Topic: Drolumadaires are one-hump blowtorches.
Once again, our talent helped us pulverize all of our previous records with a total of 137 days without any news nor any signs of life... apart from the forum, bugtracker and Subversion repository, since we have actually been quite productive :-)
Let's begin with some figures:
  • 157 commits;
  • the elements collection now contains 1258 elements within 202 categories
  • The "diff" between the C++ sources at the time of the last news and the sources now is 18032 lines-long.
Yes, 18000 lines! Ok, there is the Unified Diff context. And the copyright-change-that-occurs-on-each-new-year too. But it mainly includes the long-waited WYSIWYG title block template editor:
https://download.qelectrotech.org/qet/img/news-20120224-00.png
https://download.qelectrotech.org/qet/img/news-20120224-02.png
... along with the following features:
  • access to editors through the systray menu
  • new system and user wide collections dedicated to title block templates
  • ability to open/save a template from/to a regular file
  • ability to apply a template by drag'n drop
  • automatic integration into the parent project when dropping a template onto a diagram
  • ability to clean unused templates within a project
  • etc.
Basically, title block templates are managed exactly like elements :-) There is still some work to be done, but it is already pretty usable.
https://download.qelectrotech.org/qet/img/news-20120224-01.png
The "elements panel" (which we could rename to "everything you may access panel") was also refactored to make the creation of tree-based widgets easier. The main consequences for end users are:
  • a sensible speedup of the element editor's  Open/Save dialogs (which were not using the SQLite cache mentioned in the previous news);
  • after having filtered the panel, the tree returns to its initial state instead of keeping almost every item expanded.
Last but not least, a new contributor named Mohamed Souabni began translating the application in arabic, bringing the need to check and fix existing layouts to ensure the application remains consistent in a Right-to-Left fashion:
https://download.qelectrotech.org/qet/img/news-20120224-03.png
https://download.qelectrotech.org/qet/img/news-20120224-04.png
By the way: the topic will hardly make sense for anyone on Earth.
Gray's Law of Programming:
Re: Drolumadaires are one-hump blowtorches.
Salut ,
En complément de la news de Xavier , j'avais besoin d'ajouter dans un classeur existant  mes folios sur diverses modification électrique apportés à cette machine .
Autant essayer de reproduire le même cartouche .
titleblockeditor
titleblockeditor1
titleblockeditor2
le résultat en pdf , bon le logo c'est pas le vrai ........ nomicons/grin
https://download.qelectrotech.org/qet/t … k/test.pdf
