Topic: macintosh dark mode problems
i'm using the intel macintosh build on Monterrey (12.x)
for some reason qelectrotech dosen't respect the preeferneces setting "Use system colors", it always uses the system colors.
is there a work around for this? apart from just turning off dark mode in the Control panel?
Re: macintosh dark mode problems
See https://qelectrotech.org/bugtracker/view.php?id=231
Maybe you could try arummler CI/CD and get last 0.200.1 for your intel Mac?
https://arummler.github.io/qelectrotech-source-mirror/
See https://qelectrotech.org/forum/viewtopi … 280#p23280
and #722
PS I 'm stopped to build Intel macOS https://qelectrotech.org/download.php
Version 0.200.1-dev
macOS Intel X86_64 Qt5+KF5 [EOL]
qelectrotech-0.200.1-r9444-intel_X86_64.dmg (2026-09-02)
macOS Apple Silicon arm64, signed and notarized Qt6+KF6
qelectrotech-0.200.1-r9468-arm64.dmg (2026-09-06)
FYI, jp2images working on dark theme, not commited yet.
https://github.com/qelectrotech/qelectr … a6b7275d30
I'm tried on my Debian unstable with KDE plasma6.
dark_master
https://download.qelectrotech.org/qet/forum_img_2/dark_master.png
dark_jpp2images
https://download.qelectrotech.org/qet/forum_img_2/dark_jpp2images.png
light_master
https://download.qelectrotech.org/qet/forum_img_2/light_master.png
light_jpp2images
https://download.qelectrotech.org/qet/forum_img_2/light_jpp2images.png
thanks for the link to the alternative build.
i'm now running 0.200.1
will these builds be available going forward?
i have modified the style.css which does somewhat improve the situation.
the configuration directory is not ~/.qet on macintosh, it's: ~/Library/Preferences/QElectroTech/QElectroTech
that looks exactly what i need!
This is a temporary fix whilst we sort out a few points.
And I’ve just noticed that his master branch is out of sync with the official one, so the packages on his CI/CD are behind.
r9501-a583b3c43  https://github.com/qelectrotech/qelectr … ag/nightly
r9399-c6e8b9a65 https://github.com/arummler/qelectrotec … 07-0823-33
https://github.com/qelectrotech/qelectr … r/pull/894
perfect, now i just need a build for macos intel....
