It can't generate terminal block, yes?
QElectroTech → Terminal block generator → Ideas to solve Terminal Blocks creation
It can't generate. Only is a preview version to check the usability. I don't know if right-clicking to autofill it's a good idea. Maybe we need to create another column with extra info,...
I don't know if it's worth to put all terminal blocks together or create a TAB for every terminal block...
It 's better than enter manual number, I think and no risk to mistake.
New Debian Sid, Stretch qet_tb_generator:
https://download.qelectrotech.org/qet/s … generator/
Add python3-pyqt5 buildep and recommend, deleted pyqt5 in source file requires.txt
qet-tb-generator-0.7.74/qet_tb_generator.egg-info$ cat requires.txt
qet-tb-generator-0.7.74/qet_tb_generator.egg-info$but it appear sh***t always in /usr/lib/python3/dist-packages/qet_tb_generator-0.7.74.egg-info/requires.txt
If not work remove pyqt5 in requires.txt like this
sudo sed -i '/pyqt5/d' /usr/lib/python3/dist-packages/qet_tb_generator-0.7.74.egg-info/requires.txt
Ok , I found how to produce qet_tb_generator deb and fix requires.txt
laurent@debian:~/result/qet-tb-generator-0.7.74/debian$ cat py3dist-overrides
pyqt5 python3-pyqt5
It would be nice if the script would put its data form the XML-file first in a database (e.g. sqlite). From here the data could be edited in a kind of terminal-editor. Some of the actions might be inserting empty terminals. Changing positions of terminals in the terminal block and switching internal/external wiring.
Afterwards this data might be used for various outputs like terminal blocks, but also terminal or cable diagrams. It would be nice in the future for these scripts, as mentioned before, if the QET-terminals can have their own tag-information.
To visualize it a bit I'll add some pictures of what it might look like.
pyqt5 python3-pyqt5
I upload qet_tb_generator 0.7.74 deb packages in all Ubuntu PPA and also QET debian repository, please try it :
sudo apt-get update
sudo apt-get install qet_tb_generatorNo need to install pip3 env (~150 Mio installed) like previous recommend install [s]sudo pip3 install qet_tb_generator[/s]
you can just delete related packages installed by old pip3 command on /usr/local/lib/pythonVERSION/dist-packages directory
or
sudo pip3 uninstall qet_tb_generator
sudo pip3 uninstall PyQt5https://launchpad.net/~scorpio/+archive/ubuntu/ppa
In future I remove pyqt5-dev-tools recommends in QET deb packages, no need if qet-tb-generator is installed by apt on repositories.
On my Debian unstable :
$ apt-rdepends qet-tb-generator
Reading package lists... Done
Building dependency tree
Reading state information... Done
qet-tb-generator
Depends: python3-pyqt5
Depends: python3:any (>= 3.3.2-2~)
python3-pyqt5
Depends: libc6 (>= 2.14)
Depends: libgcc1 (>= 1:3.0)
Depends: libpython3.6 (>= 3.6.4~rc1)
Depends: libqt5core5a (>= 5.10.0)
Depends: libqt5dbus5 (>= 5.6.0~beta)
Depends: libqt5designer5 (>= 5.9.1)
