Topic: function to the terminal block generator
Hello,
I have successfully installed the terminal block generator and it works. I noticed that I can apply the terminal block generator only once to a project. Even if I delete the elements, clean up and save the drawing and then reopen it, I can not start the terminal block generator. The same applies if I add later terminals in the drawing. Is this behavior correct?
Best regards
Stebo
