26 (edited by De-Backer 2020-07-18 21:21:17)
Re: continuous blocks
De-Backer wrote:
Start QElectroTech
Ram 61.2MB (tot)
run file
Ram 200.3MB (tot)
QElectroTech V 0.80-DEV+68116f466d79751d3
Compilatie: GCC 9.3.0
Built with Qt 5.15.0 - Date : Jul 16 2020 : 11:04:52
Run with Qt 5.15.0 using 16 thread(s)
OS : winnt - x86_64 - Version : Windows 10 Version 1909 - Kernel : 10.0.18363
for 0.7:
Start QElectroTech
Ram 67.3MB (tot)
run file
Ram 214.2MB (tot)
QElectroTech V 0.70+a375424c0d79751d3
Compilatie: GCC 8.3.0 - built with Qt 5.13.0 - Date : Jul 18 2019 : 16:02:17 - run with Qt 5.13.0 using 16 thread(s)
OS : winnt - x86_64 - Version : Windows 10 (10.0) - Kernel : 10.0.18363
ToT RAM os 5GB (1GB for google Chrome)
note: test on
qelectrotech-0.80-DEV+git6478-x86-win32-readytouse.7z
qelectrotech-0.70+git5967-x86-win32-readytouse.7z
27 (edited by De-Backer 2020-07-18 21:38:57)
Maybe there is something wrong with the installer version of QElectroTech?
Or the elements user collection is too large?
@josaar2001
Can you try the Ready-to-use versions on your PC?
Good morning
I also had these blocks on win 7 pro
tried the 2 portable programs qelectrotech-0.80-DEV+git6478-x86-win32-readytouse.7z
the blocks are always there
In my company I do projects, installations and technical interventions,
time is not enough, for symbols I first take a picture and resize it than create them.
Maybe I got carried away on the graphic part, I'm thinking of dividing the projects into several parts in order to make them lighter
Greetings and happy Sunday
Yet why do I not get those stutters.
Frustrated to know that there is a problem and that I cannot simulate it.
I will make low specs VM machine and test it.
30 (edited by De-Backer 2020-07-19 09:50:14)
loading class MasterPropertiesWidget seems to cause delays (making the slave elemente image)
@josaar2001 Can you confirm that the hitch only happens when a master element is selected?
(note tested on 0.7)
Hello
When I open the project it seems to be fine for about 2 minutes, then it starts to freeze for a few seconds when I change the page, when I select an element and even without doing anything, it seems that it is waiting for something like saving. In version 0.60 these problems did not occur, tomorrow in the company I try with version 0.60
The problem looks the same as @ david.marinon who posted 2020.03.10 the program hangs every 2 minutes
Regards
Good morning
This morning I tried the project with vers. 0.60 there were no blocks.
If it can help
Vers. 0.70, I am attaching 2 photos
photo1 normal operation of the project
photo2 during the block
=> Drive
you still have an HDD instead of an SSD?
the cause will go about writing to and reading from the file.
RAM is ok CPU too.
In General settings -> project try disable autosave.
SSD
saving is disabled, the problem remains
josaar2001 wrote:
SSD
Don't get me wrong I said the problem is around reading and writing.
De-Backer wrote:
=> Drive
RAM is ok CPU too.
Of course we look further in the code on our side, the OS and the PC is for you.