Depends: libqt5gui5 (>= 5.10.0)
Depends: libqt5help5 (>= 5.9.1)
Depends: libqt5network5 (>= 5.10.0)
Depends: libqt5printsupport5 (>= 5.10.0)
Depends: libqt5test5 (>= 5.6.0~beta)
Depends: libqt5widgets5 (>= 5.10.0)
Depends: libqt5xml5 (>= 5.1.0)
Depends: libstdc++6 (>= 5)
Depends: python3 (>= 3.6~)
Depends: qtbase-abi-5-10-0
Depends: sip-py3api-12.4
libc6
Depends: libgcc1
libgcc1
Depends: gcc-8-base (= 8-20180414-1)
gcc-8-base
libpython3.6
Depends: libc6 (>= 2.25)
Depends: libexpat1 (>= 2.1~beta3)
Depends: libpython3.6-stdlib (= 3.6.5-3)
Depends: zlib1g (>= 1:1.2.0)
libexpat1
libpython3.6-stdlib
Depends: libbz2-1.0
Depends: libc6 (>= 2.15)
Depends: libdb5.3
Depends: libffi6 (>= 3.0.4)
Depends: liblzma5 (>= 5.1.1alpha+20120614)
Depends: libmpdec2
Depends: libncursesw5 (>= 6)
Depends: libpython3.6-minimal (= 3.6.5-3)
Depends: libreadline7 (>= 7.0~beta)
Depends: libsqlite3-0 (>= 3.5.9)
Depends: libtinfo5 (>= 6)
Depends: mime-support
libbz2-1.0
Depends: libc6 (>= 2.4)
libdb5.3
Depends: libc6 (>= 2.17)
libffi6
liblzma5
libmpdec2
libncursesw5
Depends: libtinfo5 (= 6.1-1)
libtinfo5
Depends: libc6 (>= 2.16)
Depends: libssl1.1 (>= 1.1.0)
libssl1.1
Depends: debconf (>= 0.5)
Depends: debconf-2.0
debconf
PreDepends: perl-base (>= 5.20.1-3~)
perl-base
PreDepends: dpkg (>= 1.17.17)
PreDepends: libc6 (>= 2.23)
dpkg
Depends: tar (>= 1.28-1)
PreDepends: libbz2-1.0
PreDepends: libc6 (>= 2.14)
PreDepends: liblzma5 (>= 5.2.2)
PreDepends: libselinux1 (>= 2.3)
PreDepends: zlib1g (>= 1:1.1.4)
tar
PreDepends: libacl1 (>= 2.2.51-8)
PreDepends: libc6 (>= 2.17)
PreDepends: libselinux1 (>= 1.32)
libacl1
Depends: libattr1 (>= 1:2.4.46-8)
libattr1
libselinux1
Depends: libpcre3
libpcre3
zlib1g
debconf-2.0
libreadline7
Depends: readline-common
readline-common
Depends: dpkg (>= 1.15.4)
Depends: install-info
install-info
PreDepends: dpkg (>= 1.16.1)
libsqlite3-0
mime-support
libqt5core5a
Depends: libdouble-conversion1 (>= 2.0.0)
Depends: libgcc1 (>= 1:3.4)
Depends: libglib2.0-0 (>= 2.22.0)
Depends: libicu57 (>= 57.1-1~)
Depends: libpcre2-16-0 (>= 10.31)
Depends: libstdc++6 (>= 4.1.1)
libstdc++6
Depends: libc6 (>= 2.18)
Depends: libgcc1 (>= 1:4.2)
libglib2.0-0
Depends: libmount1 (>= 2.19.1)
Depends: libpcre3
Depends: zlib1g (>= 1:1.2.2)
libmount1
Depends: libblkid1 (>= 2.17.2)
Depends: libselinux1 (>= 2.6-3~)
libblkid1
Depends: libuuid1 (>= 2.16)
libuuid1
libicu57
Depends: libstdc++6 (>= 5.2)
libpcre2-16-0
libqt5dbus5
Depends: libdbus-1-3 (>= 1.9.14)
libdbus-1-3
Depends: libsystemd0
libsystemd0
PreDepends: libc6 (>= 2.27)
PreDepends: libgcrypt20 (>= 1.8.0)
PreDepends: liblz4-1 (>= 0.0~r113)
PreDepends: liblzma5 (>= 5.1.1alpha+20120614)
libgcrypt20
Depends: libgpg-error0 (>= 1.25)
libgpg-error0
liblz4-1
qtbase-abi-5-10-0
libqt5designer5
Depends: libqt5gui5 (>= 5.7.0)
Depends: libqt5xml5 (>= 5.0.2)
libqt5gui5
Depends: fontconfig
Depends: libdrm2 (>= 2.4.30)
Depends: libegl1
Depends: libfontconfig1 (>= 2.12)
Depends: libfreetype6 (>= 2.6)
Depends: libgbm1 (>= 8.1~0)
