Topic: Issue: Install on: macOS M2 "Damaged and Can't Be Opened"
Hello QElectroTech team,
I recently downloaded and attempted to run QElectroTech v0.100.0 (r8427) for macOS Apple Silicon (arm64, signed and notarized) from the official site. However, when I try to open the app, I receive the following error:
"qelectrotech" is damaged and can’t be opened. You should move it to the Bin.
System Details:
Mac Model: MacBook [M2]
macOS Version: [macOS 14.4 Sonoma]
Downloaded File: qelectrotech-0.100.0-r8427-arm64.zip
Troubleshooting Steps Tried:
Thank you for your support!
Francisco mendes
Re: Issue: Install on: macOS M2 "Damaged and Can't Be Opened"
cite from Bugtracker:
Workaround:
- Download however you prefer, FireFox, Safari, etc
- Expand the arm64 zip with terminal: unzip qelectrotech-xxxxxxx-arm64.zip
- Launch .app as usual, and be presented with confirmation to open a functioning application with proper validation
I noticed that downloading the ARM64 archive and expanding with the double-click Archive Utility, the resultant application reports as corrupt. I'm not sure why exactly. Clearly there are differences between the terminal application and the GUI Archive Utility - I'm sure there are reasons.
https://github.com/qelectrotech/qelectr … issues/307
Thanks. It worked like a charm.
It would be useful to add this note on macOS Download page
Yes of course,  I can add this information, but when my health is more better!!!
Thanks for your feed back! nomicons/wink
@scorpio810 I wish you a good recovery.
@RedBaron thanks you.
macOS ARM64 DMG Build & Notarization — Fixed Workflow
After a lot of trial and error, here is the working process to build, sign, notarize and distribute QElectroTech as a proper macOS DMG for Apple Silicon (arm64).
  • Problems encountered
    1. Gatekeeper blocking the app when downloaded via Chrome
    The original script used ditto --sequesterRsrc to create the final ZIP. This flag places resource forks in a hidden __MACOSX/ folder which breaks extended attribute extraction in Chrome / Archive Utility, causing Gatekeeper to block the app with "Apple could not verify that this app is free of malware". Safari worked fine because it handles ZIP extraction differently.
    2. All MacPorts dylibs were unsigned
    macdeployqt copies third-party libraries (libsqlite3, libpng, libssl, libharfbuzz, etc.) from MacPorts into Contents/Frameworks/ without signing them. Using codesign --deep (now deprecated) missed these flat .dylib files. Apple's notarization service rejected the submission with "The binary is not signed with a valid Developer ID certificate" for every single one of them.
    Fix: sign every binary explicitly in the correct order — all .dylib files in Frameworks/ first, then .framework bundles, then plugins, then the main executable, and finally the bundle itself.
    3. hdiutil invalidating the bundle signature during DMG creation
    After the .app was correctly signed and notarized, creating a DMG with hdiutil create copies the bundle and recalculates checksums, which invalidates the Sealed Resources signature. Submitting this DMG to notarytool resulted in "The signature of the binary is invalid".
    Fix: create a writable DMG (UDRW format), mount it, re-sign all binaries inside the mounted volume, detach it, then convert to the final compressed read-only DMG (UDZO). This ensures the signature is valid after the conversion.
  • Final workflow
    1. Build with qmake + macdeployqt
    2. Copy elements, titleblocks, translations, fonts, lang, examples into the bundle
    3. Sign all binaries (dylibs → frameworks → plugins → executable → bundle)
    4. Submit a temporary ZIP to notarytool → wait for Apple approval
    5. Staple the notarization ticket onto the .app
    6. Create a staging folder with the .app + a symlink to /Applications
    7. Create a writable UDRW DMG from the staging folder
    8. Mount the UDRW DMG and re-sign all binaries inside
    9. Detach and convert UDRW → UDZO (final compressed DMG)
    10. Sign the DMG with codesign
    11. Submit the DMG to notarytool → staple the ticket onto the DMG
    12. Verify: spctl -a -vv → "accepted / Notarized Developer ID"
Result
The DMG now passes Gatekeeper correctly whether downloaded via Chrome or Safari. It includes a drag-and-drop Applications shortcut and is fully notarized and stapled.
Enjoy! nomicons/wink
