Topic: Crossing Lines
Is there a was to indicate the lines crossing by a semi-circle showing the lines cross and are not connected?
Re: Crossing Lines
Sorry auto type took over there :-(
[size=1][font=Verdana, Helvetica, Arial, sans-serif]Is there a way to indicate the lines crossing by a semi-circle showing the lines cross and are not connected?[/font]
3 (edited by Nuri 2016-10-03 16:39:08)
Re: Crossing Lines
Hello Robert,
try with the "jump" element.
But be carefull, this element is a bit wrong (it is a very old one and needs some update):
you have to draw some lines under the terminal so that it really looks good on printed document (paper or pdf).
Make some print tests to correct this element!
jump_element.png, 24.04 kb, 481 x 381
Re: Crossing Lines
Thanks