Depends: libgl1
Depends: libharfbuzz0b (>= 1.2.6)
Depends: libice6 (>= 1:1.0.0)
Depends: libinput10 (>= 0.15.0)
Depends: libjpeg62-turbo (>= 1.3.1)
Depends: libmtdev1 (>= 1.0.8)
Depends: libpng16-16 (>= 1.6.2-1)
Depends: libqt5dbus5 (>= 5.0.2)
Depends: libqt5network5 (>= 5.0.2)
Depends: libsm6
Depends: libudev1 (>= 183)
Depends: libx11-6
Depends: libx11-xcb1
Depends: libxcb-glx0
Depends: libxcb-icccm4 (>= 0.4.1)
Depends: libxcb-image0 (>= 0.2.1)
Depends: libxcb-keysyms1 (>= 0.4.0)
Depends: libxcb-randr0 (>= 1.3)
Depends: libxcb-render-util0
Depends: libxcb-render0
Depends: libxcb-shape0
Depends: libxcb-shm0
Depends: libxcb-sync1
Depends: libxcb-xfixes0
Depends: libxcb-xinerama0
Depends: libxcb-xkb1
Depends: libxcb1 (>= 1.8)
Depends: libxi6 (>= 2:1.5.99.2)
Depends: libxkbcommon-x11-0 (>= 0.5.0)
Depends: libxkbcommon0 (>= 0.5.0)
Depends: libxrender1
fontconfig
Depends: fontconfig-config
Depends: libfontconfig1 (>= 2.13.0)
Depends: libfreetype6 (>= 2.2.1)
fontconfig-config
Depends: fonts-dejavu-core
Depends: fonts-freefont
Depends: fonts-liberation
Depends: ttf-bitstream-vera
Depends: ucf (>= 0.29)
fonts-dejavu-core
fonts-freefont
fonts-liberation
ttf-bitstream-vera
ucf
Depends: coreutils (>= 5.91)
Depends: debconf (>= 1.5.19)
Depends: sensible-utils
coreutils
PreDepends: libattr1 (>= 1:2.4.46-8)
PreDepends: libselinux1 (>= 2.1.13)
sensible-utils
libfontconfig1
Depends: fontconfig-config (>= 2.13.0-4)
Depends: libexpat1 (>= 2.0.1)
Depends: libfreetype6 (>= 2.3.9)
libfreetype6
libpng16-16
Depends: zlib1g (>= 1:1.2.3.4)
libdrm2
Depends: libdrm-common (>= 2.4.91-2)
libdrm-common
libegl1
Depends: libegl-mesa0
Depends: libegl-vendor
Depends: libglvnd0 (= 1.0.0+git20180308-1)
libegl-mesa0
Depends: libdrm2 (>= 2.4.75)
Depends: libgbm1 (= 18.0.0-1)
Depends: libglapi-mesa
Depends: libwayland-client0 (>= 1.11.0)
Depends: libwayland-server0 (>= 1.11.0)
Depends: libx11-6
Depends: libxcb-dri2-0 (>= 1.8)
Depends: libxcb-dri3-0
Depends: libxcb-present0
Depends: libxcb1 (>= 1.9.2)
Depends: libxshmfence1
libgbm1
libwayland-server0
libglapi-mesa
libwayland-client0
libx11-6
Depends: libx11-data
Depends: libxcb1 (>= 1.11.1)
libx11-data
libxcb1
Depends: libxau6
Depends: libxdmcp6
libxau6
libxdmcp6
Depends: libbsd0 (>= 0.2.0)
libbsd0
libx11-xcb1
Depends: libc6 (>= 2.2.5)
libxcb-dri2-0
Depends: libxcb1
libxcb-dri3-0
Depends: libxcb1 (>= 1.12)
libxcb-present0
Depends: libxcb1
libxcb-sync1
Depends: libxcb1
libxcb-xfixes0
Depends: libxcb1
libxshmfence1
libegl-vendor
libglvnd0
libgl1
Depends: libglx0 (= 1.0.0+git20180308-1)
libglx0
Depends: libglx-mesa0
Depends: libglx-vendor
Depends: libx11-6 (>= 2:1.4.99.1)
Depends: libxext6
libglx-mesa0
Depends: libgl1-mesa-dri
Depends: libglapi-mesa (= 18.0.0-1)
Depends: libxcb-glx0 (>= 1.8)
Depends: libxdamage1 (>= 1:1.1)
Depends: libxext6
Depends: libxfixes3
Depends: libxxf86vm1
libgl1-mesa-dri
Depends: libdrm-amdgpu1 (>= 2.4.89)
Depends: libdrm-intel1 (>= 2.4.38)
Depends: libdrm-nouveau2 (>= 2.4.66)
