Topic: General workflow map
Hello
I have just started using QET for PLC cabinet layout, and I must say it's an excellent tool. As I am still learning, I have a few questions:
1) Is there an updated procedure for converting DXF to element files? The converter script has not been updated for a while.
2) Is there another tool which can be used for drawing elements to scale using real dimensions?
3) If the answer to 2) is no, can you please create or point me to a tutorial showing how to draw elements.
4) There's a lot of ready components in the embedded library. Is that library hosted somewhere, and how can I download the most recent version after an update?
5) I read this topic and it describes a good procedure for drawing elements and thumbnails. The example drawing in the post has a ruler shown on it - how can I do the same?
Thanks
Re: General workflow map
See this link for convert quickly DXF :
https://qelectrotech.org/forum/viewtopi … 702#p10702
4) Just upgrade to latest QET version if not you can get it on our GIT repository or Github.
Thanks
I tried using Inkscape for editing and preparing DXF file for DXFtoELMT, but I got an error "Too many lines", or something similar. I should look into reducing the number of lines obviously. I've never used Inkscape so I am probably doing something wrong.
Anyway I tried drawing a thumbnail assuming that each pixel is 1mm and it works out fine, should be enough for rough sketches of a panel.
