Topic: Export DXF fail QElectroTech-0.70-dev+svn5627-1
Dear Qelectrotech Team
Im was using new version 0.70. I just want to know if the DXF export feature are not available due these version is not official released.
i can export to JPEG, PNG, etc, but when i send to DXF, the only drawing that was exported is the title block.
Thanks a lot for your help, and congratulations for you program.
I want to use 0.7 version because there is the feature to add to elements more information, like we have a database, with manufacturer name, part number, etc.
Re: Export DXF fail QElectroTech-0.70-dev+svn5627-1
Hello Gamezgust,
thanks for the compliments, but we do not have anyone who is expert in DXF and who can review the DXF export code right now, and add new dynamic texts conversion.
https://svnweb.tuxfamily.org/filedetail … atedxf.cpp
Hi Laurent the king of workaround,
have you any solution to convert new dynamic text in old text ?
We have a project to convert in dxf and it's a very big problem to loose all text...
Somebody work on this problem ?
  Nobody !
But try to export to SVG or PDF and convert online SVG or PDF to DXF.
With tool to convert from pdf: text are loosed. And with tool to convert from SVg: text are dirty.
Work great here on my Debian
laurent@debian:~/qet_element_moderation$ pstoedit -f "dxf: -ctl -mm" -split example_project.pdf example_project_%d.dxf
Sinon sous win https://www.scan2cad.com/
Ok, thanks Laurent !
I will try pstoedit this evening at home on linuxmint.
Pstoedit work but text are "empty shape", not a text.I tryed option -polyaslines but not better.
sudo apt-get install printer-driver-cups-pdf
Well, go to print menu -> choose printer and select  CUPS Generic PDF printer
https://download.qelectrotech.org/qet/forum_img/cups.png
https://download.qelectrotech.org/qet/forum_img/cups-option.png
now run pstoedit again.
[font=monospace]unable to map [c2] glyph name 83 encoded as 83 - using the PostScript code value instead.
unable to map [c2] glyph name 50 encoded as 50 - using the PostScript code value instead.
unable to map [c2] glyph name 49 encoded as 49 - using the PostScript code value instead.
unable to map [c2] glyph name 55 encoded as 55 - using the PostScript code value instead.
unable to map [c2] glyph name 65 encoded as 65 - using the PostScript code value instead.
unable to map [c2] glyph name 117 encoded as 117 - using the PostScript code value instead.
unable to map [c2] glyph name 116 encoded as 116 - using the PostScript code value instead.
unable to map [c2] glyph name 45 encoded as 45 - using the PostScript code value instead.
unable to map [c2] glyph name 48 encoded as 48 - using the PostScript code value instead.
unable to map [c2] glyph name 77 encoded as 77 - using the PostScript code value instead.
unable to map [c2] glyph name 97 encoded as 97 - using the PostScript code value instead.
unable to map [c2] glyph name 110 encoded as 110 - using the PostScript code value instead.
....couic
...[/font]
https://download.qelectrotech.org/qet/s … pt_pdf.zip
I think more better if you don't use bitmap fonts in QET settings dynamic_texts fonts select a vector font !
https://www.quora.com/What-are-the-diff … ector-font
OK, I will try. But I don't not what is the link between pstoedit and cups-printer...
Thanks Laurent.
See my ZIP files .
Thanks Laurent.
cups PDF can export vector fonts into PDF, and I think not  QPrinter::PdfFormat  (raster format ) used in QET to generate PDF files.
http://doc.qt.io/qt-5/qprinter.html
Also you need vector fonts if you want DXF texts can be editable after conversion.
A bitmap font is made of raster images that define each character of a font. Bitmap fonts are non-responsive, and do not maintain their shape & character when resized to bigger/smaller sizes. these are generally meant for use in one size only. Proggy is a good example of a bitmap font. Bitmap fonts are rarely used nowadays.
A vector font is a type of font where the glyphs of the font is defined mathematically and graphed on whatever application you are using. Vector fonts can be used anywhere, and are flexible to use. they can be expanded to huge sizes without any problem, as they can retain their size. Most modern fonts like Adobe Source Sans are vector fonts.
I haven't got setting for pdf version on linuxmint ...But, I can add some parameter.
Other workaround.
export your diagrams to svg, open it in inkscape and save to *.DXF.
https://download.qelectrotech.org/qet/forum_img/inkscape_dxf.png
  https://blog.willwinder.com/2014/02/eas … rsion.html
https://github.com/winder/svgToDxf
This script simply runs a command with Inkscape to convert a file from svg to
eps, and then runs another command with pstoedit to convert it from eps to
dxf.
Exemple pour inkscape en CLI et faire de la conversion par lot :
https://superuser.com/questions/303727/ … y-used-bit
EDIT: for Windows users : https://github.com/maujabur/svg_to_dxf
https://forum.hardware.fr/hfr/Graphisme … 6009_1.htm
Thanks Laurent, conversion svg to dxf work well ! I will try conversion by batch....