Depends: libdrm-radeon1 (>= 2.4.31)
Depends: libelf1 (>= 0.142)
Depends: libllvm6.0 (>= 1:6.0~svn298832-1~)
Depends: libsensors4 (>= 1:3.0.0)
libdrm-amdgpu1
Depends: libdrm2 (>= 2.4.89)
libdrm-intel1
Depends: libdrm2 (>= 2.4.38)
Depends: libpciaccess0
libpciaccess0
Depends: libc6 (>= 2.7)
libdrm-nouveau2
libdrm-radeon1
libelf1
libllvm6.0
Depends: libedit2 (>= 2.11-20080614)
Depends: libstdc++6 (>= 6)
libedit2
Depends: libbsd0 (>= 0.0)
Depends: libncurses5 (>= 6)
libncurses5
libsensors4
libxcb-glx0
Depends: libxcb1
libxdamage1
Depends: libxfixes3
libxfixes3
Depends: libx11-6 (>= 2:1.6.0)
libxext6
libxxf86vm1
Depends: libxext6
libglx-vendor
libharfbuzz0b
Depends: libfreetype6 (>= 2.7.1)
Depends: libglib2.0-0 (>= 2.31.8)
Depends: libgraphite2-3 (>= 1.2.2)
libgraphite2-3
libice6
Depends: x11-common
x11-common
Depends: lsb-base (>= 1.3-9ubuntu2)
lsb-base
libinput10
Depends: libc6 (>= 2.9)
Depends: libevdev2 (>= 1.3)
Depends: libinput-bin (>= 1.10.4-1)
Depends: libmtdev1 (>= 1.1.0)
Depends: libwacom2 (>= 0.20)
libevdev2
libinput-bin
Depends: libwacom2 (>= 0.22)
libudev1
Depends: libc6 (>= 2.26)
libwacom2
Depends: libc6 (>= 2.8)
Depends: libglib2.0-0 (>= 2.24.0)
Depends: libgudev-1.0-0 (>= 146)
Depends: libwacom-common (= 0.29-1)
libgudev-1.0-0
Depends: libglib2.0-0 (>= 2.37.3)
Depends: libudev1 (>= 199)
libwacom-common
libmtdev1
libjpeg62-turbo
libqt5network5
Depends: libssl1.1
libsm6
libxcb-icccm4
Depends: libxcb1
libxcb-image0
Depends: libxcb-util0 (>= 0.3.8)
Depends: libxcb1
libxcb-shm0
libxcb-util0
Depends: libxcb1
libxcb-keysyms1
Depends: libxcb1
libxcb-randr0
libxcb-render-util0
Depends: libxcb1
libxcb-render0
libxcb-shape0
Depends: libxcb1
libxcb-xinerama0
Depends: libxcb1
libxcb-xkb1
Depends: libxcb1
libxi6
Depends: libxext6
libxkbcommon-x11-0
Depends: libxcb1 (>= 1.6)
Depends: libxkbcommon0 (= 0.8.0-1)
libxkbcommon0
Depends: xkb-data
xkb-data
libxrender1
libqt5widgets5
libqt5xml5
libqt5help5
Depends: libqt5gui5 (>= 5.0.2)
Depends: libqt5sql5 (>= 5.3.0)
Depends: libqt5widgets5 (>= 5.6.0~beta)
libqt5sql5
libqt5printsupport5
Depends: libcups2 (>= 1.4.0)
Depends: libqt5widgets5 (>= 5.7.0)
libcups2
Depends: libavahi-client3 (>= 0.6.16)
Depends: libavahi-common3 (>= 0.6.16)
Depends: libgnutls30 (>= 3.5.6)
Depends: libgssapi-krb5-2 (>= 1.14+dfsg)
libavahi-client3
Depends: libavahi-common3 (>= 0.6.22)
libavahi-common3
Depends: libavahi-common-data
libgnutls30
Depends: libgmp10 (>= 2:6)
Depends: libhogweed4
Depends: libidn2-0 (>= 0.6)
Depends: libnettle6
Depends: libp11-kit0 (>= 0.23.1)
Depends: libtasn1-6 (>= 4.12)
Depends: libunistring2 (>= 0.9.7)
libgmp10
libhogweed4
Depends: libgmp10 (>= 2:6.0.0)
Depends: libnettle6 (= 3.4-1)
libnettle6
libidn2-0
libunistring2
libp11-kit0
libtasn1-6
libgssapi-krb5-2
Depends: libcomerr2 (>= 1.34)
Depends: libk5crypto3 (>= 1.16)
Depends: libkeyutils1 (>= 1.4)
Depends: libkrb5-3 (= 1.16-2)
Depends: libkrb5support0 (>= 1.15~beta1)
libcomerr2
Depends: libcom-err2
libcom-err2
libk5crypto3
