Topic: When dragging element from collections to schema and it autoconnects,
... it overwrites the conductor network it connetcs to with the folio preset parameters for new conductor!
(Also, undo do not completely restore everything in this case.)
This does not happen if the new element is first placed unconnected, and then moved to autoconnect, or a conductor is drawn manually: then it works as it should: the new connector picks up the parameters of the already existing connector(s) it connect to.
I guess this is a bug, but it could also be a feature i personally just do not like...
