I usually choose one of these two options:
1. Draw the component as a separate element and add it to the user library. This is usually pretty quick if you stick to a standard grid an use a simple rectangle with pins on the edges. A small text item inside the rectangle for each pin (can be copied in bulk if you need more for another component). More text items to automatically show the device label and other meta-data fields, however you prefer, in a consistent way.
2. Add a simple rectangle, similar to those shown in the example by @scorpio810. When I don't want to draw the inner workings of the box, I just use the "half" terminal elements placed on the rectangle edge as connection points. One of these then gets the label and description for the whole device, so I can see it in the parts list overview. Of course this means the terminals and frame are not grouped for moving around. If you want that - better use option 1.
Drawing your own elements has a lot of advantages. What I often use is a physical drawing of the device, as a "master" element. For the schematics view, the simple boxes can then be linked to it as "slave" elements, so you can jump back to the physical view through cross-referencing, and the master can show a list of other pages where this component is referenced again. Of course this is most useful for complex parts such as PLC I/O modules, where you may want to use some channels on different pages.