Depends: libkrb5support0 (>= 1.16)
libkeyutils1
libkrb5support0
libkrb5-3
Depends: libk5crypto3 (>= 1.15~beta1)
Depends: libkeyutils1 (>= 1.5.9)
Depends: libkrb5support0 (= 1.16-2)
libqt5test5
python3
Depends: libpython3-stdlib (= 3.6.5-3)
Depends: python3.6 (>= 3.6.5-2~)
PreDepends: python3-minimal (= 3.6.5-3)
libpython3-stdlib
Depends: libpython3.6-stdlib (>= 3.6.5-2~)
python3.6
Depends: python3.6-minimal (= 3.6.5-3)
python3.6-minimal
PreDepends: libc6 (>= 2.25)
python3-minimal
Depends: dpkg (>= 1.13.20)
Depends: python3.6-minimal (>= 3.6.5-2~)
python3:any
sip-py3api-12.4
Hi. I attach v1.0.1.alpha to check the usability.
For now:
- tested with version 0.7 of QET documents, but will work with version 0.6 too.
- creates a tab for every terminal block
- 4 columns can be edited:
- Terminal position
- Terminal type (STANDARD, GROUND or FUSE)
- CABLE
- CABLE's CONDUCTOR
- This 4 fields can be modified as always (left clicking and writing) or by right click (auto-fill)
- The button SAVE save changes creating a diferent QET project file (to avoid losing data in testing versions)
- Al the info is saved in the 'function' field.
- Opening a previosly save QET project, the terminals info are readed.
- Runing 'python3 qet_tb.py' without parameters, a file dialog appears to select a project.
- Is possible to run specifying a projet: 'python3 qet_tb.py examples/basic.qet'
@Scorpio; The 0.xx version used QT, and a lod of dependencies are required. This new version almost always no require dependencies.
@b.w.v.leeuwen: I saved the pictures as a reference. Thanks.
I save my project to latest 0.7 devel svn , if it can help you :
laurent@debian:/media/backup6/download/v1.0.0.alpha$ python3 qet_tb.py /home/laurent/Documents/LAURENT/schemas/gestion-defib/gestion-defib-18-02-23-RR6.qet
File "qet_tb.py", line 1050, in <module>
main()
File "qet_tb.py", line 1036, in main
qet_termials_used = qet_project.get_list_of_used_terminals()
File "qet_tb.py", line 307, in get_list_of_used_terminals
if self._isValidTerminal(element):
File "qet_tb.py", line 194, in _isValidTerminal
if re.search(':', self._getElementName(element)):
File "qet_tb.py", line 145, in _getElementName
for t in element.find('elementInformations').findall('elementInformation'):
AttributeError: 'NoneType' object has no attribute 'findall'
[18:56:21] laurent@debian:/media/backup6/download/v1.0.0.alpha$
I paste two folios in your example, seems to work, I think program crash with a lot of terminal in my project?
I'm going to:
1. Split large terminal blocks. If a term. block has more then 40 terminals it will be split into a several terminal blocks.
2. Order terminals by default by the ID columns if not POS is specified.
@scorpio: Can you send me a email with the sample project that crashed? Thanks.
@unalcade : sending files by email, done, but sending here too.
~ 13 terminals block.
This is not the last version of the project, i forgot to get it back to my job tonight.
Thanks.
