Topic: Custom Commercially Available Integrated Devices
Hello, sorry if this has been covered, but I didn't see anything in a search.
I'm just looking for advice on a good approach for schematic drawings with commercial integrated devices.
Simply put, I just want to draw a box with labels and symbols that represents an off-the-shelf product and it's interfaces that I can then draw lines to represent interconnects. Leaders and notes will be needed as well.
I'm not asking _how_ to do this, but rather whether I'm thinking about this reasonably, and is this a good use for this platform- is there a better way?
Thanks very much for any thoughts or guidance :-)
Re: Custom Commercially Available Integrated Devices
Hello maybe see this project: https://download.qelectrotech.org/qet/s … efault.pdf
I usually choose one of these two options:
1. Draw the component as a separate element and add it to the user library.  This is usually pretty quick if you stick to a standard grid an use a simple rectangle with pins on the edges.  A small text item inside the rectangle for each pin (can be copied in bulk if you need more for another component).  More text items to automatically show the device label and other meta-data fields, however you prefer, in a consistent way.
2. Add a simple rectangle, similar to those shown in the example by @scorpio810. When I don't want to draw the inner workings of the box, I just use the "half" terminal elements placed on the rectangle edge as connection points. One of these then gets the label and description for the whole device, so I can see it in the parts list overview.  Of course this means the terminals and frame are not grouped for moving around.  If you want that - better use option 1.
Drawing your own elements has a lot of advantages.  What I often use is a physical drawing of the device, as a "master" element.  For the schematics view, the simple boxes can then be linked to it as "slave" elements, so you can jump back to the physical view through cross-referencing, and the master can show a list of other pages where this component is referenced again.  Of course this is most useful for complex parts such as PLC I/O modules, where you may want to use some channels on different pages.
4 (edited by gerp124 Today 19:56:45)
Thanks very much to both @scorpio810 and @acolomb- I'm off and running- this is great :-)
As a possible point of interest, I used to work for a company that integrated off the shelf devices- almost never building anything at a component level, and we had an in-house platform based on AutoCAD that automated and standardized graphical representation of any product that an engineer wanted to use.
The primary function was to precisely illustrate connections for field personnel.
The convention was to illustrate a device with _all_ of the ports to minimize confusion in the field, and to aid in future design evaluation and revisions- you can easily see from the drawing if you have an extra io or something.
I loved this work flow, and now I can use it again for personal projects :-)
Big thanks everyone :-)
