Topic: Crossing Lines
Is there a was to indicate the lines crossing by a semi-circle showing the lines cross and are not connected?
QElectroTech → EN : Help, suggestions, discussions, ... → Crossing Lines
Sorry auto type took over there :-(
[size=1][font=Verdana, Helvetica, Arial, sans-serif]Is there a way to indicate the lines crossing by a semi-circle showing the lines cross and are not connected?[/font]
Hello Robert,
try with the "jump" element.
But be carefull, this element is a bit wrong (it is a very old one and needs some update):
you have to draw some lines under the terminal so that it really looks good on printed document (paper or pdf).
Make some print tests to correct this element!
Thanks
Generated in 0.039 seconds (14% PHP - 86% DB) with 9 queries
