Topic: TEXT - FONT
Bonjour ,
Ont trouvé des constantes dans la liste source REV 5625.  nomicons/smile
Est-il possible de changer cela avec qspinbox et de le mettre dans le fichier de configuration?
Have found constants in the source listing REV 5625.
Is it possible to change this with qspinbox and put it in the config file?
REV : 9625
bold
sources/qetgraphicsitem/crossrefitem.cpp
596 : font.setBold(true);
sources/richtext/richtesteditor.cpp
684 : void RichTextEditor::setFontBold(bool b)
    if (b)
        setFontWeight(QFont::Bold);
    else
        setFontWeight(QFont::Normal);
sans serif
sources/getapp.cpp
826 : * By default the font is "sans Serif" and size 9.
835 : QString diagram_texts_family = settings.value("diagramfont", "Sans Serif").toString();
836 : qreal diagram_texts_size     = settings.value("diagramsize", 9.0).toDouble();
844 : diagram_texts_font.setWeight(QFont::Light);
859 : QString diagram_texts_item_family = settings.value("diagramitemfont", "Sans Serif").toString();
860 : qreal diagram_texts_item_size     = settings.value("diagramitemsize", 9.0).toDouble();
872 : dagiram_texts_item_font.setWeight(QFont::Light);
889 : QString dynamic_texts_item_family = settings.value("font_family", "Sans Serif").toString();
890 : qreal dynamic_texts_item_size     = settings.value("dynamicitemsize", 9.0).toDouble();
902 : dynamic_texts_item_font.setWeight(QFont::Light);
919 : QString foliolist_texts_family = settings.value("foliolistfont", "Sans Serif").toString();
920 : qreal foliolist_texts_size     = settings.value("foliolistsize", 9.0).toDouble();
928 : foliolist_texts_font.setWeight(QFont::Light);
sources/ui/configpage/generalconfigurationpage.cpp
257 : QFont font = QFontDialog::getFont(&ok, QFont("Sans Serif", 9), this);
279 : QFont font = QFontDialog::getFont(&ok, QFont("Sans Serif", 9), this);
302 : QFont font = QFontDialog::getFont(&ok, QFont("Sans Serif", 9), this);
diagramtextsfont
sources/qetapp.h
129 :         static QFont diagramTextsFont(qreal = -1.0);
        static QFont diagramTextsItemFont(qreal = -1.0);
        static QFont dynamicTextsItemFont(qreal = -1.0);
        static QFont foliolistTextsFont(qreal = -1.0);
setfont
sources/diagramfoliolist.cpp
273 : qp->setFont(QETApp::diagramTextsFont(13));
souces/editor/graphicpart/partdynamictextfield.cpp
168 : setFont(QETApp::diagramTextsFont(dom_elmt.attribute("font_size", QString::number(9)).toInt()));
218 : setFont(QETApp::diagramTextsFont(dom_element.attribute("size", QString::number(9)).toInt()));
202 : qp.setFont(QETApp::diagramTextsFont(5));
595 : /*QFont font = QETApp::diagramTextsFont(4);
602 : painter.setFont(QETApp::diagramTextsFont(5));*/
792 : painter.setFont(QETApp::diagramTextsFont(6));
sources/qetgraphicsitem/dynamicelementtextitem.cpp
1268 : m_slave_Xref_item->setFont(QETApp::diagramTextsFont(5));
sources/qetgraphicsitem/element.cpp
513 : deti->setText(dom_element.attribute("text", "_"));
514 :        deti->setFontSize(dom_element.attribute("size", QString::number(9)).toInt());
906 : comment_text->setFontSize(6);
925 : location_text->setFontSize(6);
969 : comment_text->setFontSize(6);
981 : location_text->setFontSize(6);
sources/qetgraphicsitem/elementtextitemgroup.cpp
731 : m_slave_Xref_item->setFont(QETApp::diagramTextsFont(5));
    if (b)
    else
text_size
sources/conductorproperties.cpp
226 : text_size(9)
317 : text_size            = e.attribute("numsize", QString::number(9)).toInt();
388 : text_size            = settings.value(prefix + "textsize", "7").toInt();
textwidth
37 : setTextWidth(settings.value("dynamic_with", -1).toInt());
171 : setTextWidth(dom_elmt.attribute("text_width", QString::number(-1)).toDouble());
47 : setTextWidth(settings.value("dynamic_with", -1).toInt());
169 : setTextWidth(dom_elmt.attribute("text_width", QString::number(-1)).toDouble());
909 : comment_text->setTextWidth(80);
927 : location_text->setTextWidth(80);
971 : comment_text->setTextWidth(80);
982 : location_text->setTextWidth(80);
font_size
sources/editor/graphicspart/partdynamictextfield.cpp
sources/editor/graphicpart/parttext.cpp
61 : if (!ok || font_size < 1) font_size = 20;
sources/editor/texteditor.cpp
40 : font_size -> setRange(0, 144);
165 : dom_elmt.attribute("font_size", QString::number(9)).toInt());
int font_size = 1;
sources/titleblockcell.cpp
15 : font_size = 9;
198 : font_size = -1;
font-size
sources/aboutqet.cpp
76 : QLabel *title = new QLabel("<span style=\"font-weight:0;font-size:16pt;\">QElectroTech V " + QET::displayedVersion + "</span>");
fontsize
Re: TEXT - FONT
look your config is saved in QElectroTech.conf example here :
[General]
border-columns_0=false
diagramitemfont=Sans Serif
diagramitemsize=9
diagramitemstyle=0
diagramitemweight=50
dxf_path=default
dynamic_rotation=270
dynamic_with=0
dynamicitemfont=URW Palladio L
dynamicitemsize=9
dynamicitemstyle=Regular
dynamicitemweight=50
foliolistfont=Noto Serif
foliolistsize=7
folioliststyle=Italic
foliolistweight=50
font_family=Sans Serif
lang=fr
usesystemcolors=true
Re: TEXT - FONT
Hi Erick,
perhaps we use http://doc.qt.io/qt-5/qfont.html#key function in the future (Returns the font's key, a textual representation of a font).
[General]
diagramitemfont="Sans Serif,9,-1,5,50,0,0,0,0,0,Regular"
dynamic_rotation=0
dynamic_with=-1
foliolistfont="Sans Serif,9,-1,5,50,0,0,0,0,0,Regular"
font_family="Sans Serif,9,-1,5,50,0,0,0,0,0,Regular"
lang=fr
But now I saw a litle problem with font type members : regular, Italic, Bold, thin, etc.. not applied ..
I keep font_size for compatibility with old project.
If you want to play game :  nomicons/smiley-green
svn patch font_key_2.diff
make clean
qmake qelectrotech.pro
make -j$(nproc)
https://download.qelectrotech.org/qet/forum_img/font.key2.png
Re: TEXT - FONT
Refresh patch
