1 (edited by Calypso 2016-10-25 22:15:18)
Topic: Problems with coductor numbering
When I start a new project, and the automatic numbering is activated, this is not always displayed at the latest on the second page, the numbering is not accepted any further. Do everything as usual. I work with QElectroTech V0.51-dev+svn4759
Best regards
Stebo
2 (edited by Morganol 2016-10-25 23:27:35)
Re: Problems with coductor numbering
For me fresh autonumber works partially, but as soon as i edit it or make name it manually, conductor label get invisible on shema.
In the dialog the content is OK, but on shema not visible;
i can click the emplty label there and enter sometning, but then it is shown empty again, byt what i entered there is in the textfield in the dialog.
Some issue with displaying it?
r4761
Thank you for report this bug.
Edit: I think this it policy management problem or freeze label fonction !
Setting policy management to build, conductor text set conducteur text visible ..
Revision: 4762
Author:   blacksun
Date:     2016-10-26 18:26:05 +0200 (Wed, 26 Oct 2016)
Log Message:
Bug fix : conductor don't apply text to text item
That was quick, many thanks nomicons/smile
Since my english is too bad to describe the problem I will try to create a video.
Best regards
Stebo
7 (edited by Calypso 2016-10-27 18:39:57)
The problem is, when connecting the references the conductor number and Voltage / Protocoll are not transferred with. But I have also overlooked something.
Best regards
Stebo
Have you tried with report folio, this features was added specifically for my use with report folio element and run  if I remember only with this element.
BTW, perhaps possible to add it.
Best regards,
Sorry the video is too big. I've found that it works only without auto numbering. If I use auto numbering, the references are linked
But not the conductor number. Does not work with autonumberin, I have understood so?
Best regards
Stebo
11 (edited by Morganol 2016-10-27 20:07:59)
Edit: deleted, i was way off...  /EDIT
@ Calyso, you could put your video to youtube, Vimeo, google drive and other cloud storage, or send me by email your video.
Calypso wrote:
Best regards
Stebo
Thanks for your video and for reporting this problem Calypso.
Yes thank you for reporting, Calypso.
Scorpio, you keep track of bugs reported here on forum "manually", or is there another tracking system than https://qelectrotech.org/bugtracker/ ?
I mean should we create issues there for this bug and another for the possibly related https://qelectrotech.org/forum/viewtopi … 5806#p5806 ?
Video recording tip
For making videos smaller, plan the demonstration so only a part of screen need recording, and only record that interesting part of screen, and lower framerate, increase compression etc.  I found http://www.maartenbaert.be/simplescreenrecorder/ is a really easy and efficient recorder.
To crop and compres already recorded videos https://handbrake.fr/ is really nice.
Both are packaged in Mageia which i use, some distros neeed a little bit manual work.
I lifted it into bugtracker: https://qelectrotech.org/bugtracker/view.php?id=118
Use this workaround : auto connect report folio elements before linking report folio to other, like this :
