1 (edited by Daniele.tampieri 2021-02-27 18:18:15)
Topic: How can I draw a double level terminal block in qelectrotech?
Hi to everybody: I am trying to use qelectrotech in order to draw a double level terminal and then a double level terminal block. I've already seen that there's a symbol in the library, but unfortunately it is to be used in the layout drawing and not in the electrical drawing. Also do there exist a way to represent the jumpers that join electrically these terminals when needed?
Best regards,
Daniele Tampieri
Re: How can I draw a double level terminal block in qelectrotech?
Hi gang, I'm learning too to use QET at work and I break in the same thing as Daniele. I can't have one Element symbolizing a double level Terminal. Edit Element doesn't leave me have 1 and 2 connected and 3 and 4 connected and not all connectetd.
Element property/Base type: Simple any terminals are connected. But configured as Terminal block ALL the terminals are connected!!
I don't want to place 2 simple terminals and draw a line between them each time I need a Double Level Terminal.
Someone to help me?
Daniele, have you solve your problem?
thx
