Topic: Folio number
hy every one
in my project i would like to put my elemnts in specific number folio
example motors and driver from folio 6 untill 19
input PLC from 20 to 29
so i need to give ofset to new page or add empty page because in crossreference i can't use the that i give to my page
can someone help me pleas
Best regards
Gravino
Re: Folio number
Hi Gravino,
in project setting or in general config enable use folio number/label instead of their position ...
https://download.qelectrotech.org/qet/m … oject.html
Use %F instead %f in formula for crossreference, reports, etc.
https://download.qelectrotech.org/qet/m … tings.html
Best regards,
Re: Folio number
Hi Scoprpio,
thank you very much voor your help, you guys are doing a great job, i'm learning now to use QET it's powerfull
Re: Folio number
btw use "%id" instead  "%id/%total" in your titleblock's pages, otherwise you will see Xref like this "(folio_label/total_ off_folios)-(line number)- (column_number) etc.
So, is easy with ctrl +f in and then folio section to change "%id/%total" by "%id" in all project's.
