button
and this is what I had forgotten
it only worked for coil
Sure, you have 3 enities "coil", "organ of protection", and "switch/button" settings to configure differently.
