Topic: function to the terminal block generator
I have successfully installed the terminal block generator and it works. I noticed that I can apply the terminal block generator only once to a project. Even if I delete the elements, clean up and save the drawing and then reopen it, I can not start the terminal block generator. The same applies if I add later terminals in the drawing. Is this behavior correct?
Best regards
Stebo
Re: function to the terminal block generator
j'ai moi aussi le même soucisque Calypso.
Je suis sous environnement WIN10 avec QET V0.60
Hi cy.bernard
Look forum terminal block generator "Ideas to solve terminal blocks cration to post 198)
Best regards
DMH78
