Topic: Single Line - Text Please
Hi
Is there some technical reason why the single line cannot have a text field as well ?
I'd like to do some drawings like the one below with wire sizes, details ..etc
Can it be added to the
QElectroTech → EN : Help, suggestions, discussions, ... → Single Line - Text Please
Hi
Not sure what happened to the bottom of the posting but it should read
Can it be added to the "would like" list
Thanks
Leigh
Hi Leigh,
You simply could just click on icon "add text field" and move text next to your conductor.
Why not, but I think it's not very useful.
J'ai testé un schéma unifilaire : j'ai définit une première liaison en N/Ph/PE. Quand j'ai raccordé un autre disjonteur en parallèle sur la même liaison, cette liaison n'a pas pris la même représentation. Cela parait plutôt normal en revanche quand on est en unifilaire il faudrait dans ce cas grisé l'option "Appliquer les propriétés aux conducteurs du même potentiel".
Cordialement.
Thanks Laurent but as you create drawings you always end up moving items around, the automatic wire connections are great but the "add text field" way means the text does not move at the same time, that's why a line with a connected text would be so good.
Hope it gets added to a near future version
Leigh
Ok, i see.
You could use this workaround, switch Single line to multifilar for conductors you want a text,
both modes can coexist without problems.
Generated in 0.034 seconds (16% PHP - 84% DB) with 11 queries
