Topic: Help lines to set items in diagram
Hello,
if there a tool exist to catch items in same height?
Or give it a tool to set helplines without to set or copy on every new folio and delete it when printing?
QElectroTech → EN : Help, suggestions, discussions, ... → Help lines to set items in diagram
Hello,
perhaps with https://qelectrotech.org/showcategory.p … 26comments
https://qelectrotech.org/svgelement.php … ;scale=1.0
Hi Max,
you should try this:
- create a new folio.
- set the folio background to grey (button is in the upper tool bar)
- draw a horizontal line and set its color to white and lock its position
- repeat as much as you need!
When printing, you don't need to delete anything since the lines are white and only visible if you set the background to grey.
The result looks like this:
Yeah, that's two good helpers.
Thank you guys!
Generated in 0.027 seconds (24% PHP - 76% DB) with 12 queries
