Topic: Reference of elements with Auto page numbering
It seams a reference is always made up by the "page Id" and then "Row" and "Col" of the element. When using auto page numbering the reference still shows the "page Id" and not the "page number" which is quite confusing.
pc1.png, 46.49 kb, 1280 x 1024
Re: Reference of elements with Auto page numbering
https://download.qelectrotech.org/qet/forum_img/xref1.png
You have to change property about your project: use %F and not %f for folio referencing.
Property of project, new folio and folio referencing.
Capture du 2018-04-30 09-51-23.png, 53.6 kb, 908 x 734
4 (edited by Timofeus2 2018-07-05 17:45:07)
Hello everyone, so as not to create a new topic, I will ask here. How to add these contacts to the circuit ??? that I do not understand how
25436.jpg, 74.58 kb, 1280 x 812
You insert a coil (master) into your drawing and give the coil a label. Then you add a contact (slave) in your drawing. Double-clicking on the contact opens a window where you can connect to the coil. How and where the cross-references are displayed you can set under project properties-new folio cross-references.
Best regards
Stebo
thanks for the answer, but I only get so ...
draw.jpg, 189.25 kb, 1280 x 812
if you use 0.7-dev version see this howto :
8 (edited by Timofeus2 2018-09-03 07:35:59)
Здравствуйте,
если вы используете версию 0.7-dev, посмотрите, как это сделать:
[size=4]QElectroTech V 0.70-dev + svn5495
Компиляция: GCC 8.2.0 - построена с Qt 5.11.1 - работает с Qt 5.11.1 у меня эта версия. и почему то нет того что у вас на видео. У меня поле информации пустое не возможно выбрать. Программа многофункциональна, а я пользуюсь только пару функций, может есть где то подробная инструкция с описанием всех возможностей и функций?
1235.jpg, 351.14 kb, 1920 x 1080
Timofeus2 wrote:
Здравствуйте,
You need enter data in the form before, after you could select element information list in menu dynamic texts.
Вам необходимо ввести данные в форму до, после того, как вы сможете выбрать список информации о элементах в динамических текстах меню.
