fail build on bsd
I have troubles with build qelectrotech 0.3 on FreeBSD. I ported 0.22 before on FreeBSD, but now... It doesn\'t build:
/usr/local/bin/moc-qt4 -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_LANG_PATH=/usr/local/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/local/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/local/share/qelectrotech/titleblocks/ -DQT_SVG_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/local/share/qt4/mkspecs/freebsd-g++ -I. -I/usr/local/include/qt4/QtCore -I/usr/local/include/qt4/QtNetwork -I/usr/local/include/qt4/QtGui -I/usr/local/include/qt4/QtXml -I/usr/local/include/qt4/QtSql -I/usr/local/include/qt4/QtSvg -I/usr/local/include/qt4 -Isources -Isources/editor -Isources/titleblock -Idebug -Isources/ui -I/usr/local/include/qt4 -I/usr/local/include sources/closediagramsdialog.h -o debug/moc_closediagramsdialog.cpp
g++ -c -pipe -g -Wall -W -pthread -D_THREAD_SAFE -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_LANG_PATH=/usr/local/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/local/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/local/share/qelectrotech/titleblocks/ -DQT_SVG_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/local/share/qt4/mkspecs/freebsd-g++ -I. -I/usr/local/include/qt4/QtCore -I/usr/local/include/qt4/QtNetwork -I/usr/local/include/qt4/QtGui -I/usr/local/include/qt4/QtXml -I/usr/local/include/qt4/QtSql -I/usr/local/include/qt4/QtSvg -I/usr/local/include/qt4 -Isources -Isources/editor -Isources/titleblock -Idebug -Isources/ui -I/usr/local/include/qt4 -I/usr/local/include -o debug/closediagramsdialog.o sources/closediagramsdialog.cpp
In file included from sources/titleblockcell.h:20,
from sources/titleblocktemplate.h:23,
from sources/bordertitleblock.cpp:19:
sources/nameslist.h:59: error: expected \',\' or \'...\' before \'>\' token
sources/nameslist.h:60: error: expected \',\' or \'...\' before \'>\' token
sources/nameslist.h:63: error: expected \',\' or \'...\' before \'>\' token
sources/nameslist.h:59: error: wrong number of template arguments (1, should be 2)
/usr/local/include/qt4/QtGui/qwindowdefs.h:148: error: provided for \'template class QHash\'
sources/nameslist.h:59: error: default argument missing for parameter 3 of \'void NamesList::fromXml(const QDomElement&, const QHash&, QString)\'
sources/nameslist.h:60: error: wrong number of template arguments (1, should be 2)
sources/nameslist.h:60: error: default argument missing for parameter 3 of \'QDomElement NamesList::toXml(QDomDocument&, const QHash&, QString) const\'
sources/nameslist.h:63: error: wrong number of template arguments (1, should be 2)
sources/nameslist.h:63: error: default argument missing for parameter 2 of \'QHash NamesList::getXmlOptions(const QHash&, QString) const\'
*** [debug/bordertitleblock.o] Error code 1
et ça resemble bien a l'erreur de paolo sur son mac !
Hi, I'm trying to compile QElecroTech 0.3 under Mac OS X Lion, but stops
on this error:
sources/nameslist.h:59: error: expected ‘,’ or ‘...’ before ‘>’ token
sources/nameslist.h:60: error: expected ‘,’ or ‘...’ before ‘>’ token
sources/nameslist.h:63: error: expected ‘,’ or ‘...’ before ‘>’ token
/Library/Frameworks/QtGui.framework/Headers/qwindowdefs.h:148: error: provided for ‘template<class K, class V> class QHash’
sources/nameslist.h:59: error: default argument missing for parameter 3 of ‘void NamesList::fromXml(const QDomElement&, const QHash<QString, QString>&, QString)’
sources/nameslist.h:60: error: default argument missing for parameter 3 of ‘QDomElement NamesList::toXml(QDomDocument&, const QHash<QString, QString>&, QString) const’
sources/nameslist.h:63: error: default argument missing for parameter 2 of ‘QHash<QString, QString> NamesList::getXmlOptions(const QHash<QString, QString>&, QString) const’
make[1]: *** [release/bordertitleblock.o] Error 1
Compiler is llvm-gcc42 provided by apple (and supported by QT 4.8), if I try to compile with gcc46 (from macports) the executable is created but crash after the splash screen.
QElectroTech 0.22 compile just fine under the same environment.
https://redports.org/~zloidemon/2013101 … -0.3,1.log
