Topic: Folio referencing - only by page ID?! "Use label instead of folio ID"
Trying to create a project with the following structure:
1 - page1
2 - page2
5 - page5
The pages will have id=1, id=2, id=3.
Initially I used spare pages in between, to keep all the references and numbering with the correct page number:
1 - page1
2 - page2
3 - spare
4 - spare
5 - page5
Then I discovered "Use label instead of folio ID" which I activated. AWESOME - I thought. Everything worked perfectly, I did not need the spare pages anymore.
Everything good, until I started placing coming and going arrows. The reference arrows still use the folio ID instead of the page label. Right now I have:
1 - page1
2 - page2
5 - page5
...with two linked arrows on page 2 and 5. The arrow on page 5 says "2 - A1" - ok. The arrow on page 2 says "3 - A1" instead of "5 - A1" - not ok.
Is that something normal? Is that a bug?
Re: Folio referencing - only by page ID?! "Use label instead of folio ID"
You have to change formula about report folio.
Project proterties/New folio and folio report:
on the fomula %f is id of folio and %F label of folio
Merci, monsieur! Works perfectly!