Edit :
[16:31:37] laurent@debian:/media/backup6/download/v1.0.0.alpha$ python3 qet_tb.py /home/laurent/Documents/LAURENT/schemas/gestion-defib/gestion-defib-18-01-26.qet
main()
File "/usr/lib/python3.6/re.py", line 182, in search
return _compile(pattern, flags).search(string)
TypeError: expected string or bytes-like object
[16:32:46] laurent@debian:/media/backup6/download/v1.0.0.alpha$ python3 qet_tb.py /home/laurent/Documents/LAURENT/schemas/gestion-defib/gestion-defib-18-02-23-RR6_latest_0.7_svn.qet
main()
How to start new plugin after intallation ?
v1.0.1.alpha is only a preview version to check the usability.
On your v1.0.1.alpha folder run
python3 qet_tb.py path to your project
Like me :
Afaik, isn't a problem for users, by example for Debian/Ubuntu/mint, etc : It's only require python3-pyqt5 (15,7 MB), qet_tb_generator (153 kB) with deb packages, and also QET need Qt 5 libs for run.
After if you think is more easy for you to develop your plugin with Qt 5 python libs you can keep on.
apt-cache show python3-pyqt5
Package: python3-pyqt5
Source: pyqt5
Version: 5.10.1+dfsg-1
Installed-Size: 15371
Maintainer: Debian Python Modules Team <python-modules-team@lists.alioth.debian.org>
Architecture: amd64
Depends: python3 (<< 3.7), python3 (>= 3.6~), python3:any (>= 3.3.2-2~), libc6 (>= 2.14), libgcc1 (>= 1:3.0), libpython3.6 (>= 3.6.4~rc1), libqt5core5a (>= 5.10.0), libqt5dbus5 (>= 5.6.0~beta), libqt5designer5 (>= 5.9.1), libqt5gui5 (>= 5.10.0), libqt5help5 (>= 5.9.1), libqt5network5 (>= 5.10.0), libqt5printsupport5 (>= 5.10.0), libqt5test5 (>= 5.6.0~beta), libqt5widgets5 (>= 5.10.0),
libqt5xml5 (>= 5.1.0), libstdc++6 (>= 5), qtbase-abi-5-10-0, sip-py3api-12.4
Suggests: python3-pyqt5-dbg
Description-en: Python 3 bindings for Qt5
PyQt5 exposes the Qt5 API to Python 3. This package contains the following
modules:
* QtCore
* QtDBus
* QtDesigner
* QtGui
* QtHelp
* QtNetwork
* QtPrintSupport
* QtTest
* QtWidgets
* QtXml
Description-md5: fbb6f230f704ef45fbf057abc0d8bdba
Homepage: http://www.riverbankcomputing.co.uk/software/pyqt/
Tag: uitoolkit::qt
Section: python
Priority: optional
Filename: pool/main/p/pyqt5/python3-pyqt5_5.10.1+dfsg-1_amd64.deb
MD5sum: 23bb98e1a89d6b771f862f5425fdb02b
SHA256: 2c511f097fd997f1ec0efb7594db3169d2a3bc670ab55b1b77a6c31b54bcb8a2
Hi. I've attached version 1.0.2.alpha.
What is working for now:
- opening a complex project is possible
- splits a terminal block strip into segments of 30 terminal blocks. Every segment is showed in a different tab.
- is possible to edit the columns: POS, TYPE (standard, ground, fuse), CABLE (-W1,...), CABLE COND (color o number of the conductor in the CABLE)
- is possible to SAVE the modifications and opening again preserving data.
- the terminals in a terminal block strip are sorted by the next columns: POSITION, CABLE, CABLE_COND and TERMINAL NAME.
What is coming:
- after edit fields (position, cable, cable conductor,...), pressing the button REFRESH, will show ther terminals in a new order (according of the edited data)
- pressing the button DRAW will generate, in the personal library of QET, a new element for every TAB.
Nice, thanks !
Wait to see more. ;-)
Nice indeed, but when loading terminals which have no terminal number (but do have a terminal Id) the script fails to see them. It would be nice to have a possibility when making the drawing just to enter the information to what terminal box the terminals belong (X1, X2, X3 etc). The script will insert them following the order in which they are placed (Page, Column, Row). Than a auto-numbering option might number all the separate terminals (X1:1, X1:2, X1:3 etc, X2:1, X2:2, X2:3 etc, X3:1, X3:2, X3:3 etc).
