1 (edited by achim 2026-03-17 13:22:15)
Topic: Error on github qet-source-mirror
I can no longer clone the QElectroTech repository.
The cloning process ends with an error message:
C:\Users\xxx\xxx\xxx\xxx> git clone --recursive https://github.com/qelectrotech/qelectr … mirror.git
Cloning into 'qelectrotech-source-mirror'...
remote: Enumerating objects: 153432, done.
remote: Counting objects: 100% (176/176), done.
remote: Compressing objects: 100% (101/101), done.
remote: Total 153432 (delta 105), reused 99 (delta 71), pack-reused 153256 (from 2)
Receiving objects: 100% (153432/153432), 133.84 MiB | 9.72 MiB/s, done.
Resolving deltas: 100% (128382/128382), done.
Updating files: 100% (1627/1627), done.
Downloading doc/QElectroTech.qch (530 MB)
Error downloading object: doc/QElectroTech.qch (7b77982): Smudge error: Error downloading doc/QElectroTech.qch (7b7798233e8251baac7717d4b0f991ad5fdf23a76d9fbe864d363e3b93458560): batch response: This repository exceeded its LFS budget. The account responsible for the budget should increase it to restore access.
Errors logged to 'C:\xxx\xxx\xxx\xxx\xxx\qelectrotech-source-mirror\.git\lfs\logs\20260317T120632.3963731.log'.
Use `git lfs logs last` to view the log.
error: external filter 'git-lfs filter-process' failed
fatal: doc/QElectroTech.qch: smudge filter lfs failed
warning: Clone succeeded, but checkout failed.
You can inspect what was checked out with 'git status'
and retry with 'git restore --source=HEAD :/'
The problem seems to be the size of the "QElectroTech.qch" file
in the doc directory.
Re: Error on github qet-source-mirror
Hello Achim:
No problem here on Debian Unstable...
git clone --recursive https://github.com/qelectrotech/qelectrotech-source-mirror.git qet_test
Clonage dans 'qet_test'...
Réception d'objets: 100% (153432/153432), 133.82 MiO | 40.37 MiO/s, fait.
Résolution des deltas: 100% (128379/128379), fait.
Sous-module 'SingleApplication' ([url]https://github.com/itay-grudev/SingleApplication.git[/url]) enregistré pour le chemin 'SingleApplication'
Sous-module 'doxygen-awesome-css' ([url]https://github.com/jothepro/doxygen-awesome-css.git[/url]) enregistré pour le chemin 'doxygen-awesome-css'
Sous-module 'elements' ([url]https://github.com/qelectrotech/qelectrotech-elements.git[/url]) enregistré pour le chemin 'elements'
Sous-module 'pugixml' ([url]https://github.com/zeux/pugixml.git[/url]) enregistré pour le chemin 'pugixml'
Clonage dans '/media/backup6/download/qet_test/SingleApplication'...
remote: Enumerating objects: 1461, done.
remote: Counting objects: 100% (533/533), done.
remote: Compressing objects: 100% (117/117), done.
remote: Total 1461 (delta 463), reused 416 (delta 416), pack-reused 928 (from 1)
Réception d'objets: 100% (1461/1461), 535.08 KiO | 4.18 MiO/s, fait.
Résolution des deltas: 100% (783/783), fait.
Clonage dans '/media/backup6/download/qet_test/doxygen-awesome-css'...
remote: Enumerating objects: 2996, done.
remote: Counting objects: 100% (484/484), done.
remote: Compressing objects: 100% (130/130), done.
remote: Total 2996 (delta 405), reused 354 (delta 354), pack-reused 2512 (from 2)
Réception d'objets: 100% (2996/2996), 8.47 MiO | 32.61 MiO/s, fait.
Résolution des deltas: 100% (2281/2281), fait.
Clonage dans '/media/backup6/download/qet_test/elements'...
remote: Enumerating objects: 59430, done.
remote: Counting objects: 100% (21211/21211), done.
remote: Compressing objects: 100% (8247/8247), done.
remote: Total 59430 (delta 13969), reused 17451 (delta 12926), pack-reused 38219 (from 1)
Réception d'objets: 100% (59430/59430), 48.60 MiO | 37.11 MiO/s, fait.
Résolution des deltas: 100% (45028/45028), fait.
Clonage dans '/media/backup6/download/qet_test/pugixml'...
remote: Enumerating objects: 9869, done.
remote: Counting objects: 100% (2410/2410), done.
remote: Compressing objects: 100% (360/360), done.
remote: Total 9869 (delta 2187), reused 2054 (delta 2050), pack-reused 7459 (from 1)
Réception d'objets: 100% (9869/9869), 6.52 MiO | 23.33 MiO/s, fait.
Résolution des deltas: 100% (6806/6806), fait.
Chemin de sous-module 'SingleApplication' : 'cbe496bc01e6515f9692824bf36d5136e8208c85' extrait
Chemin de sous-module 'doxygen-awesome-css' : '568f56cde6ac78b6dfcc14acd380b2e745c301ea' extrait
Chemin de sous-module 'elements' : '4e7f569dca75ee7ca78fc86b33cd800dfb4951d7' extrait
Chemin de sous-module 'pugixml' : '5a1892b321a38997e3e359069aea3fa35d49a5c6' extrait
[12:33:41] laurent@debian:/media/backup6/download$
Okay, thanks for the reply.
It seems the problem is on me. I'm not an expert with Git/GitHub. I spent half the day
on it yesterday. The problem is indeed the large QElectrotech.qch. I deleted the file in
my GitHub repository, and then I was able to clone from my repository.
Okay, I guess I'll have to keep looking.
I had the same issue on my Windows 11 VM but not on my Debian system. Since no one else had reported it, I assumed it was an isolated error. Apparently, that’s not the case. It might be a Git configuration issue on the Windows side.
Exactly as you said. Last evening I discovered that the problem doesn't exist on my both Debian systems.
It only affects my two Win11 computers.
Let's see, maybe I'll be able to solve the problem eventually.
May be test this :
https://stackoverflow.com/questions/420 … noring-lfs
https://it-explain.com/how-to-clone-git … lfs-files/
Thanks Joshua, the solutions described in the links helped.
