Topic: sorting order terminals
the sorting order of the conducturs is not saved
after having filled all the fields hose and conductor I closed the application
when reopening the order is not the same anumore
also the hose and conductor are not on the correct line for some of the terminals
Re: sorting order terminals
You need to order -> generate X1 terminal-block and Quit and close your QET project without saving!
Re launch your QET project and re open terminal block plugin. Order is saved.
3 (edited by andi11 2024-07-26 16:40:02)
is it possible that in the current 0.1 dev is an bug together with the plugin?
Sorting the terminals in the pugin works. After that I closed QET without saving. Importing shows the correct sorting of the terminals.
Reopening the plugin shows the "old" sorting.
Also when i understand the source correctly, it should be able to click on some columns, and the elements should be sorted
https://github.com/raulroda/qet_tb_gene … 5420ab5f8b
But nothing happens, when i click or doubleclick for example XREF
eventuall it's a problem that my blocks are called for example X4:01u or X4:01o because it's an multi row terminal.
The dev version of the newer terminal block manager can do this mutli row setup, but it doesn't show the signal name
5 (edited by andi11 2024-07-28 10:35:14)
i made a deeper dive into the source of the plugin
Within the plugin i switched positions with the down button.
Attached is example file and backup from the plugin created. Source is from here https://github.com/raulroda/qet_tb_generator-plugin
The upper part "update terminals" from the screenshot is generated within
    def update_terminals(self, data):
        """Changes the config of every terminal in the diagra. The changes made
        in the plugin will be save in the 'elementInformation' of every
        terminal."""
        print('update terminals')
        for diagram in self.qet_project.findall('diagram'):  # all diagrams(pages)
            for element in diagram.iter('element'):  # all elements in diagram
                dt = [x for x in data if x['uuid'] == element.attrib['uuid']]
The lower part lists the tree withing "def save_tb(self, filename)"
It looks as if the properties of the terminals are switched (ground and standart) and not, like i hoped the positions within the plugin.
Unbenannt.PNG, 57.28 kb, 675 x 814
does this mean there is a need for a new version of the generator?
i think so. In my opinion there is an bug that doesn't store the sorting correctly in all cases.
Any news regarding this issue?
Please open an issue here https://github.com/raulroda/qet_tb_generator-plugin
J'ai un projet qui fait planter le qet_tb_generator, la version standalone aussi. On voit le script de démarrage sous la fenêtre dos s'executer et le logiciel s’arrête. J'ai essayé d'utiliser la sauvegarde mais elle se comporte pareil. Idem pour des sauvegarde plus anciennes. Je ne sais donc pas quand le projet s'est mis dans cet état sachant que je n'avais pas utilisé le générateur de bornier jusque là. Le générateur de bornier est fonctionnel avec d'autre projets.  Avez vous une solution s'il vous plait? Manipulation ou procédure de récupération de purge sur le projet? (le clean n'a pas marché non plus).
Bonjour Thomas,
ton projet contient des logos SVG dans les cartouches?
Si tu as un backup fonctionnel de ce projet, regardes si tu peux le partager ici.
Non mon projet ne contient pas de logo SVG dans les cartouches. Il y a juste des image dans l’écran de titre . Je sais aussi qu'a un moment j'ai relié une borne "classique" avec une borne à une seule entrée et que j'ai effacé ça.
Comment envoyer un fichier ici?
Édites ton ancien post, et tu devrais voir choisir un fichier et le joindre.
Ça veut pas me le prendre, il est trop gros.
Your Project-file is too big?
Use zip to compress and try again.
ok c'est bon le problème est résolje . C'était des bornes non reliées qui posaient probleme (je constitue ue reserve). Je l'ai relié tout est bon maintenant. Merci.
I made the issue on github
https://github.com/raulroda/qet_tb_gene … n/issues/5
until now no reaction
the solution is there only someone needs to implement it
or when to expect this functionality in QET itself?
The source code of qet_tb_generator has not been changed for four years. How high do you think the chances are that it is being worked on “today”?
The plugin is python code: Can't you perhaps get together with someone who "speaks" Python and see how the problem can be fixed, LievenC and andi11?
You seem to have already found the problematic part...
how can I attach files? I think i fixed it. I also did some more minor improvements in the files.
So posting it fix for the "sorting order" bug is not 100% correct, because it includes more changes.
Click on button "Preview reply" then there is a button to search the attachment on your system.
Important: You have to click "Add file" to upload the attachment!
I guess there are some users looking forward to it!