When there are pre-defined terminals (e.g. X2:5), these ones will be frozen by default (kept while numbering the terminals). An option might be to renumber the whole terminal box, or defreeze separate terminals.
Another nice option might be to use the location field. When the "location"-field is empty it is similar to the "location" of the Folio. When the "location" field of the element defers from the location of the Folio, the terminal is an external terminal. The same is true for elements that are connected with. A terminal might be connected internal with a relay contact. Both the location filed of the terminal and the location field of the relay-contact are empty. This means that it is an internal connection. At the other side of the terminal we have a motor connected. The location field of the motor is "+Roof" and thus defers from the location of the terminal. His means that this connection is an External connection.
The motor might have a Function-description, like "Ventilator 1". This field might be used to fill out a "comment" field for use in the terminal box.
When there are two or more external connections, they might be added to the string, separated by a comma (e.g. Ventilatior 1, Ventilator 2).
Hi.
This new alpha 1.0.3 allows pressing REFRESH button and sorts terminals according the data edited in the columns POS, CABLE and CABLE CONDUCTOR. A terminal block is divided into several segments (every segments fits on a page). Every segment is represented in a different tab. REFRESH works between segments. For efample, if the terminal block -X1 has 2 segments (-X1_1 and -X1_2) and you set POS = 1 for a terminal of the segment -X1_1, when you press REFRESH, this terminal goes to the -X1_1 segment.
Next step, I'm going to start drawing the terminal blocks to import in QET.
Hi, Unalcalde
you could add a auto loop when use right click on "TYPE " columns like this : GROUND, FUSE, STANDARD, GROUND, FUSE, STANDARD, etc ?
Thanks.
Hi, I introduce the versión 1.0.4 alpha.
Now is able to "draw" the terminal blocks.
Remember: In the plugin's title bar appears the version.
The Terminal blocks appear in the "IMPORTED ELEMENTS" section:
To do:
* if not CABLE is indicated ( e.g. -X1, -X2,...) all terminals are draw as part of unique conductor. The next version will solve this.
* if you draw again the terminal blocks, creates duplicate elements. Next version will not duplicate elements.
* the QET file with the attributes edited in the plugin and the terminal blocks elements are save on a different file name. When works well, it will edit the current QET file.
* auto loop right clicking in TYPE column (good idea scorpio810)
* next version will draw the different terminal type: STANDARD, GROUND and FUSE.
Latest qet_tb.py python script need python3-lxml package.
When you launch command if you have this warning :
File "qet_tb.py", line 31, in <module>
import lxml.etree as etree # python3-lxml
ModuleNotFoundError: No module named 'lxml'Install python3-lxml
Les paquets suivants ont été installés :
python3-bs4 (4.6.0-1)
python3-html5lib (0.999999999-1)
python3-lxml (4.2.1-1)
python3-webencodings (0.5-2)
Hi, this new version (1.0.5) :
* doesn't require the module lxml.
* solves the problem drawing conductors that not belongs to any cable.
* right-clicking on Terminal type column loops 'STANDARD', 'GROUND' and FUSE.
Any design ideas for GROUND and FUSE terminals?
just a little remark I preferred when the conductor text is placed in the left position.
Possible design.
Hi, this new version 1.0.6.alpha creates terminal blocks like:
The conductors labels are on left side. A logo identifies the terminal type.
Please test the plug-in to fix errors.
For easy use, will be good if QET calls the plugin as: "qet_tb %f", where %f is the current project path.
To Do:
- draw bridges between terminals if have the same name or same north cable id
- add a checkbox the overwrite or not, the terminal block config in the original qet file.
- check compatibility with QET 0.6
- uploads the project to pip repositories allowing a easy installation and auto-updates of the plug-in (as usual: pip3 install qet-tb-generator)
Nice Raul, thanks.
you could add a informations for user, like progressbar, dialog, or "generating terminal blocks, please wait", when user click on button "create terminal blocks", thanks.
Generated in 0.051 seconds (36% PHP - 64% DB) with 12 queries
