Re: Traduction, manuals and QET internationalization.
Nice! It may be easier for you than ssh +svn.
Fernando I added you.
If you need I can transfer ownership to you.
QElectroTech → Documentation → Traduction, manuals and QET internationalization.
Hello everybody,
I have been searching for the best option for internationalization of the documentation, I have discovered how to define the file name from the figures of the project at conf.py file.
I have defined and tested the following configuration for filename variable:
figure_languge_filename = "{path}{language}/{basename}{ext}"
I will re-structurate the documentation for a final test and once it is made and I see the result, I will inform you to discuss the update of the documentation.
I have seen some small modifications at the release version, I will also use the re-structuration to update the changes.
What is the decision about the future version 0.8? I would like to know what will be changed to do not spend too much effors on those issues.
Generated in 0.023 seconds (40% PHP - 60% DB) with 10 queries
